| Re: Spinlock to cam cleat
[Re: Tony_F18]
#121181 10/27/07 06:56 PM 10/27/07 06:56 PM |
Posts: 3,528 Looking for a Job, I got credi... | Is is mounted on the frontbeam or on the mast? IMHO the advantage when sailing solo is that the Spinlock requires a lot less power to uncleat. What kind of rope are you using? I've never had a problem un-cleating my cleat - mounted on the front beam BTW.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Spinlock to cam cleat
[Re: Robi]
#121183 10/27/07 10:35 PM 10/27/07 10:35 PM |
Posts: 6,049 Sebring, Florida. | Robi, a Spinlock will re-cleat itself on a douse, if you put any resistance on the halyard, such as when you sit on it. That cannot happen on a cam-cleat. I have broken several spinlocks, I won't use them. I see no advantage to them, only problems when they fail or re-cleat on a douse.
Blade F16 #777
[Re: Robi]
#121186 10/28/07 08:36 AM 10/28/07 08:36 AM |
Posts: 6,049 Sebring, Florida. | I really like mine on the mast with a separate tack line. I can reach both from mid tramp when hoisting, and I can douse from the off side (port side) without having to go forward. The only time I have a problem is if I have to set it on port tack, I can't do that with the tack and halyard on the starboard side, but I haven't had to yet.
Blade F16 #777
[Re: Robi]
#121188 10/28/07 09:43 AM 10/28/07 09:43 AM |
Posts: 6,049 Sebring, Florida. | To do that, you would have to rig it like yours, with the single cleat (spinlock or cam) on the front beam somewhere. I think it's slower to hoist as you have to pull 3 feet at a time, hand over hand and the halyard passes through two extra blocks which adds drag (effort) to raise it.
With my cleat on the mast, I can use my full 195lbs. to pull down on the halyard, I can raise the spin in about 3 good long pulls and cleat it. It only takes me one long pull on the tack line (first) to set that. It is a little slower (half a second?) on the douse as I have to stop snuffing for a second to uncleat the tack line when the spin is 2/3 in the sock, then go back to snuffing. On the hoist, I pull the tack out before the halyard. On the douse, I release the tack line last. This prevents the spin getting under the bow.
Blade F16 #777
[Re: davefarmer]
#121190 10/28/07 10:11 PM 10/28/07 10:11 PM |
Posts: 6,049 Sebring, Florida. | Dave, the short answer is, no. No digital camera. My boat has the standard Blade setup, there is a picture of the under tramp tack line cleat in the other post. The halyard is a simple cleat on the mast with a turning block. Simple, works great. If you look at those Alter Cup pictures closely, you will see the same mast cleat that I have.
Blade F16 #777
[Re: Timbo]
#121191 10/29/07 03:49 PM 10/29/07 03:49 PM |
Posts: 1,200 Vancouver, BC | We've been running the new type spinloks on the T for a few months with good results. I have the halyard lock on the mast: with a flapper turning block lower down: This allows crew to haul the sail up be pulling upwards instead of "jumping" it from above...keeps the feet well planted into the tramp for stability. The system also makes cleating automatic during the hoist, remain cleated during gybes when someone trips on the lazy section of halyard on the tramp and surprisingly it does not re-cleat during douses if the lazy side gets a snag or resistance. The new type spinlok does have a higher SWL than the original type. I have been running 4 mm Pirhana (a type of the new Paraloc) line, but the pic shows standard tapered line with stripped 3mm spectra core. Robi, a Spinlock will re-cleat itself on a douse, if you put any resistance on the halyard, such as when you sit on it. That cannot happen on a cam-cleat. I have broken several spinlocks, I won't use them. I see no advantage to them, only problems when they fail or re-cleat on a douse.
346
guests, and 22
