Page 4 of 13 1 2 3 4 5 6 12 13
Re: 1182 [Re: Pirate] #267754
12/15/13 10:52 PM
12/15/13 10:52 PM
Derrinallum
Al_scorpion1101 Offline
Derrinallum
Tramp on. Fittings on and youre on the water! Get excited mate!
Now the real fun starts!
Al
Scorpion 1101 Mosquito
Wild oats g=6 Graduate
HARD WOOD RACING
Re: 1182 [Re: Matt_Stone] #267775
12/17/13 05:37 AM
12/17/13 05:37 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
Originally Posted by Matt_Stone
The orange peel affect, is caused by applying too thick off the gun, to get auto finish thinner coats and more of it, what I saw in the pics is called fish eyed, means contamination on the cloths or on the work, usally siliconis the main cause and oil. other reasons undercoat not cured properly. Orange peel affect is on almost everything that is industral, as its a good strong coat and will last for years, auto finish is good bht need to be upkept
The paint rep dropped by today, showed him the pics of the boat and he also had a look at the effected steel work....
verdict => too heavy with the 2nd coat and way too hot when applied, the really bad areas are a contamination .
this is part of the effected steel work that was sprayed on the same day, oddly enough only half the beam was effected, the rest as we've since noted was in the shade and completely unaffected.
Kingy
& now Mosquitos #1182 & #1740
Re: 1182 [Re: Al_scorpion1101] #267776
12/17/13 05:53 AM
12/17/13 05:53 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
Al
yep its all starting to come together nicely...... soon..... very soon I hope
cant wait.....
lets hope it floats [Linked Image]
I'm actually missing working on Jurassic karp and I'm keen to get back onto it again, the huge gain has been the bits I now know I'll do differently => very differently in fact
shocked
I have a few other ideas to try out over the next week or two that will also have an impact on Karp in the long run. hopefully over the x-mas break I'll get Karp into full primer and have the graffic's all finalised and cut out ready for the base color coat
as of tonight (actually 1/2 an hour ago wink )...... two of the main bits are married again grin
my eBay bargin is lookin sweet as now
wink
Kingy
Re: 1182 [Re: Al_scorpion1101] #267910
12/21/13 06:24 AM
12/21/13 06:24 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
Tramp on. Fittings on .......
getting there wink
Kingy
Re: 1182 [Re: Pirate] #267911
12/21/13 06:28 AM
12/21/13 06:28 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
the name makes an appearance smile
the treadgrip is applied.... this is just the first coat so the masking tape will stay until the 2nd coat is on.
Kingy
Re: 1182 [Re: Pirate] #267912
12/21/13 06:41 AM
12/21/13 06:41 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
couple more shots of the treadgrip
close-up of the treadgrip remembering this is just the first coat so it will have a bit more body to it later....
for perspective the strip is ~40mm wide wink
Kingy
Re: 1182 [Re: Pirate] #267937
12/22/13 06:52 AM
12/22/13 06:52 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
2nd coat applied and dry, masking tape removed smile
although it looks quite coarse its actually rather smooth to the touch, it does actually 'feel' quite grippy
grin
The tredgrip was tinted to match as close as possible to the actual color of the boat, and esentually it is as close to identicle as the paint shop could get it, the main reason its so different is its a low sheen paint and the boat has a high gloss over it so a dead match was never going to happen....
but damn its close
wink
lesson learned for Jurassic Karp, make sure that the tredgrip can be matched to the color wink
Kingy
Re: 1182 [Re: Pirate] #267938
12/22/13 07:00 AM
12/22/13 07:00 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
today was a tidy up day....
chase a few loose ends and do a few of the fiddly little bits
simple stuff like this
the eye-bolt was a part of original hold-down setup on the trailer, 4 of them strapped the boat down via turn-buckles.
One broke on the way home and I did stop 3 or 4 times to re-tension the boat back down.....
No wonder it moved around a bit on the trailer shocked
Of the 4, one remove itself somewhere between here and its old home, 2 snapped off clean as soon as I showed them the spanner and this one was the cream of the crop ......
this eyebolts location is where the threaded end is pointing, now sporting a nice n new stainless bolt
grin
Kingy
Re: 1182 [Re: Pirate] #267939
12/22/13 07:08 AM
12/22/13 07:08 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
rear decks glossed up n lookin sexy grin
this is straight gloss, I didn't stain the ply and yet it came up really well, definitely highlights the grain in the ply
smile
Kingy
Re: 1182 [Re: Pirate] #267940
12/22/13 07:25 AM
12/22/13 07:25 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
I also spent a few hours on the lathe machining up some steel discs....
the discs prior to being machined up....
now it may seem a bit of an odd thing to be doing but there is as usual a reason behind them..... and that is the one thing we've not repaired/cleaned/altered/replaced/painted/resined or polished......
I sure as hell aint using these.....
the steel discs will when finished allow me to roll 20mm alloy square tube into a nice tight circle..... and then with a wave of the magic wand I'll hopefully have a nice pair of rudder boxes.....
thats if it works
whistle
stay tuned...... wink
Kingy
Re: 1182 [Re: Pirate] #267999
12/24/13 05:36 PM
12/24/13 05:36 PM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
assembled and ready to go with the first one about to be released....
& hey presto ....
grin
Kingy
Re: 1182 [Re: Pirate] #268000
12/24/13 05:42 PM
12/24/13 05:42 PM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
half an hour later smile
(NB: the unit behind my rolling die is off a Taipan and is what I'm duplicating, only slightly smaller wink )
all the bits are now rolled and ready for assembly which I'll do if I find a spare minute or 10 over the next few days.
Haven't decided on whether I'll tig weld them together or just use pop-rivets and small bolts as yet, but the plan does call for some stainless steel plates to be pop-riveted on, these plates will strengthen up the areas around the hinge pins etc and reduce wear down to a minimal amount...
merry xmas to all
smile
Kingy
Re: 1182 [Re: Pirate] #268022
12/26/13 06:30 AM
12/26/13 06:30 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
xmas dinners aside, and the customary mid-day nap to sleep off the meal.... tired sleep
and having assembled a dozen odd toys for the boys along with a few others bits for the less mechanicly minded adults that insisted in dropping by..... bloody relitives eek
Xmas is half done, only have the other side of the family to do tomorrow cry
Today I managed to sneak out to the shed armed only with the last 2 toys to assemble, with them done and quietly returned to the lounge room without being spotted I figured I'd earnt a reward ...... boat time grin
2 hours later and both 'boxes' are assembled with one slightly further progressed than the other, I'll just sneak in another half n hour and do the pins.... so a duplicate set to Jurassic Karps is pumped out .....
cool
Oh what the hell.....
may as well slip all the bits together for a mock-up....
so.....
after 3 hours we have ....
Kingy
Re: 1182 [Re: Pirate] #268023
12/26/13 06:36 AM
12/26/13 06:36 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
the duplicate top pin setup
bottom pin setup
The bolts through the transom haven't got nuts on them, the entire mock-up is literaly just hanging there
cool
Kingy
Re: 1182 [Re: Pirate] #268024
12/26/13 06:45 AM
12/26/13 06:45 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
this bit wasn't fun.....
every bolt I had was way too short or way too long, so this was the simplest solution, rather pleased with the end result
smile
Kingy
Re: 1182 [Re: Pirate] #268025
12/26/13 06:46 AM
12/26/13 06:46 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
bottom plate ......
Kingy
Re: 1182 [Re: Pirate] #268026
12/26/13 06:51 AM
12/26/13 06:51 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
I'll just sneak in another 1/2 n hour wink
which resulted in
all up, it's been a good xmas so far, and I'm pleased with the results on the boat as well over the last couple of days.
grin
76/2965
Kingy
Re: 1182 [Re: Pirate] #268174
12/31/13 06:30 AM
12/31/13 06:30 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
Hours n hours of measuring /checking, double checking my measurements after re-measuring yet again, I decided to do some more trimming to the rudders to get them where I wanted......
A phonecall was made and the positions and angles were discussed at length .... 2 mozzie owners measuring the boats as we walk around our own sheds comparing the pro's n con's of what and where and how much.
Thanks Philip, your knowledge backed my thought up almost exactly...... + or - a few mm
grin
Kingy
Re: 1182 [Re: Pirate] #268175
12/31/13 06:35 AM
12/31/13 06:35 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
the next thing I know is I'm at the local army disposals store and much to my supprise (& $8:00 later) I get back home with this....
yup....
dome tent fibreglass pole thingies....
smirk
and this has what to do with 1182 ???? .....
Oh....
and I also added 2 extra screws between the existing screws in the tramp track, 20 extra screws means a lot more strength for the tramp/hull connection and although I'm a trim 75kgs when she goes 2 up then it may well get some added stress that may be too much for the old girl
smile
Kingy
Re: 1182 [Re: Pirate] #268177
12/31/13 06:53 AM
12/31/13 06:53 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
then I hit the lathe and a lump of stainless shaft began a transformation.....
now that these are done, I started wondering about using alloy.... mmmmmmmm wink
[img]http://i961.photobucket.com/albums/ae97/BADZX/1182/116_zpsde099215.jpg[/img]
next set maybe
the stainless ones will do for now ..... smile
more lathe work to come on these but for now that will have to do on these bits
wink
Kingy
0 registered members (), 474 guests, and 116 spiders.
Posts267,058
