Re: broke my spin pole! [Re: WindyHillF20] #111091
08/14/07 10:26 AM
08/14/07 10:26 AM
So, here I am. Have acquired 2 pieces of extrusion and neither work. I am seriously considering turning this in on insurance as a mid-pole system is the only available at roughly $600. I would prefer to stay with the endpole system but apparently my current pole is european spec and not available in the states. Hobie cannot or will not give me measurements on their current poles so I have no idea if they will work. Any other suggestions? I have purchased a nearly new 3 point chute with a fiberglass pole and homemade snuffer system. Just not wild about the fiberglass windsurfer pole, would prefer aluminum. Fiberglass pole is light, not sure about its strength.
Could you measure the diameter of the snuffer?
Re: broke my spin pole! [Re: ] #111092
08/14/07 10:44 AM
08/14/07 10:44 AM
Graham, NC
WindyHillF20 Offline OP
Graham, NC
Yes, but what will that provide me? Its an aluminum circle?
Re: broke my spin pole! [Re: WindyHillF20] #111093
08/14/07 12:12 PM
08/14/07 12:12 PM
Yea I have to replace mine too. Don't feel alone. PITA.
Doug
Re: broke my spin pole! [Re: WindyHillF20] #111094
08/14/07 12:23 PM
08/14/07 12:23 PM
Do you have pics of the fiberglass pole? It should be ok to use. I used one on my 6.0 when I added a spin and the very experienced sailor I bought it from said he trusted it more than the aluminum poles.
Can you elaborate on why the aluminum extrusions won't work?
Re: broke my spin pole! [Re: WindyHillF20] #111095
08/14/07 12:45 PM
08/14/07 12:45 PM
srm Offline
srm  Offline
Is it a 100% fiberglass windsurfer mast, or does it have carbon in it too? If it's 100% fiberglass, it may be a total piece of crap (or it could be half decent, but it will be pretty heavy). If it's got carbon in it (50% or more would be real good), it's probably stronger than the old aluminum pole - there's a reason that aluminum windsurfing masts are not made out of aluminum any more.
There may be a sticker at the base of the mast which tells you the carbon %, or if the mast is black, that's usually a pretty good indicator.
sm
Re: broke my spin pole! [Re: PTP] #111096
08/14/07 01:11 PM
08/14/07 01:11 PM
Graham, NC
Graham, NC
The aluminum pieces I need are european dimensions, 40mm OD 34.8mm ID. Larger than 1 1/5" which is common. One piece was free, found a manufacturer of tubing that sent me a scrap ( 9'), they even anodized it for me. I told them that the ID was critical and they sent me a piece with OD close to my ID spec, whatever. The other piece came from online metals, they guarantee OD specs but not ID, this piece is approx 2 thousandths too small and not anodized. I could sand the inserts or hone the tube but that would create a weaker joint. The fiberglass pole I have has nothing on it, it is very light so some carbon is likely. It tapers to the tip and is wound by looking at the glass lines. I assume it would work fine but not sure. Don't want to deal with another broken pole in the surf, very risky at best!
Re: broke my spin pole! [Re: WindyHillF20] #111097
08/14/07 01:15 PM
08/14/07 01:15 PM
if it is close, I would sand the inserts. WHat insert are you talking about? The part that attaches the pole to the front beam? If that is it I think it will handle the load if you had to shave off a little.
Re: broke my spin pole! [Re: WindyHillF20] #111098
08/14/07 03:29 PM
08/14/07 03:29 PM
Dunedin Causeway, FL
David Parker Offline
Contact Jill Nickerson of Fun in the Sun (or Red Gear Racing). She and Robbie Daniel are the USA Capricorn dealer (as well as other AHPC products). She recently quoted me a great price on a new Capricorn spin rig including the pole, ring, sock, halyard, and head-to-head block (for the one-piece design). The price for the entire rig, ready to go, was less than the $600 you mentioned. That price could have been low due to my good looks so I don't want to make any promises. However, it is a great mid-pole solution of a boat known for great fit and finish and Jill and Robbie are first class dealers.
Write to Jill A Nickerson, funinthesun(at)juno.com
Re: broke my spin pole! [Re: PTP] #111099
08/15/07 10:42 AM
08/15/07 10:42 AM
Graham, NC
Graham, NC
I have Dave Lennards' old tiger pole. The hoop sleeves into the main pole and the attachment end sleeves on as well. He even sent a sleeved on replacement for the hoop so the pole can be used for deck launching instead of snuffing. So, the pole is really 3 pieces. I broke the center section which is 8'6" long. Both sleeve pieces were loose fitted and had been taped to prevent any slop. The extrusion I just received is approx 2/1000ths too small inside. The sleeves are roughly 18", so they do extend quite a ways inside the center section. I'm concerned that if I mill either piece it won't be strong enough. Would it be best to mill the inserts or the replacement tube?
0 registered members (), 290 guests, and 28 spiders.
