Catsailor.com reef my mainsail?
You know those days when its blowing stink and you cant find crew? and its honkin' too hard to go out with expectation that you'll make it back, in the 20-25 knot range? I only sail with the main. If I took the sail to a local sailmaker how would i tell them to reef it? How far down should i reef the thing to spill more air? How would i rig a reef rig on the halyard? The outhual is adjustable so that shouldnt be a problem. I just feel useless and a waste letting all that wind just blow by!!
Posted By: Mike Fahle Re: reef my mainsail? - 10/29/02 09:37 PM
One idea is to acquire a used sail (or buy a new one for racing and do this to the current sail) and have the sailmaker cut out the roach. The leech will have a hollow from head to clew (like unbattened jibs) which will remove as much as 40% of the sail area, depending on how big the roach was to start. The advantages to this approach are: You eliminate the need for battens - imagine not having to be concerned about the battens when you crash and burn or do fast, hard jibes in big air; You eliminate the need for extra fittings to allow reefing; You preserve your good sail for the more moderate conditions it was designed for. Reefing a sail creates high stress areas and adding reef points and patches adds weight to a sail and can distort the way it responds to wind pressure; This change should be pretty quick and inexpensive to complete since it is so simple. Give this approach some serious consideration.
Posted By: Ed Norris Re: reef my mainsail? - 10/29/02 10:03 PM
Hi, MIke!
What's a mystere 5.0 look like anayway. Is it a boardless competitor to the N5.0 and the H16 & P16? Or something else alltogether?
Just curious.
Posted By: thouse There are a number of options.... - 10/29/02 10:05 PM
I'm discovering there are a number of options, to keep the boat under control and sailing fast, as the wind speed increases.
Certainly too much sail, in faster wind speeds, seems to cause more heeling and less speed.
I'd guess that is because more sail area probably is also producing more drag.. so in very fast wind, less sail (i.e., a reefed main) is probably faster than a main that is being eased to keep the boat on it's feet..
One thing I do is to loosen the main sheet and really harden the jib's halyard. I then, again go back to hardening my main sheet.
I'd guess hardening both, is helping to ensure both sails are as flat as possible, even before one cranks things down to induce mast top bending.
The next thing I'm noticing is in higher wind, I think my sail clothe stretches more than in light air, due to the high with pressures against it. I'd guess this allows the sail's draft to move aft... in the higher wind speeds.
If I ease the jib sheets, just a bit, I can get the jib's head to twist off a bit and open the slot a bit, producing a bit less heel.
I sure you've also discovered the benefits of hardening up your main sail down haul...to help keep the boat sailing fast and reducing heeling.
I also play with the sail slot, opening or closing it, to decrease or increase how much air is going through it... which also affects how much my boat is heeling.
I also notice, when the wind hits gets above certain speeds, I’d rather be watching from the beach, with my sails stowed, the boat secure and the mast down…..
Just some thoughts...
Tom H.
Posted By: ejpoulsen Re: reef my mainsail? - 10/29/02 10:33 PM
Ed,
The Mystere 5.0 is very similar to your N5.0. It's boardless but with symmetric hulls. The built in skeg in the hull is more well defined (like on some of the new boardless Hobies) in terms of the hull shape.
I believe that the Mystere 5.0 comes is an XL version also that includes a spinnaker set up. Never sailed one but have seen them around.
Posted By: jwrobie Re: reef my mainsail? - 10/29/02 11:50 PM
On my Prindle 16, I have one reef point, which is about 1/3 of the way up from the bottom. It's basically three grommets in the sail. I attach the outhaul to the grommet at the leech, which becomes the clew when it is reefed.
I roll up the bottom of the sail and use line through the three grommets to hold the roll together.
So I suspect you wouldn't need much more than a few grommets in your sail.
Jonathan
Posted By: MauganN20 Re: reef my mainsail? - 10/30/02 01:31 AM
I've got a neil pryde H17 sail that has reefing points in it. Although, I don't think I'd ever use them.
I don't even use that sail anymore, just let out the sheet a bit :P
Posted By: catman Re: reef my mainsail? - 10/30/02 01:32 AM
I agree with Mike. Your best bet is to find a dacron sail and have a bit shaved off the roach. I would keep the battens though.
Posted By: PSAILOR Re: reef my mainsail? - 10/30/02 04:42 AM
I tried this on an older H17 I ahd and this is the main problem I ran into:
The sail uses a hook at the top of the mast and I made a short cable, connecting one end to the top of the sail and installing a ring on the other end. This way I could raise the main and hook it lower than intended. When sailing, the force on the sail would cause the comptip to bend slightly creating a force on the luff of the sail at the top that would pull it out of the comptip luff track every time. Lowering the sail is a bitch after this happens, roll the boat on its side and fight it down. I usually had to take the comptip track off of the comptip.
I did come up with a solution that worked well, although I don't know if it is the best of ideas. I picked up a peice of aluminum tubing, I htink 1/2", from the hadware store and cut about a 6" piece. Then used a dremel tool and cut a groove lenthwise in the tube ( a straight cut about 1/8" wide). I slid the tube over the luff rope at the top of the sail and squeezed it on with pliers. It just fit inside the sail guide at the bottom of the mast. The tube fattened up the luff and would not give enought to pull out of the track.
Good luck with your sail!
Posted By: hobiegary Re: reef my mainsail? - 10/30/02 05:48 AM
Ed,
You've seen them around? I sail a Mystere 6.0 in Los Angeles. I have never seen another Mystere.
Just to stay within the subject matter of this thread, I've attached a picture of my reefed main sail.
Posted By: Ed Norris Re: reef my mainsail? - 10/30/02 02:25 PM
Would it work to just attach a couple o' lugs to the wire? Couple bux @ West marine.
Posted By: PSAILOR Re: reef my mainsail? - 10/30/02 02:50 PM
The H17 uses a line that runs down the inside of the mast with a hook at the top of the mast and a ring at the top of the sail, not a wire with lugs on the front of the mast like the Prindle and H16.
Unless I am mis-understanding the lugs you are refering to.
Posted By: Ed Norris Yup, I wasn't clear at all.... - 10/30/02 04:30 PM
Yes, I was unclear. I meant sail track lugs, with little SS straps embedded in nylon cylinders - put one or two above the sail, on the added wire, to hold it parallel to the curving luff track in the comp tip. This way, you've got no aluminum-on-aluminum or worse, aluminum-on-carbon friction and attendent abrasion.
Posted By: samevans Re: Luff track upgrade kit - 10/30/02 05:33 PM
The main hakyard of a Hobie 17 runs inside the mast track next to the sail luff rope, not inside the mast.
There is a luff track upgrade kit which prevents the pullout problem.
It consists of an approx. 12 inch long section of aluminum mast track. The top 12" of the plastic luff track is cut off and the aluminum section is installed in it's place.
It is also usually a good idea to replace the old style thin Hobie 17 hook with a Hobie 20 or 21 hook which is made of much thicker metal.
ok, great, but how much of the sail should be reefed? above or below a batten?
