| Re: Building a mast
[Re: Gato]
#133040 04/25/08 12:44 AM 04/25/08 12:44 AM |
Posts: 435 Finland | | | | Re: Building a mast
[Re: Rolf_Nilsen]
#133042 04/25/08 04:54 AM 04/25/08 04:54 AM | Anonymous
| Anonymous
Unregistered | Rolf,
I believe thats the F12 mast. Gato also has the drawings for an F16 one. The F16 mast has similiar static bend characteristics to the "standard" aluminium one but is much lighter and ironically probably cheaper. I believe he makes the carbon tube himself.
You can buy "peel ply" at any dress making shop.
| | | Re: Building a mast
[Re: Rolf_Nilsen]
#133045 04/25/08 02:17 PM 04/25/08 02:17 PM | Anonymous
| Anonymous
send me an email to chris (at) ctmd.com.au and I'll send you the F16 mast drawing. | | | Re: Building a mast
[Re: Gato]
#133047 04/28/08 03:52 PM 04/28/08 03:52 PM |
Posts: 4,451 West coast of Norway | You can buy "peel ply" at any dress making shop. Really? Any kind of nylon cloth? I was worried that the cloth treatment would leave residues in the surface of the epoxy. I have used some ripstop nylon from an inner tent and that worked very well.. I got the plans from Scarecrow. Think I can do this! Would be a really fun project, but not until the next winter I think. Engineering wise, is the carbon taking all the loads or do the wood contribute as well? Perhaps especially in the "horizontal" level? | | | Re: Building a mast
[Re: Rolf_Nilsen]
#133048 04/28/08 05:03 PM 04/28/08 05:03 PM | Anonymous
| Anonymous
the ply is definitely a contributing component in the structure, primarily in the longitudinal structure. It is not considered to provide any "hoop" strength because it is stripped.
Buy a couple of samples of nylon and have an experiment. A lot of commercially available "peel plys" are [censored] and aren't easily removed in one piece. | | | Re: Building a mast
[Re: PTP]
#133051 04/29/08 07:22 AM 04/29/08 07:22 AM |
Posts: 4,451 West coast of Norway | That is the beuty of it, epoxy dont adhere to nylon, so you can remove the nylon and any aborbent layers on top of it in one go. You remove it when the epoxy have set fully.
Scarecrow. If the ply strips dont add "hoop" strength, using WRC strips would be even better? I dont have the math to understand why, but I though the carbon fibers would take all loads longitudionally until they eventually broke. Then the wood would begin to carry loads? Is that a matter of oversimplification?
Nick, I think they left the peel ply on in the beginning, and pulled it off when they were to glue something to the surface. It was thought to be state of the art and the solution to the eternal sanding. As you say, they found out differently, to their cost. | | | Re: Building a mast
[Re: Rolf_Nilsen]
#133052 04/29/08 08:08 AM 04/29/08 08:08 AM |
Posts: 2,921 Michigan | Scarecrow. If the ply strips dont add "hoop" strength, using WRC strips would be even better? I dont have the math to understand why, but I though the carbon fibers would take all loads longitudionally until they eventually broke. Then the wood would begin to carry loads? Is that a matter of oversimplification?
I have wondered about this- are the strength characteristics of wood and carbon different? I would figure they obviously are, so how does that work then in terms of using two difference substrates in an application that will be bending all the time? Does the wood break before the carbon or vice versa? If the properties of each are very different then one breaks before even getting near the break point of the other | | | Re: Building a mast
[Re: PTP]
#133053 04/29/08 04:49 PM 04/29/08 04:49 PM | Anonymous
| Anonymous
Unregistered | Rolf, any stripped material is going to provide limited hoop strength, simply due to the fact that you are relying on the tensile strength of the resin between strips.
PTP, yes the material properties of timber and carbon are different, as are carbon/foam etc. The trick is to engineer the structure to make sure each component is not asked to contribute any more strength than it is capable of. I did quite a bit of work many moons ago with a company who were building carbon masts for offshore racing boats in a very similar fashion to what we are doing here. I know they built a mast for at least one 66' pocket maxi.
Peel ply definately reduces the need to sand but doesn't eliminate it. Leave it on for as long as possible, ie take it off when the job is done or when and if required to access an area for secondary bonding. | | | Re: Building a mast
[Re: PTP]
#133054 04/29/08 08:16 PM 04/29/08 08:16 PM |
Joined: Oct 2005 Posts: 951 Brisbane, Queensland, Australi... ncik
Posts: 951 Brisbane, Queensland, Australi... | It is not necessarily the strength of the materials in a laminate that determines which will break first, it is the stiffness of each material. Deflection/bending is the key.
Imagine two simple laminates; stiff carbon and flexible fibreglass. Under the same load the carbon will deflect less than the glass. Keep increasing the load and you will find as expected that the fibreglass laminate will break first, but at a much greater deflection than the carbon.
Now join the two laminates together. The carbon is so much stiffer than the glass that the deflection allowed by the carbon won't be very large, and certainly nowhere near the deflection required to stress the glass fibres greatly. Increasing the load and the carbon will continue to restrict deflection below that required for the glass to fracture, until the carbon breaks a little below what it would've alone (because the glass is providing a little bit of support).
This is a highly simplified scenario, it gets a bit trickier when considering hoop stresses and laminate shear forces, buckling, etc. | | | Re: Building a mast
[Re: ncik]
#133055 04/29/08 11:48 PM 04/29/08 11:48 PM | Anonymous
| Anonymous
Unregistered | Well put Ncik, I might have been a bit simplistic in my answer.
I don't like writing the over the top highly technical and condescending answers that some others use, but sometimes go to far in the other direction. | | | Re: Building a mast
[Re: ncik]
#133057 04/30/08 05:34 AM 04/30/08 05:34 AM | Anonymous
| Anonymous
Unregistered | Are you going to be around during Sanctuary Cove? Come and find me. Stand 377 (superyacht tent) | | |
1 registered members (TimTT),
600
guests, and 94
Mod | | Forums26 Topics22,404 Posts267,055 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
