| Re: Gybing procedure
[Re: Robi]
#104027 04/17/07 11:16 AM 04/17/07 11:16 AM |
Posts: 5,590 Naples, FL | Yes, it does sound as if you're heading too high after a gybe, and then get slammed once your boatspeed takes a dive.
Some try to float the spin across as long as possible with a smooth, carving gybe. As long as the main is reasonably tight, there shouldn't be too much shock when it comes across (if you've got hands, you can swing it over by hand)
Boat speed is king. Whatever you can do to keep your boatspeed up during the gybe will reduce the "knockdown" on the new point of sail.
[Re: PTP]
#104028 04/17/07 01:07 PM 04/17/07 01:07 PM |
Posts: 12,310 South Carolina | Stank is talking gospel. If you are getting hammered on the other side, you're probably not carrying enough boat speed. It goes against the grain of intuition when things are crazy and your sailing downwind...you would think slowing down is wise. However, the apparent wind your boat sees when going slow downwind is greater than the apparent wind it sees if you keep your speed up....the faster you go, the less power you have on the boat. Also make sure that you are not gybing right when a gust is bearing down on you - your speed won't be up to par with the new windspeed.
The crew really must get the spinnaker across cleanly and plan his move down to the detail of where his hands are going while he's moving across...no back-wind'ing the kite here or you're done.
Jake Kohl | | | Re: Gybing procedure
[Re: PTP]
#104032 04/17/07 03:17 PM 04/17/07 03:17 PM |
Posts: 1,203 uk | The idea is to try and gybe when the boat is sailing well, quite often we say 'ah this is going rubbish - lets gybe now' which is a mistake. Its similar to the rule that you only tack when the boat is sailing nicely to windward. after we decide to gybe, its the crew that dictates what happens - the helm steers to his actions.
[Re: PTP]
#104033 04/17/07 05:42 PM 04/17/07 05:42 PM |
Personally, and I do this when singlehandedly gybing my F16, I just arc the boat through the gybe and let everything take care of itself except the spi sheet and handing the tiller across. If you have good speed and a nice sharp arc then the mainsail will come across nicely on its one without any skipper intervention. Even the spi will almost gybe itself then.
So in summary.
-1- pick up speed, plan you turn. -2- start the arc, throw the tiller overboard and track through the arc fast but gentle. -3- Keep the spinnaker drawing till it wants to gybe, while you wait move to centre of the trampoline. -4- let go of the spi sheet and pull the new spi sheet in, no in a wild manner byt quickly just the same, make sure the spi gybes nicely and starts drawing as soon as it can. -5- settle on the boat and pick up speed again. -6- pick the tiller out of the water when all is under control.
Before and during the gybe I still by the tiller bar and not the joystick. You can easily let go of the tiller bar and quickly find it again. You can not with the joystick.
[Re: Wouter]
#104034 04/17/07 05:58 PM 04/17/07 05:58 PM | Anonymous
| Anonymous
Unregistered | Wouter: Thanks I needed something like this. I am going to race the 4.3 in the 20 mile Redfish Reach this weekend at www.tcdyc.com. Will be my first race/use of the snuffer spinnaker. Doug | | | Re: Gybing procedure
[Re: flumpmaster]
#104036 04/18/07 06:42 AM 04/18/07 06:42 AM |
Posts: 12,310 South Carolina | Flump,
Try this for the spinnaker gybe - don't float the spinnaker out as the boat turns but just as the spinnaker starts to backwind, tug the active sheet hard, then go across the boat taking the lazy sheet (the new sheet) with you and reel it in. The tug / pop just before the spinnaker deflates makes the luff fold to the new side without wrapping around the luff - gybes are much faster. The timing of the tug is critical however.
#104037 04/18/07 12:51 PM 04/18/07 12:51 PM |
Posts: 606 League City, TX | Flump,
Try this for the spinnaker gybe - don't float the spinnaker out as the boat turns but just as the spinnaker starts to backwind, tug the active sheet hard, then go across the boat taking the lazy sheet (the new sheet) with you and reel it in. The tug / pop just before the spinnaker deflates makes the luff fold to the new side without wrapping around the luff - gybes are much faster. The timing of the tug is critical however. Thanks for the tip Jake - we'll give it a go later this week. Chris. | | | Re: Gybing procedure
[Re: flumpmaster]
#104038 04/18/07 03:47 PM 04/18/07 03:47 PM |
Posts: 5,590 Naples, FL | Yea, though I walk through the valley of GRP, I shall fear no back strain, for carbon fiber art with thee...
My hot stick and fully battened jib comfort me.
My apparant wind overflows
AMEN.
Now, all rise for the concluding hymn, found in your sailing hymnal:
"what a friend we have in Pentex"
[Re: Wouter]
#104039 04/23/07 08:03 AM 04/23/07 08:03 AM |
Posts: 3,348 | . . . 2- start the arc, throw the tiller overboard and track through the arc fast but gentle. . .
Wouter Failed to do this last Saturday and put the boat over twice! "Smooth" seems to be the key. Anything jerky and I'm swimming. Gettin' pretty good at righting though! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Also, acting on advice from the F16 forum. I've started "hunting" the wind when under spinnaker. Heading up a little, flying the weather hull and driving the boat down with speed. I'm not very good at it yet. Even so, it makes a huge difference.
479
guests, and 23
