Loose numbers #107464
05/16/07 10:19 AM
05/16/07 10:19 AM
Largo, Florida
papayamon2 Offline OP
Largo, Florida
Some of the numbers on my dacron sail are starting to let go around the edges. What is the best glue for sticking them back down?
Thanks!
Kevin
Re: Loose numbers [Re: papayamon2] #107465
05/16/07 10:32 AM
05/16/07 10:32 AM
I'd get some double-sided tape (venture tape). Peel the edge back so that you can get the tape onto the back of the number, then stick the number back onto the sail (obviously trim the tape to the edge of the number if necessary)
Re: Loose numbers [Re: papayamon2] #107466
05/16/07 10:33 AM
05/16/07 10:33 AM
Straight Outta Hell
Boudicca Offline
Boudicca  Offline
Straight Outta Hell
www.sailmakersupply.com
Order stickyback in the color of interest, cut new numbers out of the stickyback, and apply to the sail
This sig would be something witty, but the censors are against that.
Re: Loose numbers [Re: Boudicca] #107467
05/16/07 01:22 PM
05/16/07 01:22 PM
St. Louis, MO
JoeLeonard Offline
JoeLeonard  Offline
St. Louis, MO
Windshear adhesive.
http://www.windance.com/default.asp?windance~shownewitem~MM_4001
best thing I've ever seen for sail repair and I now use it for all kinds of stuff including recently re-gluing a piece of rubber trim on my truck!
Murrays carries it too.
JL N20 # 1041 "Lucille" A-cat USA 44
0 registered members (), 550 guests, and 41 spiders.
