Heavy weather sailing in multihulls #16308
02/10/03 04:01 PM
02/10/03 04:01 PM
Farmington, Utah
thouse Offline OP
thouse  Offline OP
Farmington, Utah
I thought this worth the read, so I posted it for others:
By Kevin Jeffrey and Charles E. Kanter
First, let us make the distinction between heavy weather sailing and survival sailing. Heavy weather sailing is done in full control of your circumstances and ability to manage your vessel. Survival is when you pass that point and must take action to preserve life and property...a subject for another time.
Historically, many situations that would have been survival situations in other craft were just heavy weather sailing for catamarans. There is a classic story by Robin Knox Johnson published in Cruising World. It is his account of sailing his catamaran through Force 12 winds. There are other similar experiences that support the notion that keeping the vessel under way is perhaps the best survival tactic.
Little has been written specifically for survival situations in multihulls. The basic reason for this lack of literature is the astonishing safety record compiled by ordinary sailors in "off the shelf" catamarans. For instance, at the time of the famous Fastnet disaster, of which volumes have been written, there were two Prout catamarans in the vicinity. They were shadowing the fleet as unofficial entries. The racing fleet sailed into a serious storm. The carnage caused by the storm was so great that a Committee On Safety From Capsizing was formed. It consisted of the Society of Naval Architects and Marine Engineers (SNAME), the United States Yacht Racing Union (USYRU), and the United States Naval Academy (USNA), and others. The purpose of this committee was to design a minimum stability formula for ocean racing monohull yachts. The weather that was disaster to the Fastnet fleet was considered merely "beastly weather for sailing" by the two adjacent catamarans.
Heaving weather sailing--basic tactics
Knowing when to reef is the most important skill to develop for heavy weather sailing. Then comes sail shape and sheeting angle. There are a few generalities that will help you get started learning about heavy weather sailing tactics:
As the wind increases, move the sheeting point to leeward. This is one of the best features of multihull sailing. Multihulls have a wide sheeting base, which allows a greater angular choice for sail trim than narrow boats. Ease off the traveller to move the main to leeward and use an outside rail attachment point, stanchion base or toe track and car to move the jib to leeward.
Allow more twist in the sails as the wind strengthens and reduce camber (flatten the sails). This is achieved in the main by slacking the mainsheet and in the jib by moving the sheeting point aft.
Reduce sail. You will find most multihulls just as happy with reduced sail, and you will be surprised how little speed you really lose.
Learn to use a barber-hauler to control your jib. A barber-hauler does not need to be a fancy multipart tackle, but can be made from almost anything, including just a length of line from the clew of your jib to an appropriate turning point and to a winch.
Slow down to a more moderate speed...like slowing down your car when you come to a rough road.
Choose sail combination according to direction. Downwind-reduce main area first, then the jib. Upwind-reduce jib first, then the main. This is just a rule-of-thumb. It must be tailored to the individual vessel.
Expect to hand-steer downwind in big waves. Your autopilot will not be able to react fast enough, nor can it anticipate waves. The trick is never to allow yourself to be perpendicular to the wave, but always to be at angle to it. That way you are always sailing downhill, and you eliminate the chance of pooping or pitch-poling. Pooping is unheard of in cruising catamarans, and pitch-poling comes from excessive speed perpendicular to the waves.
Getting to windward
If you seriously feel the need to maximize your heavy-weather windward ability under sail, then you must be prepared to change headsails for the purpose. Roller reefing sails are good to a certain point. It must be remembered that a sail is sewn to pull against the head, tack, and clew with the luff supported by a stay. When a sail is partially rolled, it is no longer pulling against the designed strong points but is pulling against the luff and the foot where they roll around the stay. While it is possible to do reasonably well with a partially rolled jib, it is without doubt much better to have a sail specifically cut for that purpose, such as a good storm jib.
On the other hand, if you do what most cruisers do and simply run your engine about one third your normal cruising speed, you will go to windward just fine.
This motor-sailing concept is almost the universal choice of cruisers for going to windward in heavy weather. In a catamaran with twin engines, it is usually only necessary to run one of the engines to gain the desired effect.
How do I know when to reef?
This is the most often asked question concerning multihull safety. The answer is deceptively simple: "It is time to reef when you first think about it." This is not meant to in any way belittle the importance of knowing that "time." As you get more experience with your particular boat, the more feel you will get for the process. Let us compare learning how to "feel" your boat, with how you learned to "feel" your car. When you first learned to drive, how did you know when to start slowing for a stop? If you started slowing too soon, you created a traffic hazard. If you started too late, you wound up with a panic stop or a rear end collision. How did you learn this subjective judgmental skill? How did this judgmental process become habituated? The feel just developed with experience.
Subjective and objective sailing
From the subjective point of view, when you begin to feel uneasy, apprehensive, concerned, it is time to reef. When the boat no longer has its feather light touch at the helm, it is time to reef. When the boat's motion changes from its normal light, resilient feeling to one of petulant obedience, it is time to reef. When the lee bow seems to want to plunge and bury, it is time to reef. From the objective point of view, when the apparent wind speed goes over 15 knots, it is time to reef on most boats. When you are heeled two degrees more than normal, it is time to reef. When you are no longer strong enough to crank in the sails, it's time to reef. Reefing, as referred to in this section, includes both headsail and mainsail. As a rule for masthead boats, upwind reef the jib first, downwind reef the main first. It is hard to generalize about fractional rigs. Sailing under main alone is typically far more controllable. The fully-battened mainsail has the most sail controls, is held on two sides by spars, and can be given optimum size and shape.
Experience counts
There is no substitute for experience, and I suggest taking your catamaran out in a controlled environment in strong winds, with some capable crew. Sail it as hard as you can and try to lift a hull. You may or may not be able to do it. You surely will learn a lot about how your cat feels when you begin to reach the realistic usable limits. Never sail your boat that hard again if you can help it!
Trimarans
A trimaran is far easier to judge when over-pressed than a catamaran as the extreme initial stability of the cat muddies both sensory and visual clues. A trimaran heels almost like a monohull, and you can visually see the lee float being depressed. Since there is more heel, there is more familiarity for those used to monohulls. As with any multihull, however, the wide beam of a trimaran allows you trimming angles not available to monohulls; thus you can have far more control and keep your power up longer. A good multihull requires less power to move at speed because it is lighter and does not have the hull speed limitation factor of a monohull.
Re: Heavy weather sailing in multihulls [Re: thouse] #16309
02/10/03 05:12 PM
02/10/03 05:12 PM
South Louisiana, USA
Clayton Offline
Clayton  Offline
Excellent article Tom. As a fairly new sailor to Stiletto's this is the one concern of mine as I get used to a larger boat. With my other cats I always new that I could right the boat if I flipped it. Not so with this one. But as mentioned, on the water time experience is the one thing that will make someone comfortable with the capabilities of his boat.
Clayton
0 registered members (), 528 guests, and 103 spiders.
Posts267,056
