| Re: A Cat advice
[Re: Capt_Cardiac]
#103902 04/16/07 08:26 AM 04/16/07 08:26 AM | Anonymous
| Anonymous
Unregistered | The only guide to modern multihull sailing that I know of is the French sailing dvd’s: http://www.multihulls-world.com/us/livres-262-the-catamaran-sailing-dvd.htmlthere are a few sequences talking with GASHBY and some clips of him on the A-Cat, but I don’t even remember if he gives any real tips. These dvds are applicable to all modern cats, but really not focused on the A-Cat in general. I plan to re-watch these in about 2 months and I can see how much info is given to the A-Cat. There are many A-Caters on this message board; you could probably get most questions answered here. Matt | | | Re: A Cat advice
[Re: ]
#103903 04/17/07 02:23 PM 04/17/07 02:23 PM |
Posts: 396 Annapolis Md. | Try the USACA web site and go thru the blogs. If this doesn't get you anywhere send me a PM and I'll chop out some stuff I've tried to save over time. Ed
Still hazey after all these beers. F-16 Falcon #212
| | | Re: A Cat advice
[Re: Capt_Cardiac]
#103904 04/17/07 02:23 PM 04/17/07 02:23 PM |
Posts: 246 Kiel, Germany | ... I guess you are from the US? Why not having a look at the United States A-Class Catamaran Association at http://www.usaca.info ? Have you sailed an A-cat before? I am owning a F18 and bought now an A-cat in addition. It's a pretty different subject - but lots of fun!
F18: C2 / A-Cat: Minelli
| | | Re: A Cat advice
[Re: Baltic]
#103905 04/17/07 02:38 PM 04/17/07 02:38 PM |
Posts: 396 Annapolis Md. | Baltic. Do you find that the A Cat improves your steering of the F18? Does the F18 help you in any way to sail ther A Cat better? Ed
| | | Re: A Cat advice
[Re: LuckyDuck]
#103906 04/17/07 02:42 PM 04/17/07 02:42 PM |
Posts: 3,116 Annapolis, MD | Rumor has it that you in fact have one of those three sail thing a ma jig's... True??? (but of course you would only use the one sail yo know and that big pink one in the front!)
crac.sailregattas.com
| | | Re: A Cat advice
[Re: Mark Schneider]
#103907 04/17/07 02:46 PM 04/17/07 02:46 PM |
Posts: 396 Annapolis Md. | Sorry for hi-jacking your thread CC.
Mark, you are correct. The money has been put down. I'm hanging out some laundry this year.
| | | Re: A Cat advice
[Re: PTP]
#103910 04/17/07 04:09 PM 04/17/07 04:09 PM | Anonymous
| Anonymous
Unregistered | I never sailed an A cat, but when I came from sloop to uni rig I found you must uncleat 2-3 feet of sheet as you go head to wind. May be different on an A cat because it is so light. 165 lbs vs 340 for my Hobie 17.
Doug | | | Re: A Cat advice
[Re: ]
#103911 04/17/07 04:18 PM 04/17/07 04:18 PM |
Posts: 3,528 Looking for a Job, I got credi... | I never sailed an A cat, but when I came from sloop to uni rig I found you must uncleat 2-3 feet of sheet as you go head to wind. May be different on an A cat because it is so light. 165 lbs vs 340 for my Hobie 17.
Doug Uncleat ? YOu cleat the sail upwind ?
F16 - GBR 553 - SOLD I also talk sport here | | | Re: A Cat advice
[Re: scooby_simon]
#103912 04/17/07 04:28 PM 04/17/07 04:28 PM | Anonymous
| Anonymous
Unregistered | Yes you do, BUT when you sail most heavier uni's, as you are sheet in tight going to weather with speed, As you start the tack, the second you go head to wind you MUST uncleat 2-3 feet of sheet and recleat it as you go to the other side and change the tiller or. Then as you go to a reach heading on new tack, SLOWLY begin sheeting in and heading up. If you DON'T you will go into irons. TRUST me I learned this the hard way. A cat my be different because it is so light?
[Re: ]
#103913 04/17/07 04:48 PM 04/17/07 04:48 PM |
Posts: 3,528 Looking for a Job, I got credi... | Yes you do, BUT when you sail most heavier uni's, as you are sheet in tight going to weather with speed, As you start the tack, the second you go head to wind you MUST uncleat 2-3 feet of sheet and recleat it as you go to the other side and change the tiller or. Then as you go to a reach heading on new tack, SLOWLY begin sheeting in and heading up. If you DON'T you will go into irons. TRUST me I learned this the hard way. A cat my be different because it is so light?
Doug It was more along the lines that you ever cleat the mainsail upwind. The only time I cleat if I don't have a spare hand while I am doing something else or when the the kite goes up <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Agree 100% you need to ease some sheet as you tack as the boat will slow down, and the apparent wind is changing.
[Re: scooby_simon]
#103914 04/17/07 05:35 PM 04/17/07 05:35 PM | Anonymous
| Anonymous
Unregistered | I think you need to cleat in light to about 15, and sail by the telltales and the feel of the boat. Above 15 I agree or if there are a lot of puffs, but then you should be watching the water and be ready for them. In the light stuff I think it is more important to watch the telltales and the feel of the boat and keep movement and healing to a minimum.
Just my 2 cents,
[Re: ]
#103915 04/17/07 06:22 PM 04/17/07 06:22 PM |
Posts: 396 Annapolis Md. | Cleats? You got cleats? Isn't that what ratchet blocks are for?
Seriously, some A Cats dont use cleats, more manly.
| | | Re: A Cat advice
[Re: LuckyDuck]
#103916 04/17/07 06:40 PM 04/17/07 06:40 PM | Anonymous
| Anonymous
Unregistered | Cleats? You got cleats? Isn't that what ratchet blocks are for?
Seriously, some A Cats dont use cleats, more manly. Never been on an A. Guys around here won't let me try one. Would LOVE too!! Doug | | | Re: A Cat advice
[Re: ]
#103917 04/17/07 07:03 PM 04/17/07 07:03 PM |
Posts: 829 Charleston, SC | Doug, you should always be playing the mainsheet when going upwind-don't cleat it. An inch in or an inch out may make a noticable difference. I have my cleat angled so high that it is hard to cleat the sheet, and I only do so when going downwind or tacking. Don't cleat the sheet...
Trey
| | | Re: A Cat advice
[Re: NCSUtrey]
#103918 04/17/07 10:11 PM 04/17/07 10:11 PM |
Posts: 606 League City, TX | Doug, you should always be playing the mainsheet when going upwind-don't cleat it. An inch in or an inch out may make a noticable difference. I have my cleat angled so high that it is hard to cleat the sheet, and I only do so when going downwind or tacking. Don't cleat the sheet... Totally with you on that Trey. Our Marstrom A-Cat has one of those evil tramp centered main sheets that doesn't even let you cleat for the tacks. You have to hold onto the sheet and stay on the wire until well into the tack before swinging in like tarzan and trying to juggle unhooking, steering, rehooking while not letting the main sheet get away from you. Still a bit of a chinese fire drill for me. On the F18 we only cleat the main just before tacking. Chris. | | | Re: A Cat advice
[Re: Capt_Cardiac]
#103919 04/17/07 10:14 PM 04/17/07 10:14 PM |
Posts: 606 League City, TX | I am looking for books/links/etc. that can help with learning A Cat techniques. Has anyone published something like an A Cat bible? I would really appreciate any help you can offer.
CC Advice given to me by some sage A-Catters: practice the wild thing when ever possible to improve your technique, but be more conservative when making the transition from mild to wild when racing - they kept repeating 'a good mild is better than a bad wild'. | | | Re: A Cat advice
[Re: LuckyDuck]
#103920 04/18/07 01:27 AM 04/18/07 01:27 AM |
Posts: 9,582 North-West Europe | Seriously, some A Cats dont use cleats, more manly.
They don't use spins either, more girly ! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Wouter
1 registered members (FredL),
431
guests, and 37
