Cat Trax inner tube on a Roleez wheel? #141177
04/24/08 08:38 PM
04/24/08 08:38 PM
Chesapeake, VA
C
clintopher Offline OP
C
Chesapeake, VA
Will the Cat Trax inner tube fit a roleez wheel? I'm not sure of the size. My father-in-law has had them for a while...says patent pending on the tire. Anyway, the only information it has on the side of the tire is 120Kg (264lb) payload. That jives with the info from the 49cm Wheeleez.
So does anybody know if the tubes will work? If not I'm gonna have to get real creative with a broken valve stem.
Clint
Re: Cat Trax inner tube on a Roleez wheel? [Re: clintopher] #141178
04/25/08 06:33 AM
04/25/08 06:33 AM
Cincinnati, Ohio
Tri_X_Troll Offline
Tri_X_Troll  Offline
Cincinnati, Ohio
Don't see why not, as long as they are both close in size.
You could blow them up outside of the tire and see how they look next to the tire they are going in.
Re: Cat Trax inner tube on a Roleez wheel? [Re: Tri_X_Troll] #141179
04/25/08 07:46 AM
04/25/08 07:46 AM
Columbia South Carolina, USA
dave mosley Offline
dave mosley  Offline
if not, I got a tube replaced in mine from the local tire store for $20. sure beats $110 for a new tire from cattrax
Re: Cat Trax inner tube on a Roleez wheel? [Re: Tri_X_Troll] #141180
04/25/08 08:03 AM
04/25/08 08:03 AM
Cat Trax tires are much larger than Rol-eze tires. 65" circumference if memory serves.
Re: Cat Trax inner tube on a Roleez wheel? [Re: mbounds] #141181
04/25/08 09:33 AM
04/25/08 09:33 AM
Chelmsford, MA
Barry Offline
Barry  Offline
Chelmsford, MA
You can't put a tube in a Rolleze tire. The tire doesn't have a bead that attaches to the rim like the Cat Trax.
Blow them up to the pressure you want then seal the value with some glue.
Re: Cat Trax inner tube on a Roleez wheel? [Re: Barry] #141182
04/25/08 04:16 PM
04/25/08 04:16 PM
dave mosley Offline
dave mosley  Offline
mine was a cattrax tire that I replaced with an innertube, but I bet they(any tire store) could size and/or fix the rolleez too
0 registered members (), 194 guests, and 44 spiders.
