| Dyneema jib halyard #152730 08/14/08 11:57 PM 08/14/08 11:57 PM |
Joined: Sep 2006 Posts: 586 Hobart, Tasmania, Oz. Dazz OP
Posts: 586 Hobart, Tasmania, Oz. | Hi everyone
Im about to replace the jib halyard on the capricorn, I would like to use dyneema but i am concerned about the stretch as my halyard is not adjustable on water.
are there many peeps using dyneema over wire now?
| | | Re: Dyneema jib halyard
[Re: Dazz]
#152732 08/23/08 01:41 PM 08/23/08 01:41 PM |
Posts: 1,203 uk | Don't do it unless you can rig an easy on the water tensioner
[Re: davefarmer]
#152734 08/24/08 07:32 PM 08/24/08 07:32 PM | Anonymous
| Anonymous
Unregistered | Dazz,
the last owner of your boat was a know nothing layabout. Whatever you do change all his systems and rope selections etc. | | | Re: Dyneema jib halyard
[Re: ]
#152735 08/27/08 02:37 AM 08/27/08 02:37 AM |
Posts: 586 Hobart, Tasmania, Oz. | Thanks Scarecrow, I'm sure TA will be pleased to hear that :P
There are some realy good setups on this boat that I havnt seen anywhere else.
I have made some changes, done a bucket load of maintenace (all standing rigging, diamonds, all shock cord, new sheets..) mostly so the boat is easier to deal with on a week to week basis.
The forestay is being replaced today, the furler is coming out as the jib doesnt furl anyway. The choice between a rope or wire jib halyard determins the type of pulley that will be swaged onto the forestay.
Im sticking with wire.
[Re: Dazz]
#279572 06/23/15 02:55 AM 06/23/15 02:55 AM |
Posts: 9 | Hi there, I would like to replace the jib halyard on my Nacra Infusion mk II. What line are recommending for the halyard? Should I use Dacron or some other material, such as Vectran? Here's the Nacra's manual how to replace the halyard -> http://goo.gl/ohNDxi . Thanks in advance. | | | Re: Dyneema jib halyard
[Re: Dazz]
#279593 06/24/15 07:06 PM 06/24/15 07:06 PM |
Posts: 586 Hobart, Tasmania, Oz. | What a fortune teller you turned out to be Scarecrow. by the time I had finished it was virtually identical in setup to the C2, so when i made the move to a new boat, everything was the just the same but faster/easier to sail.
Juha, any old piece of string will do for a nacra halyard. If you have the stock hook/ring arrangement then there is no load on the halyard at all.
153
guests, and 222
