Jib setting on 5.8 #156859
10/12/08 06:14 AM
10/12/08 06:14 AM
Kingston SE South Australia
JeffS Offline OP
JeffS  Offline OP
Set up the 5.8 for light wind yesterday. The jib leads were forward in the slide, when I looked at the video the foot was pretty loose when the jib was on hard up wind even though the telltales were flying okay. It got to about 13 knotts, 2 on the wire rarely flew the hull more than 4ft.
Is it more important to have the foot pulled tighter for shape or more important to have the high volume of air pushed through?
I've attached the only photo taken just after the start the jib wasn't fully on but was close. Were the ones at the back.
regards
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: Jib setting on 5.8 [Re: JeffS] #156860
10/12/08 12:01 PM
10/12/08 12:01 PM
Santa Barbara CA
sbflyer Offline
sbflyer  Offline
Santa Barbara CA
Move the jib leads back usually in light air (wouldn't call 13 kts light air though, light usually refers to under 8 kts where its starting to go into laminar flow.). But if your jib is getting a little baggy could be hard to get it looking right. Where you passing people or getting passed?
Re: Jib setting on 5.8 [Re: sbflyer] #156861
10/12/08 01:57 PM
10/12/08 01:57 PM
SE Pa. or Chesapeak Bay
HMurphey Offline
HMurphey  Offline
From the pic (if I picked out the correct boat) your jib luff curve is not quite matched to you mainsail curve .... I would try moving your jib leads back slightly and if at 13knts of wind you are backwinding the mainsail, move the jib traveler out alittle to open the slot ... You are close through
Sail Flat, Sail Fast, Sail Safe
Harry Murphey
TheMightyHobie18/#9458, Fleet54/Div11
P19mx/#86, CRAC
Re: Jib setting on 5.8 [Re: HMurphey] #156862
10/12/08 03:07 PM
10/12/08 03:07 PM
JeffS Offline OP
JeffS  Offline OP
Thanks guys it was only about 8 knotts when the photo was taken and then it just kept gradually building to 13. The main wasn't backwinding but I was slow which I put down to our weight until I saw the pics and video. The jib leads are on tracks on the hulls and only go for and aft, I had them as far forward as they would go which may have been too far. Do you point better with the jib leads further back even in light air?
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
Re: Jib setting on 5.8 [Re: JeffS] #156863
10/13/08 04:34 AM
10/13/08 04:34 AM
Hobart, Tasmania, Oz.
Dazz Offline
Dazz  Offline
Hi Jeff's
if you have a look at the modern 5.8's you will notice they don't have jib tracks anymore. instead they have alight-medium position and a heavy weather position.
the simple things often work the best. If you dont have access to a modern boat I can measure one for you. just let me know.
in the mean time this is how it should look:
C2 AUS 222 by Goodall design
"Darph Bobo"
Re: Jib setting on 5.8 [Re: Dazz] #156864
10/13/08 05:14 AM
10/13/08 05:14 AM
JeffS Offline OP
JeffS  Offline OP
Thanks Dazz I'd appreciate if you would measure it for me, mine is the only 5.8 I've seen except for pictures so I've got no idea. That foot in your post is nice and tight even in light wind and appears to be inside the hull. Does it have a wire across the tramp to bring the jib leads in? I'll work on the jib settings this weekend as the weather report seems to be more of the same.
regards
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
Re: Jib setting on 5.8 [Re: JeffS] #156865
10/13/08 05:59 AM
10/13/08 05:59 AM
Dazz Offline
Dazz  Offline
No wire across the deck. in this picture you can see it more clearly.
We hardly ever moved them back unless it was blowing the dogs off the chains.
Will post tomorrow with measurements. also do you have a clew traveler or a clew board with holes?
"Darph Bobo"
Re: Jib setting on 5.8 [Re: Dazz] #156866
10/13/08 06:30 AM
10/13/08 06:30 AM
JeffS Offline OP
JeffS  Offline OP
Beautiful cat, what do your jib leads attatch to? I've got an old baggy main with a clew traveller and the newer one in the post that is fairly flat with holes for a hook. I had the hook in the middle hole.
regards
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
Re: Jib setting on 5.8 [Re: JeffS] #156978
10/14/08 06:09 PM
10/14/08 06:09 PM
Dazz Offline
Dazz  Offline
The jib attaches to a saddle mounted on the deck on the tramp side of the hull. we had two saddles mounted at 107cm and 120cm from the main beam. many boats only have the one at 107cm.
"Darph Bobo"
Re: Jib setting on 5.8 [Re: Dazz] #157032
10/15/08 12:46 AM
10/15/08 12:46 AM
Dazz Offline
Dazz  Offline
oooo that worked!!!
"Darph Bobo"
Re: Jib setting on 5.8 [Re: Dazz] #157038
10/15/08 01:51 AM
10/15/08 01:51 AM
JeffS Offline OP
JeffS  Offline OP
Thank's for the PM as well Dazz you've given me heaps to work on.
regards
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
Re: Jib setting on 5.8 [Re: Dazz] #157057
10/15/08 06:34 AM
10/15/08 06:34 AM
Dunedin Causeway, FL
David Parker Offline
Originally Posted by Dazz
We had two saddles mounted at 107cm and 120cm from the main beam.
I have an old Nacra 5.0 and would like to add another jib block saddle (eye strap?)for my new short-foot long-leach jib. How did you attach the saddle to the hull? Do you feel the hull is structurally sound enough to carry the load? Is there a backing plate under the deck lid? Bad news if it ripped out under load!
Re: Jib setting on 5.8 [Re: Dazz] #157058
10/15/08 06:42 AM
10/15/08 06:42 AM
Am I missing something here? What is the skinny red line? If that's a barberhauler why is the cleat mounted on the low side and why doesn't the line run out to a block on the beam end? It must be someting else. I MUST have the wrong idea. What is that line?
My copy of your photo comes out tall and thin and you must scroll right to see the cleat I'm talking about.
Re: Jib setting on 5.8 [Re: David Parker] #157066
10/15/08 07:33 AM
10/15/08 07:33 AM
http://www.catsailor.org/photos/downhaul/
here are some more pics of jack
yes that line is the barber hauler, yes it worked perfectly.
I cant be certain of a plate below the saddles because they were fitted at the factory. That boat is now 8 years old and the fittings did not move.
Re: Jib setting on 5.8 [Re: Anonymous] #157067
10/15/08 07:35 AM
10/15/08 07:35 AM
Dazz Offline
Dazz  Offline
that cant be good, posted without logging in!
"Darph Bobo"
1 registered members (Mark Wasleyy), 487 guests, and 100 spiders.
Posts267,056
