Page 1 of 3 1 2 3
Upwind speed (Question) #108881
06/02/07 06:03 AM
06/02/07 06:03 AM
Mark P Offline OP
Mark P  Offline OP
An A Class is 200mm (8") narrower, 300mm (12") longer, roughly 30kg (66lbs) lighter and mainsail area 2.25m smaller although the mast is 600m (24") longer. Why is it that a Cat rigged F16 is roughly 10% slower upwind?
I ask this question as last week it was astonishing at the speed at which an 'A' was passing me upwind. There was flat water and 10mph of wind speed we were both on the wire and the 'A' was capable of pointing a few degrees higher at times and yet still power past.
We are both decent Club Sailors with over 12yrs Cat sailing experience between us and I'm possibly 5kg lighter at 64-65kgs.
If anybody could break these stats down and come up with a reasonable conclusion/ solution I would be most grateful, or is it purely down to the different aspect ratios of the mainsails.
MP*MULTIHULLS
Re: Upwind speed (Question) [Re: Mark P] #108882
06/02/07 10:52 AM
06/02/07 10:52 AM
Knokke-Heist - Belgium
Gilo Offline
Gilo  Offline
Mark,
Were you sailing with the Jib? Because I think it's normal you point higher with just the mainsail.
Gill
Re: Upwind speed (Question) [Re: Gilo] #108883
06/02/07 01:19 PM
06/02/07 01:19 PM
Mark P Offline OP
Mark P  Offline OP
No jib and my main is 12 months older than the 'A's, both Cats are under 1 year old.
MP*MULTIHULLS
Re: Upwind speed (Question) [Re: Mark P] #108884
06/02/07 02:24 PM
06/02/07 02:24 PM
Mark,
Length is king sailing up wind. Also, the A is 25% lighter and in that sort of wind the A will be very much in the ideal groove/setting. Also remember you have a Spi halyard and associated gubbins causing more windage uphill.
Re: Upwind speed (Question) [Re: Mark P] #108885
06/02/07 03:05 PM
06/02/07 03:05 PM
USA
NaCl H20 Offline
NaCl H20  Offline
USA
Mark,
Get the Texel rating spreadsheets at:
http://www.watersportverbond.nl/content.asp?me_id=468%20
Download: Complete list with all details-04-0-2-2007.zip
Download: Easy calculator-04-02-2007.xls
Put the F16 (1) measurements into the Easy Calculator, then change the numbers 1 at a time to the "A" measurements.
It's kinda fun. It'll give you a rough idea where the "A"s gains are coming from.
Hint - change the weight first <img src="http://www.catsailor.com/forums/images/graemlins/ooo.gif" alt="" />
e
Re: Upwind speed (Question) [Re: NaCl H20] #108886
06/03/07 01:47 AM
06/03/07 01:47 AM
Mark P Offline OP
Mark P  Offline OP
'Sailwave' also has a Calculator facility. However, I'm not totally convinced about the weight being a significant factor due to the F18 argument. I'm sailing the F16 all up at approx 170kgs (374lbs) F18's are likely to be in the region of 330kgs (726lbs). Therefore I'm roughly 50% lighter but I certainly don't pass a F18 upwind as quick as an 'A' passes me. Yes, the F18 has a lot more sail area and longer water line but realistically they are slightly faster boats in all but the lightest of wind conditions (upwind).
MP*MULTIHULLS
Re: Upwind speed (Question) [Re: Mark P] #108887
06/03/07 04:14 AM
06/03/07 04:14 AM
Mark, Agree with that, but they also have 2 on the wire and so have more righting moment(RM) and so can generate more power and more speed.
Re: Upwind speed (Question) [Re: Mark P] #108888
06/03/07 04:45 AM
06/03/07 04:45 AM
Mark,
Your data is not correct.
An A-class cat is actually.
200 mm narrower
490 mm longer (and not 300 mm)
35 kg lighter (on average)
1.20 sq. mtr. smaller in its mainsail area (and not 2.25 sq. mtr.)
600 mm shorter in mast length AND 700 mm longer in mainsail luff length.
Now that is a very interesting question.
Personally I think we must recognize that the A-class rig and platform has been developped over a long time and it is developped to be a very good upwind performers The F16's haven't had nearly the same amount of development in their rigs yet. Also we are losing some upwind performance because of the spinnaker package and the spi halyard running up the mast. I saw a good trick on a singlehanded F16 recently. The owner had moved the spi halyard so that it run up along the forestay instead of along side the mast. This will most definately improve flow in that very important spot, the mast. In the latest club race we had he nailed us all upwind, working up between 2.5 and 6 minutes lead. He lost some on the downwind legs, but he is still new to spi sailing.
Additionally our F16 hulls are a (good) compromise between diverging requirements. Afterall the A-cat hulls are designed to carry ONLY a single skipper while our F16 hulls are also designed a crew of 150 kg well and be a forgiving hullshape when crashing through waves under a spinnaker. Additionally our hulls are made to handle being a platform that is short and wide instead of being long and narrow. The penalty is drag. From a performance perspective, probabbly the best singlehander setup is a 5.5 mtr long by 2.75 mtr wide platform (18 feet by 9 feet) that weights under 100 kg, carries a 15 sq. mtr. mainsail on a 9 mtr carbon mast and a F16 size spinnaker. But that was not something we could get going in a commercial viable way.
In the end of the day the whoel A-class concept is optimized for a single purpose while the F16's necessarily are a compromise between 1-up and 2-up sailing and all the little aspects in which we are suboptimal add up. Especially on upwind legs as here efficiency is so important in the way of pointing without losing speed.
But also we must never forget that weight is a large factor in performance. Afterall, each time you travel ahead by a boatlength you will have pushed the overall weight in water volume out of the way. The A-cats just push 150/180 = 83.3 % => 17 % less weight aside. The F16's have 1.09 % more sailarea and "83.3 % times 1.09 %" equals 90.5 % in favour for the A-cat. So here they have about 10 % advantage. Naturally this is a rather crude calculation but suprisingly enough it comes really close your on the water experience. Sometimes things are that simple.
If you as a human being had to dig a hole that is 10 % larger then that of your neighbour then chances are that you'll take 10 % longer to do so.
But of course you should win all that back, AND MORE, on the downwind leg after deploying your spinnaker !
That is unless the A-cat sailors insist on running triangular courses of very modest length with alot of laps and you cave into that ! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Upwind speed (Question) [Re: Wouter] #108889
06/03/07 04:54 AM
06/03/07 04:54 AM
any details on the spi halyard along the jib luff route? That is mighty interesting!
Re: Upwind speed (Question) [Re: Rolf_Nilsen] #108890
06/03/07 04:57 AM
06/03/07 04:57 AM
Won't you (potentially) overload the bow areas running all that tension down to the forestay first ?
Interesting evolution I'd also be interested in hearing more about.
Re: Upwind speed (Question) [Re: Rolf_Nilsen] #108891
06/03/07 05:05 AM
06/03/07 05:05 AM
Everybody
It is, but I'm already on the edge of what I can say in public. This guy wants to make an impression on the upcoming F16 Global Challenge and has tweaked out his boat to do exactly that. I think it is most wise to not elaborate on this setup till after the Global Challenge so he can make maximal use of his "invention". Afterward is a different matter of course !
But basically what I wanted to say with it is that F16 sailors still have some way to go to optimize the boats. And we should all be getting into that and progress the F16 performance just as the A-cat sailors have done with their boats (and are still doing).
Re: Upwind speed (Question) [Re: Wouter] #108892
06/03/07 05:12 AM
06/03/07 05:12 AM
Everybody
Oh come on Wouter, if it's been in the dinghy park, it's public knowledge. I assume he (I assume it's a he) has just routed the halyard partly down the mast, then thru a block at the hounds, down the forestay to another block on the foestay by the podder and then to the cleat on the font beam.
Re: Upwind speed (Question) [Re: scooby_simon] #108893
06/03/07 05:16 AM
06/03/07 05:16 AM
Humm ! This is getting a little bit out of hand. I hope he will not be irritate at me for spilling the beans.
No, because any tension put on the spi halyard in this situation will lower the tension in the forestay by the same amount. In effect, the load on the bows will remain unaffected. That is just the beauty of it.
But I won't elaborate any further at this time beyond the point that I think it is a very interesting development myself and that I'm quite thrilled to see the EU importer of F16's boats engage in such efforts to evolve the F16 design. (And there are other idea's being tested as well)
How many importers/agents do that ?
I think we can consider ourselfs lucky with F16 agents like that.
If any of you want to scoop on things like this on the shortest possible time frame then I guess you guys just have to come over for the F16 Global Challenge in 10 weeks time !
And be sure to stay on for the long distance race (REM-race) that directly follows our week of bouy racing. It will be great to see a fleet of F16's participating in this 100+ boat race. There will be a very strong F18 fleet there for this distance race and if we can get 15-20 F16's participating then that would be absolutely perfect.
Re: Upwind speed (Question) [Re: Wouter] #108894
06/03/07 05:21 AM
06/03/07 05:21 AM
Eh
Unloading the forestay how, if the Spi halyard is in some way replacing the forestay when the kite is up (I assume the forestay actually just sags a bit) then the load is INCREASING on the bows as the distance between the hounds (top end of the forestay) and the lower fixing (on the bows) is de-creasing, thus load is increasing.
You have totally lost me here Wouter.
Re: Upwind speed (Question) [Re: scooby_simon] #108895
06/03/07 05:28 AM
06/03/07 05:28 AM
Dear scooby,
There is an agreement in place that development and testing is done in a protected environment. This way the involved parties feel free to discuss these things in private among themselfs. Garanteeing this free discussion is important in advancing the F16 design. And the driving force under these development projects is achieving some gain in performance over competitors, even when only temporary. Such factors need to be nurtured, because without it sailors are less likely to do all the hard work and investments.
It is a balancing act but eventually we all benefit in the long run as nothing can be kept secret for long periods anyway.
Additionally, you guys can all try to work out a system yourself. Maybe we find the perfect setup afterwards when comparing all individual systems after the Global Challenge !
I know that I'm going to try and work out my own setup. I actually have to as my cleat/halyard situation is different from his requiring me to adjust the setup.
Good luck you all,
Re: Upwind speed (Question) [Re: Wouter] #108896
06/03/07 05:34 AM
06/03/07 05:34 AM
I Understand that. But can you expalin how by adding extra load on the front of the boat you reduce the load at the front ?
Eh
Re: Upwind speed (Question) [Re: scooby_simon] #108897
06/03/07 06:30 PM
06/03/07 06:30 PM
ncik Offline
ncik  Offline
Maybe a shock-cord take-up system is employed which pulls the loose halyard to the bridle, but when the halyard is tensioned it runs its normal course straight up the mast.
If it were running from beam to bridle and up the forestay the loads would be a bit strange...you'd think it would load up the bridle and unload the forestay, but then again, you are running downwind so the forestay/bridle isn't heavily loaded anyway.
Re: Upwind speed (Question) [Re: Wouter] #108898
06/04/07 02:49 AM
06/04/07 02:49 AM
Mark P Offline OP
Mark P  Offline OP
If this person is that worried about the drag caused by a spi halyard running down the mast I think they should see a Doctor. As for keeping this new rigging technique 'Top Secret' thats not really F16. But it can't be that advantageous otherwise the Olympic Tornado's crews would all be doing it.
As for developments in rigging and upwind sailing techniques that was the purpose of this thread, people could be open with information which would in turn help the Class to be more competitive, and for me help understand the differences in power to weight ratios of my nearest competitors. I guess I'll have to wait 10 weeks now!!!
MP*MULTIHULLS
Re: Upwind speed (Question) [Re: Mark P] #108899
06/04/07 03:21 AM
06/04/07 03:21 AM
Guys,
This approach to the spin halyard routing is not new. There were Shearwaters with spin halyards running down the forestay 20 odd years ago. The Shearwater was one of the very earliest adopters of the wing mast and some owners tried to improve the airflow by re-routing their jib and spin halyards.
There are still Shearwaters today with external spin halyards running down the mast so I guess that even after all this time the jury's still out on the benefits?
One of the best solutions I've seen is to go internal and exit at the front of the mast above the gooseneck. The halyard then drops down to a spring loaded block at the base of the mast, runs forward, round a turning block and then back to a spinlock on the beam. From there it's the usual route back to a block/ring and then forward through the chute.
Re: Upwind speed (Question) [Re: Mark P] #108900
06/04/07 03:22 AM
06/04/07 03:22 AM
ncik Offline
ncik  Offline
This is a possible line of reasoning for the conditions you described.
The lower weight of an A-class means less hull resistance (in general) and lower righting moment (in general).
Lower resistance directly influences speed at all points of sail.
Lower weight may also reduce their pitch radius of gyration (how easy/hard it is to rotate the boat in pitching) which has been shown to improve the performance of boats, particularly upwind.
Lower righting moment means that they can fly a hull with less pressure in the rig, which means they don't need as much draft in the sail (the sail is flatter in general), flatter sails have less drag and can also point higher. Both increase VMG.
A-classes also have less "stuff" dangling about in the wind creating drag. Items like spinnaker poles, chutes, bigger hulls and extra crew all increase the windage (drag from wind) of the boat, which is slower.
A-classes are lean, finely tuned, upwind dominating machines. In their condition, there is not much on the water that can touch them.
Page 1 of 3 1 2 3
0 registered members (), 309 guests, and 40 spiders.
