| Painting Prep questions #14160 12/14/02 09:40 PM 12/14/02 09:40 PM |
Posts: 3,114 BANNED | Since it seems the only way that I can keep up with the jones' and keep my boat respectable amongst the speedy is if I'm gonna suck wind because of my boat, I might as well look good doing it.... that why I'm repainting the lead sled. I've got all the goodies that I need from painting restored 55 chevys, but I have one quick question. The no-slip texture on the top of the hulls.... do I sand it smooth or try and leave it there? I would rather sand it off, so I can add my own no-slip textured paint topside. The "expert" (read: father) says that if I sand that off, I'd go right through the gelcoat. I disagree. You people are the moderators  Wheres judge mills lane when you need him? Thanks! (yeah, I might not sail as quick as you carbon fiber fuddyduddies, but all the chicks will want my lowrider heh) | | | Re: Painting Prep questions
[Re: MauganN20]
#14168 12/15/02 05:25 PM 12/15/02 05:25 PM |
Posts: 117 | Your post caught my intrest...and I am currently rebuilding a H17 and had to install access ports for a repair. I still had the cut out piece for the hole, so I decided to sand the texture portion to see what happens. I was able to sand it smooth and the resin and glass from below the gelcoat started to show through as i just sanded it level with the center non textured section. This kind of makes sense because the gelcoat is sprayed into a mold and will form a uniform film thickness.
I just painted my 17 last october, and after making all of the repairs and fairing everything, I sanded everything but the texture with 320 paper, and just cleaned the texture real well with a scrub brush and acetone. I then rolled on 2 coats of interthane plus, even over the texture, and it looks great. The finish does not build up much in the texture. I used white, although the off white may have been a better choice, so if it chips or scratches it will just show the white gelcoat below the paint and hopefully not be noticable. No primer was needed. E-mail me if you want some details.
Also, on your soft spot, I had a soft spot like this on a older 17 I had and it did not appear to be delamination. It seemed it had been steped on carelessly or a heavy object on it and it kind of crushed the structure of the glass and foam not cosmetically but damageing it internal strength. I epoxyed a peice of hardwood to the underside and it fixed it perfectly. You could glass in a piece of PVC or even a Christmass wrapping paper roll tube to strengthen it. (the paper tube is just to give the glass shape untill it sets up, it will eventually rot away) I had to cut out some flotation foam to get to it, just put it back in when finished.
P16 H17 in progress | | | Re: Painting Prep questions
[Re: PSAILOR]
#14170 12/17/02 01:08 AM 12/17/02 01:08 AM |
Posts: 3,114 BANNED | I like the idea of the pvc, its quick and easy, but I think I'm going to go for the hardwood idea. I'm going to laminate it first in a coat of glass, then shove it in there, build up some glass on top of that, then putsome of that "great stuff" foam on top of that, replace the pumpkin lid and tape it down, so that the foam is forced out of the edges of the lid... then use some kind of marinetex time stuff to fill in the gap. Then it's time for painting.
This sound like a good plan?
(this plan was conceived by my father and I. The former having a couple years of powerboat fiberglass experience, the latter a prodigy in the works :P ) | | |
522
guests, and 41
