| Re: weather helm
[Re: tau0]
#143278 05/14/08 04:47 PM 05/14/08 04:47 PM |
Posts: 6,049 Sebring, Florida. | In light air you will definately go faster with the jib. In medium air you will be faster with the jib too, only in big wind will you be better off to leave it in the box unless you have crew, then take it. I assume you have a self tacking jib. It's very easy to trim it and forget about it in the tacks even if you are sailing alone. BUT, when you raise up the spinnaker, be sure to let the jib out quite a bit so the air can freely pass through the slot.
Blade F16 #777
| | | Re: weather helm
[Re: bobcat]
#143279 05/14/08 05:30 PM 05/14/08 05:30 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Sailing one-up, you would have to leave the jib on the beach to be true to your Portsmouth rating. If you put the jib on you would be exposed to an adjustment of your rating. I have a question about that. If you are sailing one-up on the F16, can you choose to sail with just main and jib instead of main and spinnaker? | | | Re: weather helm
[Re: Mary]
#143280 05/14/08 06:01 PM 05/14/08 06:01 PM |
Posts: 131 Scotland | I have a question about that. If you are sailing one-up on the F16, can you choose to sail with just main and jib instead of main and spinnaker? Nope - rules say you can't use a jib one up: 1.11 The sails in general 1.11.1 The sail plan in the doublehanded configuration comprises a mainsail, a jib and a gennaker. 1.11.2 The sail plan in the singlehanded configuration comprises a mainsail and a gennaker. 1.11.3 Racing with fewer sails than those named for each configuration is permitted. | | | Re: weather helm
[Re: tau0]
#143282 05/15/08 08:18 AM 05/15/08 08:18 AM |
Posts: 465 Oxford, UK | In theory, adding the jib should reduce weather helm, as it should move the centre of effort forwards. In fact, I find the exact opposite, but this is because I only ever sail 2-up with the jib, and 1-up without, and by the time you're twin-wiring the rudder loads are much higher than when you only have one person on board, amplifying any weather helm.
Checking the forestay position is not a great way of measuring rake, as the rigging will stretch a bit over time.
As others have said, you'll be faster with the jib up to the point where you're getting overpowered. This is especially true if you get set reaching courses.
Paul | | |
320
guests, and 35
