| What are these things? #117879 09/23/07 08:49 PM 09/23/07 08:49 PM |
Joined: Sep 2007 Posts: 224 Cincinnati, Ohio Tri_X_Troll OP
Posts: 224 Cincinnati, Ohio | First off, I appoligize for my ignorance. There is a metal basket mounted on the front of my boat, and I have no idea what it is for. It's mounted to the front of the dolphin striker? ![[Linked Image]](http://i19.photobucket.com/albums/b161/Tri_X_Troll/Boat/DSC01373.jpg) There is also a shock cord that runs from the dolphin strikcer to a pulley at the stern of the boat, what is this for? Best illustrated in this picture taken from the stern looking forward. ![[Linked Image]](http://i19.photobucket.com/albums/b161/Tri_X_Troll/Boat/DSC01366.jpg)
Ryan - H16
I prefer to go sailing because baseball, football, tennis, and golf only require 1 ball!
| | | Re: What are these things?
[Re: lluistar]
#117881 09/24/07 12:47 AM 09/24/07 12:47 AM | Anonymous
| Anonymous
Unregistered | the bracket is to hold a battery should you choose to mount a trolling motor to your cat. the blue line is a righting line for when you capsize. | | | Re: What are these things?
[Re: mmiller]
#117885 09/24/07 01:24 PM 09/24/07 01:24 PM |
Posts: 117 Atlanta, GA | If the cooler rack causes the jib sheets to hang up, what the best way to carry a cooler?
Thanks, Kent
Kent 1988 H16
[Re: KentHobie]
#117886 09/24/07 02:17 PM 09/24/07 02:17 PM |
Posts: 5,582 “an island in the Pacifi... | If the cooler rack causes the jib sheets to hang up, what the best way to carry a cooler?
Thanks, Kent You can use the rack if you run a bungee from the top of it to the forestay. US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: What are these things?
[Re: KentHobie]
#117887 09/24/07 02:59 PM 09/24/07 02:59 PM |
Joined: Jun 2007 Posts: 100 Lindale, Texas Inland freshwa... Wallybear
Posts: 100 Lindale, Texas Inland freshwa... | If the cooler rack causes the jib sheets to hang up, what the best way to carry a cooler? Kent, I have a rack for an ice chest that clamps onto the front crossbar near the mast step. It does not interfere with the jib even with the cooler in it. I actually thought the pic was a battery holder for a trolling motor as well. I saw a battery holder that looked very similar to it in a catalog somewhere with the trolling motor mounted under the front crossbar but I am sure Matt and Gary know what it is more so than myself.
[Re: Wallybear]
#117888 09/24/07 04:22 PM 09/24/07 04:22 PM |
Posts: 117 Atlanta, GA | [I have a rack for an ice chest that clamps onto the front crossbar near the mast step. It does not interfere with the jib even with the cooler in it.] Great. Any idea on where I can find one? Thanks!
Kent 1988 H16
[Re: KentHobie]
#117889 09/25/07 01:28 PM 09/25/07 01:28 PM |
Posts: 100 Lindale, Texas Inland freshwa... | [I have a rack for an ice chest that clamps onto the front crossbar near the mast step. It does not interfere with the jib even with the cooler in it.] Great. Any idea on where I can find one? Thanks! Kent, The one I have came with the cat when I bought it. I have no idea where it originally came from. I checked the web and was unable to locate one. My rack looks very similar if not not exactly like the photo above except it has a clamping type bracket for the front crossbar. Makes it easy to yank off if you don't want it on the boat. I originally thought the one in the pic above might have been a battery box because of its mounting position. Hobie sells one for batteries in the catalog that mounts under the front crossbar. It is obvious that a battery would not stay in the one above without a bottom and sides. DUH!! | | | Re: What are these things?
[Re: Wallybear]
#117890 09/25/07 04:37 PM 09/25/07 04:37 PM |
Posts: 117 Atlanta, GA | My rack looks very similar if not not exactly like the photo above except it has a clamping type bracket for the front crossbar. Makes it easy to yank off if you don't want it on the boat. Thanks, I've been looking for one for a while. I'll keep looking. May have to find another way to put a cooler on the boat.
Kent 1988 H16
567
guests, and 43
