hi all,
gree thanks for your 5.2 advice, esp about the the early 80's nacra downhaul system needing to be upgraded for modern useage, (couldn't imagine letting go of tiller and leaving sheets cleated during big gusts while i used 2 hands on that weak pull down system every time i needed to de-power)
TEAMVMG, i keep rereading the 5.2 tuning guide at
www.goosemarine.com.au and understanding it more but these bits i would still appreciate input about
1. Hull Alignment.........35mm toe out.
on short track auto-cross for cars, toe out is used to help initiate turns at the expense of straight line stability
what's the purpose of toe-out for cat hulls???
3. Dagger Boards.........Parallel to centre line of hulls.
like you have a choice???
4. Mast settings........... Spreader Rake: 5 mm behind mast track.
ok easy, my 5.2 has the older spreaders that have no rake and are not adjustable
5. Diamond wire tension.............Tight
Tighten just enough so as not to induce any prebend.
This will allow Cunningham to work to its full extreme to
induce bend as required.
does this mean the mast becomes sort of like a batten and must pop across during tacks and jibes???
6. Mast Rake...................Centre to rear off hatch.
translates as, mast straight up, (at 90 degrees to tramp) or angled rearward slightly so that top of mast appears inline with the forward inspection hatches on the hulls when viewed from the side???
7. Boat Trim.…………...When sailing to windward and reaching in flat water have leeward Bow driving in to about 50mm before
deck.
whole downwind hull is underwater until 50mm before main beam!!!?
sorry for the long list of Q's but as it was written as a race tuning guide for experienced cat sailors newbies like me can get a bit lost...like all these references to "wild thing"
eric e
