| Trapeze Wires #122312 11/06/07 04:20 AM 11/06/07 04:20 AM |
Joined: Jul 2006 Posts: 461 Victoria, Oztralia mattaipan OP
Posts: 461 Victoria, Oztralia | Hi All
I'm having a bit of a blank moment, and can't remember what construction is used for trapeze wires, 1x19 or something else.
About to order some wire and things to make some up, and I thought I was right with 1x19, now I'm doubting myself.
Please Help
Matt Harper
Homebuilt Taipan 4.9
| | | Re: Trapeze Wires
[Re: davefarmer]
#122316 11/07/07 11:35 AM 11/07/07 11:35 AM |
Posts: 9,582 North-West Europe | 3 mm dyneema on there since juli 2004 and I'm still counting.
| | | Re: Trapeze Wires
[Re: davefarmer]
#122319 11/09/07 12:02 AM 11/09/07 12:02 AM |
Posts: 2,921 Michigan | The best thimble to use is the closed end "sailmakers" thimbles. The biggest problem I have had with the synthetic lines around standard thimbles is that they do get abraded around the sharp V. You actually don't need the thimbles at the top. They are necessary at the bottom though depending on how you run the trap line to the hook through them. I have made about 6 sets or so for boats that I was able to keep an eye on and there have been no issues except on the boat with the 7/64 amsteel and a 240lb dude hanging from them who likes to fly around the forestay on a routine basis. Those abraded relatively quick. Another boat has had them up in the Florida sun over the summer and there were no problems.
and they are eyesplices around the thimbles. I would recommend 1/8 because it gives you more play room before the abrasion becomes a problem. Our Scandinavian friend uses knots and hasn't had a problem. I like splicing them so I do that.
| | | Re: Trapeze Wires
[Re: davefarmer]
#122321 11/09/07 04:41 AM 11/09/07 04:41 AM |
Plastic thimble on top secured with a figure 8 knot and some stitching. Bottom just a figure 8 knot loop that is secured to the pin of the shackle by a fishers hitch. The trap handle rest on a figure 8 knot in the line. I have no issues with abbrassion. The plastic thimble has "teething" marks of the gear up at the hound fitting but the line itself is fine.
591
guests, and 41
