| Prindle rudder problems... #108213 05/23/07 08:09 PM 05/23/07 08:09 PM |
Joined: Jan 2005 Posts: 6,049 Sebring, Florida. Timbo OP
Posts: 6,049 Sebring, Florida. | I took the Escape out today, blowing 25+, took a new kid out and he loved the wire...BUT, every time we got it on a fast, low reach, the rudders would pop up. I think I need new springs but before I buy 4 of them, I figured I would ask if it might be something else. Any ideas? Thanks in advance. Oh, they are the square tip Prindle 18 type rudders. It's hard to steer that beast at high speed with both rudders up! <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
Blade F16 #777
| | | Re: Prindle rudder problems...
[Re: Timbo]
#108215 05/23/07 08:44 PM 05/23/07 08:44 PM |
Posts: 264 Long Island, NY | This is a very common problem with Prindle rudders and is easily fixed. You need to make the rudder lock bolt a couple of turns shorter and make sure it is properly alligned with the pin it engages. Be careful not to overtighten the locking nuts. You can damage the rudder at this critical point. With the boat in a position where the rudders are locked down and can kick up freely (on the beach or dry land) you should have to kick the bottom of the leading edge of the rudder firmly to get them to pop up. In 21 years of owning Prindles I have never seen the cause of rudders popping up at speed to be anything other than rudder lock bolt adjustment. It can be very annoying to have this problem in a windy race. Good luck. Greg
G Gove
Blade #728
Long Island, New Yawk
[Re: F17_129]
#108217 05/23/07 09:10 PM 05/23/07 09:10 PM |
Posts: 6,049 Sebring, Florida. | Thanks, I will try adjusting the lockdown bolt with the V in it. It does have a little more weather helm than I like so maybe that will cure that too?
Blade F16 #777
[Re: blockp]
#108219 05/24/07 08:25 AM 05/24/07 08:25 AM |
Posts: 6,049 Sebring, Florida. | That sounds like it might be the problem. I can hear them click when I lock them down, but I have not looked over the back at them closely to see what is going on. At speed, one always popped up. But yesterday, with the great wind we had and another guy on board, we were able to push it fast enough to get the "good" rudder to pop up too. I will put it up on a trailer and see what is going on. Thanks for the ideas.
Blade F16 #777
[Re: Timbo]
#108220 05/25/07 02:25 AM 05/25/07 02:25 AM |
Posts: 2,844 42.904444 N; 88.008586 W | What Blockp said. It has nothing to do with turning the lock down bolt in or out,- unless when you tighten it, you also raised it up a few millimeters. It only adjusts rudder rake, as someone else said.
1. the lock down bolt has to have an unworn groove in it. 2. the bolt that goes across the casting can't be bent at all, (sometimes, you can turn a bent one downward, this tightens it up) 3. this same bolt, must move freely up and down. Don't tighten the springs too tight against the casting. I've seen a transom ripped out of a P16 at East beach, Galveston, b/c the springs were soo tight, when he hit the beach fast, it wouldn't pop up, and ripped the transom off! 4. after all this is done, then rarely is it the spring tension. New ones or modified ones as has been said then will help this.
Good luck
F-18 Infusion #626- SOLD it!
[Re: Todd_Sails]
#108221 05/25/07 07:44 AM 05/25/07 07:44 AM |
Posts: 6,049 Sebring, Florida. | I looked at them closely yesterday, I think the bolts that go across the casting, that the pin lock to, might be slightly bent or worn at the contact point. I was thinking I could remove all four bolts and swap the good ones for the bent ones. While I have it apart, I can squeeze the springs a bit to tighten them up too, and file the rudder lock down bolts a bit too. Thanks for the help.
Blade F16 #777
[Re: palmwolfe]
#108223 05/25/07 10:38 AM 05/25/07 10:38 AM |
Posts: 6,049 Sebring, Florida. | Jerry, do you mean to tap the V cut lock bolt in the up direction so it will be tighter to the cross bolt? Or are you tapping the cross bolt down?
Blade F16 #777
3,195
guests, and 376
