| Re: Hobie 16 Hiking Strap Length??
[Re: pitch_poled]
#14264 12/16/02 01:11 PM 12/16/02 01:11 PM |
Posts: 284 Norfolk, VA | You should be able to use the same spot where the straps were sewn on originally. I have done the repair before and seat belt material works well. I have also used life jacket straps that I found at West Marine. I found that if you put a twist in the straps, you can slip your feet under them much easier. Use Nylon straps, not cotton!
Another trick I did was to install grommets in the tramp where the lacing was attached before. Then, I ran a line through the grommets and never had to worry about replacing the straps. That was a $2.00 fix compared to a $40+ fix getting an upholstery shop to sew the straps back on. I didn't even have to take the tramp off the boat! You can also slip some material like a hose over the line to make it easier on your shins and feet.
Dan Berger Norfolk, VA A Cat USA139 Supercat 15
[Re: Curt]
#14269 12/19/02 05:48 PM 12/19/02 05:48 PM |
Joined: Nov 2002 Posts: 54 Panama City Beach, FL Sunjammers
Posts: 54 Panama City Beach, FL | You can use the grommet to attach the strap to the tramp. This is normally the best way to attach the strap back to the tramp. If you store lifejackets or anything under any part of the strap then I would consider leaving more slack than normal for more storage. Thanks, Brad Stephens 850-235-2281 www.sunjammers.comAuthorized Hobie Dealer
Thanks, Brad Stephens Panama City Beach, FL | | | Re: Hobie 16 Hiking Strap Length??
[Re: Curt]
#14270 12/20/02 07:51 PM 12/20/02 07:51 PM |
Posts: 284 Norfolk, VA | I did the strap thing a few times. I installed 3 grommets on each side piece of the tramp where the straps used to be sewn on. The first time, I used a dog leash size nylon strap. I thought it was a little small, so I replaced it with a life jacket one. You will have to get special grommets if you want to use something big like a seat belt piece.
I tied a knot in one end of the strap and passed it up through the grommet at the front of the boat. I then ran it to the grommet in the middle of the boat and down trough it. I tied another knot in it under the boat and passed it back up through the grommet. Then, I ran it down through the rear grommet and tied one more knot under the boat. Pretty easy!
I suppose that you could use the seatbelt piece in the same fashion. You could probably tie it in a knot under the tramp and run it through once, but it proably won't go through the same grommet twice. You could use a larger diameter piece of rope by tying a knot in the end (under the tramp) running it up through the grommet, around the seatbelt strap and back down through the grommet. Finish it off by tying another knot in it. That should work to hold the strap down.
I bought a grommet kit at Home depot. It came with a bunch of grommets, a punch and the setter. Granted, that was a little bit of an investment, but I have used it MANY times and it was a lot cheaper than taking the tramp somewhere to get it fixed.
[Re: pitch_poled]
#14272 12/23/02 07:25 PM 12/23/02 07:25 PM |
Posts: 54 Panama City Beach, FL | You can order a grommet kit from any Hobie Cat Dealer, They are the same grommets Hobie uses in there tramps. They are very reasonably priced and include everything you need to install them, except the hammer! Thanks, Brad Stephens 850-235-2281 www.sunjammers.comAuthorized Hobie/Vanguard Dealer
[Re: Sunjammers]
#14273 12/27/02 03:27 PM 12/27/02 03:27 PM |
Posts: 284 Norfolk, VA | The grommets from Home Depot have been OK--I haven't noticed any differences in quality. I also bought a bunch on eBay!
264
guests, and 46
