Re: Gargantuan mast-How to get it pointing to the sky? [Re: fin.] #111539
07/12/07 12:52 PM
07/12/07 12:52 PM
Dunedin Causeway, FL
David Parker Offline
I may just start an "idiot" thread composed of all the screw-ups I've made.
Pete, I've got another, well, several, "idiot" stories all ready for YOUR thread. I'll wait for you to start it so your name is forever listed as the origianl author, not mine. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Gargantuan mast-How to get it pointing to the sky? [Re: David Parker] #111540
07/12/07 05:39 PM
07/12/07 05:39 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
My brain did not take in the written electricty warnings so I made my own which is a big red thunderbolt an a white field. I stuck that over the written one and now I always notice it as the mast goes up or if I am pulling/pushing the boat.
Re: Gargantuan mast-How to get it pointing to the [Re: TEAMVMG] #111541
07/12/07 06:31 PM
07/12/07 06:31 PM
Bellville, Texas
Joee Offline OP
Joee  Offline OP
Bellville, Texas
I honestly hadn't thought of that...I'll have to try putting the boat off the front end of the trailer so it starts out on an angle, removing the need to hop up to the tramp.
In fact, I'll be trying a quite a few of these ideas. I'll keep ya'll posted as to the final outcome of my preferred mast raising method.
Re: Gargantuan mast-How to get it pointing to the sky? [Re: Joee] #111542
07/12/07 07:22 PM
07/12/07 07:22 PM
PA, Bucks
N
Nieuwkerk Offline
Nieuwkerk  Offline
N
PA, Bucks
Joe,
I have a N6.0 and frequently sail alone and here's what I did.
I purchased a reversable electric winch with an automatic brake. Using 2 blocks (See attached picture) I attached the clip to the forestay.
I then attach the mast and go the the tip of the mast and using a lanyard (connect to the winch) begin to raise the mast. Your only role is to keep it from swaying. As it raising, I walk to the tramp and climb on. Once I'm on, I continue to raise it until its all the way up.
To lower the mast, just connect to the forestay, and while on the tramp, lower it all the way. There is no need to get off.
As its been pointed out, its very important to to tie the boat to the trailer. Also, I attached a chain from the top of the mast cradle to the front of the trailer to strengthen the pole.
It works like a charm, requires no strength and is easy on the back !
Bill
Re: Gargantuan mast-How to get it pointing to the sky? [Re: Nieuwkerk] #111543
07/12/07 07:23 PM
07/12/07 07:23 PM
PA, Bucks
N
Nieuwkerk Offline
Nieuwkerk  Offline
N
PA, Bucks
Here's another picture
Re: Gargantuan mast-How to get it pointing to the sky? [Re: Joee] #111544
07/12/07 07:25 PM
07/12/07 07:25 PM
PA, Bucks
N
Nieuwkerk Offline
Nieuwkerk  Offline
N
PA, Bucks
and heres another picture
Just follow the sequence 1 [Re: Joee] #111545
07/12/07 07:54 PM
07/12/07 07:54 PM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
See photo #1/3 attached
Luiz
Re: Just follow the sequence 2 [Re: Luiz] #111546
07/12/07 07:55 PM
07/12/07 07:55 PM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
See photo #2 attached
Luiz
Re: Just follow the sequence 3 [Re: Luiz] #111547
07/12/07 07:56 PM
07/12/07 07:56 PM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
See photo #3 attached
Luiz
Re: Just follow the sequence 3 [Re: Luiz] #111548
07/12/07 08:35 PM
07/12/07 08:35 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Luiz, nice system. I like the bridle attached to the beach wheels setup.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Just follow the sequence 3 [Re: hobie1616] #111549
07/12/07 08:47 PM
07/12/07 08:47 PM
Thats off of the Aquarias website. Something that big needs to be complicated.
Re: Just follow the sequence 3 [Re: Karl_Brogger] #111550
07/15/07 08:09 PM
07/15/07 08:09 PM
Bellville, Texas
Joee Offline OP
Joee  Offline OP
Bellville, Texas
Hahaha! Yes! I've just got the mast up. My illustrious father just HAD to weld up a solution for me.
It's a simple A-frame. Two trapeze wires and the jib halyard are attached, via clips, to the A-frame. The A frame has a hand winch on it that is used to pull the frame from Vertical forward, pulling the mast along with it.
Here's some photos. They'll probably be the worst you'll see in awhile because of all the loose lines and so-forth that are spread across the boat.
0 registered members (), 588 guests, and 22 spiders.
