| Re: discarding old hulls
[Re: Eric Anderson]
#102123 03/30/07 09:33 AM 03/30/07 09:33 AM |
Posts: 833 St. Louis, MO, | If you want to get the job started quick. Drive over it with a truck a few times. Chainsaws also make quick work. Please wear goggles and a mask though.
Mike Hill
Mike Hill N20 #1005
[Re: Bob Klein]
#102124 03/30/07 09:44 AM 03/30/07 09:44 AM |
Posts: 284 Norfolk, VA | OK, this is how I do it--I have it down to a science.
Take the boat apart and set the hull on it's side on the ground. Then, cut off the bow and stern about 6 inches back. Run your sawsall along the entire length of the hull about 2 inches below the deck lip on both sides. Cut the hull into sections about 2.5 feet long. The benefit of doing it this way is that the hull pieces fit inside eachother and you can get an entire hull in one trash can. I have two of the big city trash cans and can get an entire 14 in both, a 16 takes me an extra can.
Whatever you do, wear a mask and long clothes. DON'T use a chainsaw! I used a chainsaw once with shorts on and got a bunch of fiberglass splinters in my legs. Couldn't sleep for a week.
Don't forget you can recycle the aluminum! I get about 56 cents a pound around here!
Dan Berger Norfolk, VA A Cat USA139 Supercat 15
[Re: Bob Klein]
#102126 03/30/07 11:09 AM 03/30/07 11:09 AM |
Posts: 902 Norman,OK | How cruel, not only destroying a boat but bribing a young broke person.... Need help?
[Re: Seeker]
#102130 03/30/07 01:46 PM 03/30/07 01:46 PM |
Posts: 12,310 South Carolina | The resin is tough on a saw blade...I had a fine jigsaw blade only last through one circular cut around the hull on an old destroyed Nacra.
Jake Kohl | | | Re: discarding old hulls
#102131 03/30/07 01:57 PM 03/30/07 01:57 PM |
Posts: 829 Charleston, SC | The easiest way is a hammer or an axe. It will take no time at all...
Just trust me on this one... <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Trey
345
guests, and 50
