| Southern Hemisphere question #128945 01/16/08 10:14 AM 01/16/08 10:14 AM |
Joined: Jul 2001 Posts: 1,253 Columbia South Carolina, USA dave mosley OP
Posts: 1,253 Columbia South Carolina, USA | ok, Im really bored, and just wondering does the water in the toilets in the southern hemisphere really swirl counterclockwise?
| | | Re: Southern Hemisphere question
[Re: dave mosley]
#128946 01/16/08 11:36 AM 01/16/08 11:36 AM |
Posts: 902 Norman,OK | Nope, I checked a few years abck when I was in Ecuador, I am pretty sure the toilet designer can control which way it swirls.
[Re: dave mosley]
#128948 01/16/08 12:22 PM 01/16/08 12:22 PM |
Posts: 1,200 Vancouver, BC | While a toilet could be made to swirl anyway the designer wants because the flow direction from the tank can be at an angle, a sink drain is a different matter. In the absense of an overiding force, the Coreolis Force determines directil of swirl. At the equator, the net Cereolis force cancels out, so water tends to straight down drains.
[Re: Tornado]
#128949 01/16/08 03:29 PM 01/16/08 03:29 PM | Anonymous
| Anonymous
Unregistered | And we are still in the first month of winter... wow... whats next? If a tree falls and no one hears it....
Boy i hope Punxsutawney Phil sees no shadow this year! | | | Re: Southern Hemisphere question
[Re: dave mosley]
#128950 01/16/08 03:42 PM 01/16/08 03:42 PM |
Posts: 6,049 Sebring, Florida. | Dave, I used to lay over in Sao Paulo, Brazil quite a bit. I too had the same buring question, keeping me awake at night...so I tried the sink, toilet and tub. As previously stated, if the toilet shoots water at an angle, that's the way it swirls. BUT in the TUB and Sink, if you plug it up and let the water level go up several inches, you can indeed see a little vortex spinning the -other way- when you let the water out, at least that's what it looked like to me.
Blade F16 #777
[Re: Timbo]
#128951 01/16/08 05:17 PM 01/16/08 05:17 PM |
Joined: Nov 2002 Posts: 612 Cape Town, South Africa Steve_Kwiksilver
Posts: 612 Cape Town, South Africa | This thread is rapidly going down the drain. I almost ran downstairs to fill the sink and check, but last I remember the water forms a vortex going in a clockwise direction. Is this opposite to up North ? And, your Northern Winter being the cause of threads like this one, I thought I`d add what some folks do in winter, though I`m glad it`s not me. iceman | | | Re: Southern Hemisphere question
[Re: Steve_Kwiksilver]
#128952 01/16/08 05:55 PM 01/16/08 05:55 PM |
Posts: 757 japan | in theory it works but in practice the movements in the water, the design of the sink, is it perfectly level etc. are all much much stronger than the weak coriolis force, so in tests it never works
[Re: Tornado]
#128954 01/16/08 09:29 PM 01/16/08 09:29 PM |
Joined: Jun 2001 Posts: 890 Dunedin Causeway, FL David Parker
Posts: 890 Dunedin Causeway, FL | At the equator, the net Cereolis force cancels out, so water tends to straight down drains. So at the poles...? <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" /> | | | Re: Southern Hemisphere question
[Re: Darryl_Barrett]
#128956 01/17/08 07:47 AM 01/17/08 07:47 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Darrell, since you are in the southern hemisphere, can you tell me which direction the water swirls in your toilet? Kwiksilver in South Africa has already reported clockwise.
And also, if you have a dog, what direction does the dog circle in when lying down to go to sleep? Our dog circles counterclockwise, just as our toilet does (and just as have all the toilets and dogs we have ever owned).
I guess we could rip out our toilet and take it and our dog to South America and see whether they go the other direction. <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" /> | | | Re: Southern Hemisphere question
[Re: davidtilley]
#128960 01/17/08 09:07 AM 01/17/08 09:07 AM |
Posts: 1,187 38.912, -95.37 | There it is!!! Empirical evidence...Mary and David's dogs and our Border Collie/something else mix rotate counterclockwise prior to the important things in life. Bordie Collies originated in England and Scotland and her other half is definitely some kind of retriev-ador. NH rules.
Hey, do your dogs sleep 17 hours a day too? <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
[Re: David Parker]
#128961 01/17/08 09:07 AM 01/17/08 09:07 AM |
Posts: 6,049 Sebring, Florida. | Yeah in South America I become left handed... <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />
Blade F16 #777
[Re: David Parker]
#128962 01/17/08 01:02 PM 01/17/08 01:02 PM |
Posts: 1,200 Vancouver, BC | Umm..water is solid at the poles...so it doesn't go down the drain. (NOTE: THIS IS NOT AN INVITATION TO START ANOTHER G.W. THREAD!!!) At the equator, the net Cereolis force cancels out, so water tends to straight down drains. So at the poles...? <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
[Re: ]
#128963 01/17/08 01:22 PM 01/17/08 01:22 PM |
Posts: 3,969 | And we are still in the first month of winter... wow... whats next? If a tree falls and no one hears it....
That's an easy one. It just depends on your definition of "sound." According to dictionary.com: "the sensation produced by stimulation of the organs of hearing by vibrations transmitted through the air or other medium." So, by that definition, if there are no ears to translate the vibrations of the air, then no, the tree doesn't make a sound. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> Yes, winter sucks. As for the Coriolis effect, don't hurricanes spin the opposite way down under too? Of course, they're called cyclones or something, aren't they? Wikipedia seems to clear this up: http://en.wikipedia.org/wiki/Coriolis_effectAs mentioned by others here, the geometry of the toilet affects the flow more than anything else. Per the Coriolis effect only, it should be actually be flowing COUNTER-clockwise in the north... Mike | | | Re: Southern Hemisphere question
[Re: Mary]
#128964 01/17/08 07:10 PM 01/17/08 07:10 PM |
Joined: Feb 2004 Posts: 1,012 South Australia Darryl_Barrett
Posts: 1,012 South Australia | Mary the water in every bath, sink, toilet, in every house/building that I have ever owned, (although I don’t make a habit of holding my head in the toilet when flushing, but Hey, if that is your thing ------) has always, and does, swirl in a clockwise motion. As to dogs, I have bred dogs for many years, mainly Boxers, and I have to say that although predominantly my dogs tend to turn three times clockwise before settling down to sleep they do at times turn the other way, at times even turning clockwise three times then immediately reversing for three turns anti clockwise before settling I have many varieties of Southern, Indian, and Pacific Ocean Abalone shell here and they all have formed with the swirl clockwise | | |
3,236
guests, and 277
