I20 euro mainsail #112860
07/27/07 02:51 PM
07/27/07 02:51 PM
TampaN20 Offline OP
TampaN20  Offline OP
Anyone know what the size difference is between the euro main and NA main, and where can you still get a euro sail, I've heard it's like 15 sqft smaller and might be better for sailing light (320lbs)
Re: I20 euro mainsail [Re: TampaN20] #112861
07/27/07 03:38 PM
07/27/07 03:38 PM
Note that the Nacra class rules were recently changed to read that only the North American sail plan was legal for racing in North America.
Re: I20 euro mainsail [Re: TampaN20] #112862
07/28/07 07:28 AM
07/28/07 07:28 AM
One of the best sources on European boat specs is the Texel handicap rating measurement form.
http://www.watersportverbond.nl/data/837_numdet_27-5-2007.pdf
This is the PDF version but you can also download the excel version and see the actually measurement taken. It is a very rich source of information and a headache for builders. Afterall the REAL specs are publicized after being measured putting truth to claims.
For the Inter-20 sailing in the EU we find.
nacra inter 20 - 18,00 sq mtr. with 9,08 mtr luff
nacra 20 medium - 18,56 sq mtr. with 9,00 mtr luff
nacra 20 large - 19,18 sq mtr. with 9,00 mtr luff
It think the nacra 20 medium was a try out and the nacra 30 large is the current "popular" US rig that is being used in the EU now. OF course the "nacra inter-20" was the old size and formula 20 compliant.
15 sq ft = 1.39 sq. mtr.
and I'm convinced it is better for sailing light at 320 lbs (145 kg) in anything but sub 8 knot winds.
Re: I20 euro mainsail [Re: Wouter] #112863
07/28/07 04:03 PM
07/28/07 04:03 PM
TampaN20 Offline OP
TampaN20  Offline OP
Wouter thanks for that information, that puts the NA sail at 206.98 and the EU sail at 194.24, a 12.74 difference. I'm guessing you can't get the EU main anymore with everyone using the NA one now.
I wonder how an F18 sail would work, if you used 2 feet of vectran at the top to make up for the 2 foot difference in mast size.
Re: I20 euro mainsail [Re: TampaN20] #112864
07/28/07 04:34 PM
07/28/07 04:34 PM
Yes, so they want us to believe.
One can always try but I don't expect much from it.
Re: I20 euro mainsail [Re: Wouter] #112865
07/30/07 09:20 AM
07/30/07 09:20 AM
Solutions:
- Corrector weight(s)
- Downhaul the snot out of the NA sail. They go flat pretty dang well.
- max spreader rake and diamond tension (check the rig guides)
- traveler down in heavy stuff
Re: I20 euro mainsail [Re: waterbug_wpb] #112866
07/30/07 10:26 AM
07/30/07 10:26 AM
Charleston, SC
NCSUtrey Offline
NCSUtrey  Offline
Charleston, SC
The Euro Nacra 20 (one-design) sail (same size as ours here) is cut quite a bit flatter than ours. I am assuming this is because of the higher average windspeed in Europe. I found the sail to be lacking in light and shifty winds, but it was much better in higher winds. If you are just looking for a high-wind sail to throw up for fun sailing, you might want to check one out, but it will not be class legal in the US.
Trey
Re: I20 euro mainsail [Re: waterbug_wpb] #112867
07/30/07 10:35 AM
07/30/07 10:35 AM
Solutions:
2nd 3rd and 4th points are all good.
I'd guess most people this side of the pond would be loving to be sailing at this weight. I fight to stay as light as I can - failing at the moment <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />
0 registered members (), 270 guests, and 43 spiders.
