Page 1 of 3 1 2 3
Holmenkol SealNGlide #101510
03/25/07 09:37 PM
03/25/07 09:37 PM
MauganN20 Offline OP
Re-posting this from the F18 forums in the hope that someone will stumble upon it and give me a firm answer.
The instructions for applying this are pretty cut-and-dry, but a little on the tedious side. I don't want to use my garage to suspend my spinnaker from AND get the sealant all over my garage floor (I can see the ice-capades already). Macca suggested dunking the spinnaker in the solution in a big bucket. This method of application sounds much easier to deal with than suspending the spinnaker in the air while applying with a sponge.
Also, does this stuff really kill the grass or can I let it dry while on the lawn?
Thanks in advance.
Re: Holmenkol SealNGlide [Re: MauganN20] #101511
03/26/07 12:35 AM
03/26/07 12:35 AM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
I wouldn't recommend doing it in a hotel room the night before a regatta--photo attached--the room may never be the same. <img src="http://www.catsailor.com/forums/images/graemlins/ooo.gif" alt="" />
[I'm talking about the SealNGlide.]
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: Holmenkol SealNGlide [Re: MauganN20] #101512
03/26/07 08:01 AM
03/26/07 08:01 AM
Tornado_ALIVE Offline
Happy Birthday Tornado_ALIVE  Offline
Just used it on the new F18 kite. Goodall buys non-impregnated cloth and applies the stuff to all his kites.
We had our kite painted after purchase, so we applied the stuff bu mixing it in a bucket of water and dunking the kite. Swished it around for a while, retrieved it into the sock and then hoist it. This way the sock and kite gets a coat.
When you hoist it, face the boat dead downwind so as not to have any of the mixture drip onto the boat...... Can make the tramp and decks a wee slippery.
Re: Holmenkol SealNGlide [Re: Tornado_ALIVE] #101513
03/26/07 08:24 AM
03/26/07 08:24 AM
Did it work?
Re: Holmenkol SealNGlide [Re: Jake] #101514
03/26/07 08:52 AM
03/26/07 08:52 AM
yes, quiet well
Re: Holmenkol SealNGlide [Re: Jake] #101515
03/26/07 08:54 AM
03/26/07 08:54 AM
GA
saylor_nacra Offline
GA
Got the stuff from Mike at Layline and did my daughters spin and bag for her Raider 16. I used the hanging method that the direction call for. Worked great except getting to the middle of the spin as it was hanging. When I do my cat spin I plan on laying out some plastic on the ground and appling the stuff then hang it to dry. Jake you asked how it works. Very well in fact my daughters spin would not go into the bag or come out the last 2 feet without help by hand, now it is not a problem. I also like the fact that it does not allow the sail to retain water if it goes for a swim. My sail person had to repair a seam and was going to tape it then sew. Wrong, tape won't stick or anything else. Makes the spin feel like silk. The launch and retrieval sock is made from dacron and it worked great on it also, I turned it inside out and hung it in the air to apply and dry.
Carl
Saylors Spcialties
www.saylorspecialties.com
Re: Holmenkol SealNGlide [Re: saylor_nacra] #101516
03/26/07 05:37 PM
03/26/07 05:37 PM
I tried the dunking method. Lets hope I got adequate coverage.
I'm expecting a letter from the HOA any minute now.
Re: Holmenkol SealNGlide [Re: MauganN20] #101517
03/26/07 07:29 PM
03/26/07 07:29 PM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
I take it you "dunked" it in the tote bin sitting on the driveway?
How much SealNGlide did you have left in the bin? Enough to do another spi' (or two)?
I dry my spi' the same way except I use a basketball hoop for the head end.
USA 777
Re: Holmenkol SealNGlide [Re: tback] #101518
03/26/07 07:52 PM
03/26/07 07:52 PM
Australia
macca Offline
macca  Offline
Australia
if you have the small package you will have enough to do 2 kites using the dunk method, the sponge on method sucks and none of the Tornado guys use it still, just fill up the bucket and throw the kite in.
________________________
http://aus300.blogspot.com
Re: Holmenkol SealNGlide [Re: macca] #101519
03/26/07 08:23 PM
03/26/07 08:23 PM
I didn't fill the bucket completely up. I didn't want to dilute the solution TOO much. In fact, I only filled up the bottom about 3" but I sat in the tote bucket for about 20 minutes making sure every square inch of that spi made contact with the solution. I just took it down off the drier, and to the touch, the cloth doesn't seem all that slick, but when you rub it against itself, man oh man is it slippery.
Had one more "redneck" neighbor stop by in his pickup truck and litterally said... "Son, what in the sam-hell is that?"
oh and yeah, there was plenty to do a second spin.
Re: Holmenkol SealNGlide [Re: MauganN20] #101520
03/26/07 08:55 PM
03/26/07 08:55 PM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
Ah, I understand...I used to live in Hillsborough, NC.
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: Holmenkol SealNGlide [Re: MauganN20] #101521
03/27/07 06:45 AM
03/27/07 06:45 AM
...In fact, I only filled up the bottom about 3" but I sat in the tote bucket for about 20 minutes...
...Had one more "redneck" neighbor stop by in his pickup truck and litterally said... "Son, what in the sam-hell is that?"
He was probably asking about why you were sitting in a bucket filled with goo. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Holmenkol SealNGlide [Re: Jake] #101522
03/27/07 07:16 AM
03/27/07 07:16 AM
Would this work for rope as well?
To reduce friction by applying it to halyards and part of the snufferline? (Obviously just for the parts you dont touch ;-)).
Re: Holmenkol SealNGlide [Re: Tony_F18] #101523
03/27/07 08:08 AM
03/27/07 08:08 AM
luff bolt ropes. I dipped the end of the rolled up mainsailin there to make raising the mast a bit easier
Re: Holmenkol SealNGlide [Re: MauganN20] #101524
03/27/07 12:30 PM
03/27/07 12:30 PM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
Where do you buy this stuff? Anyone have a link to where to purchase?
Mike Hill
Mike Hill
N20 #1005
Re: Holmenkol SealNGlide [Re: Mike Hill] #101525
03/27/07 01:18 PM
03/27/07 01:18 PM
mikekrantz Offline
mikekrantz  Offline
http://www.layline.com/prodinfo.asp?number=HSEAL100
$39.73 / bottle - enough to do at least three F18 spins
Re: Holmenkol SealNGlide [Re: Mike Hill] #101526
03/27/07 01:20 PM
03/27/07 01:20 PM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
Mike Hill
After a little research you can purchase SealNGlide from any Contender Sailcloth Reseller. Many won't have inventory, but they can special order.
I called Layline www.layline.com and they are just now setting up ordering info for this product.
The 100ml kit sells for $39.73 MSRP (plus shipping). Their part number is HSEAL100. They say it'll cover two J24 spi's.
Also found this SealnGlide User manual.
SealnGlide User Manual
USA 777
Re: Holmenkol SealNGlide [Re: tback] #101527
03/27/07 01:22 PM
03/27/07 01:22 PM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
Mike beat me to the punch by 2 minutes.
USA 777
Re: Holmenkol SealNGlide [Re: tback] #101528
03/27/07 05:18 PM
03/27/07 05:18 PM
Won't McLube work just as good?
Dou
Re: Holmenkol SealNGlide [Re: ] #101529
03/27/07 08:27 PM
03/27/07 08:27 PM
Australia
macca Offline
macca  Offline
Australia
Mclube is no comparison to the seal n glide.
Page 1 of 3 1 2 3
Yesterday at 09:43 PM
