Posted By: Tornado
Spinnaker Halyard Attachment - 04/05/04 06:16 PM
While I had my Tornado mast down yesterday I inspected the spinnaker halyard fittings. There is an eyelet rivetted about 1m above the shroud attachment point. From this eyelet, a leader line runs down about halfway to the shroud point, then passes under a short bit of Amsteel line and ends at the spin. halyard block. The Amsteel line wraps across the leading edge of the mast and through a hole on each side towards the trailing edge.
The holes are in the "sealed" section of the mast, not the sailtrack, so loads of sealant were on the line knots to attempt to keep things watertight. Due to chafing where the halyard block attaches, the line needed replacing, so I removed it.
What is the purpose of the leader line down from the eyelet and the amsteel line? Is it to distribute loads into a compression loading along the mast section between the eyelet & Amsteel points? If not, why not just put the eyelet where the Amsteel is located and fix the halyard block right there?
Given the problems trying to seal line to the mast holes, is there a better solution for the Amsteel line? I'm thinking rivetting small eyelets in place to attach the line to.
Mike.
Mike.
