Howling winds (40), four capsizes, typical Biscayne bay chop, and sailing with someone you can trust in these testing conditions, priceless. Columbus Day Regatta, Coral Reef YC, 96 registered from 20 to 40+ footers, and started at NW end of Biscayne bay. It was a cloudy day with moderate winds and seemed comfortable enough (hook), maybe the weather forecast was wrong. We started right on time at 10:55a GPS time, down to a buoy to far. A Stiletto 23 was windward of us on Port tack, and we gradually put distance on them (gage). Twenty minutes later We gibed on to starboard, and then it started to rain. With visibility about 50 feet we were now flying/sailing by GPS, and it was time to jibe back to Port and give us a safe distance from the shore, just in case. It was either at this time the squall hit or Hans did not S jibe, and we capsized. It was definitely a surprise, but Hans and know the drill and easily righted the Hobie 20 with the help of wind. While we were capsized the Stiletto 23 came over to check us out to make sure everyone was Ok, and thank you guys. Interestingly the Hobie 20 went over rather slowly compared to my F16.
A little disorientated now we set up to get going, and couple minutes later got blow over again. We righted the Hobie 20, and the wind blew it over the other way. OK, capsized, we sat it out for a while to let Mother Nature calm down a bit, and then righted the catamaran. Now the wind really picked up, probably the peak, and I assumed the helm and feathered the boat in the squall with the main traveler all the way out, and again waited for MN to calm down. Meanwhile the quick release on the jib sheet came off and Hans had to watch his expensive jib shred itself. Hans wanted to cut it down, but the storm was so intense at this point, I told him to wait until another lull, because it he falls off trying to cut down the jib, I would not be able to find him. With the jib down we feathered the wind toward Stiltsville, tacked and sailed/feathered our way to Hobie beach (Rickenbacher causeway).
We knew we would be overpowered under main with the rain squalls coming one after another, and would be a high risk sailing into US Sailing in Coconut Grove. This was one of the few times I have ever brought my cell phone and Hans called a friend who gave us ride to US Sailing Center, and Hans got his backup jib. So we jury rigged the jib on the mast were the main goes, and did 12 knots back to Coconut Grove. We were discussing when, where, how to get the sail down, when a huge gust tore the sail off the mast, and end of discussion. We were now doing 5knots under bare poles, entered USSC channel and roped the dock.
