Nacra 5.0 hull and sail numbering #124680
11/24/07 06:20 PM
11/24/07 06:20 PM
Castelldefels, Barcelona
Toni_50 Offline OP
Toni_50  Offline OP
I have recently bought a used old Nacra 5.0 in the Netherlands.
The hull number can be read below the rear beam and is hand writen as follows: NACA 2072L 586.
The original main sail is white with center red and yellow stripes and apart from figures 5.0 has no inverted U logo nor sail number.
I would like to add now a number to the sail for identification in Barcelona Spain where I live, what is the usual numbering policy? should I use the same number as the hull (I guess 2072) ?
Do the last digits of the hull code indicate that the manufacturing year is 1986?
Regards
Toni
Re: Nacra 5.0 hull and sail numbering [Re: Toni_50] #124681
11/25/07 04:25 AM
11/25/07 04:25 AM
japan
erice Offline
erice  Offline
japan
as far as i know it should be a 1986 model....
that's about the time nacra changed from solid frp to the foam sandwich, which do you have?
as for sail numbers my 1982 nacra 5.2 doesn't have the inverted U symbol either but i have a pic of a 5.2 3089 which does, so i guess it came into use sometime after 1982....
my sail number is J65, which has nothing to do with the hull number as can be seen below but more to do with the fact that it was the 65th 5.2 to be registered? in japan
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: Nacra 5.0 hull and sail numbering [Re: erice] #124682
11/25/07 08:41 AM
11/25/07 08:41 AM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
the 586 could indicate May 1986.
The inverted U is actually an N, for Nacra.
Re: Nacra 5.0 hull and sail numbering [Re: arbo06] #124683
11/27/07 10:57 PM
11/27/07 10:57 PM
Severna Park, MD
David_Nolte Offline
David_Nolte  Offline
Severna Park, MD
I concur, the 86 identifies it as a 1986 boat. I've just come into a 1983 boat.
Many manufacturers numbered sails in production order, but there is no reason you can't put any number that has significance for you on it.
David
H16, H14, N5.0
David Nolte
H16, H14, Nacra 5.0
0 registered members (), 273 guests, and 54 spiders.
