| Idiot's guide to sailplan setup #145727 06/13/08 09:35 AM 06/13/08 09:35 AM |
Joined: Dec 2001 Posts: 5,590 Naples, FL waterbug_wpb OP
Posts: 5,590 Naples, FL | Okay, need some really basic (yet reasonalby accurate) means of measuring the following on a beachcat: Mainsail luff curve Mast prebend Mainsail draft
I would seem from my reading that the easiest way is to turn the boat on its side (I guess support the mast at the hounds) to measure sail draft..?
| | | Re: guide to sailplan measurement
[Re: waterbug_wpb]
#145728 06/13/08 12:15 PM 06/13/08 12:15 PM |
Posts: 1,307 Asuncion, Paraguay | Okay, need some really basic (yet reasonalby accurate) means of measuring the following on a beachcat: Mainsail luff curve Mast prebend Mainsail draft
I would seem from my reading that the easiest way is to turn the boat on its side (I guess support the mast at the hounds) to measure sail draft..? The luff length is easy to measure directly from the sail lying on the floor, as well as the luff cord (curvature). I would take pictures of the others and see if it suffices. Pictures of the mainsail as seen from the tramp (or from the ground, if tramp removed) reveal a lot. Pictures of the mast taken from the mastfoot or from the ground inform a lot about prebend.
Luiz
| | | Re: Idiot's guide to sailplan setup
[Re: waterbug_wpb]
#145729 06/13/08 02:37 PM 06/13/08 02:37 PM |
Posts: 3,906 Clermont, FL, USA | Bug, just go sailing! Why in the world are you worrying about luff curve when you haven't been wet it what.... 4 years? And another thing...pictures or it never happened.
[Re: waterbug_wpb]
#145730 06/13/08 02:46 PM 06/13/08 02:46 PM |
Posts: 3,528 Looking for a Job, I got credi... | Okay, need some really basic (yet reasonalby accurate) means of measuring the following on a beachcat: Mainsail luff curve Mast prebend Mainsail draft
I would seem from my reading that the easiest way is to turn the boat on its side (I guess support the mast at the hounds) to measure sail draft..? Mainsail luff curve: Peg head to ground (or tie around a post), pull "tight" from the downhaul clew and peg / tie to another post, put some twine from center of one eye to the other (head eye to DH eye) and tighten; and then measure the difference between this line and the BACK of the bolt rope. Mast prebend 1, tie a thin line or whipping tewine to top of the mast and then pull tight and tie around the gooseneck fitting on the mast. Tape the line to the mast at the black band at the top of the mast (if you have one) or have a "class measuement point"; Same at the bottom so you have the line right beside the mast. 2, take a sail batten and place this across the back of the spreaders resting on the diamonds; Measure distance from mast track to the bit of line. Never really measured sail draft.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Idiot's guide to sailplan setup
[Re: David Ingram]
#145731 06/13/08 03:40 PM 06/13/08 03:40 PM |
Posts: 5,590 Naples, FL | Bug, just go sailing! Why in the world are you worrying about luff curve when you haven't been wet it what.... 4 years? And another thing...pictures or it never happened. It's part of my "dreaming out loud" thing.... But Ksurfer did offer an invite to Hirams if he still has a boat in one piece by then.... And it's probably been closer to A BILLION years <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />
[Re: waterbug_wpb]
#145732 06/13/08 04:31 PM 06/13/08 04:31 PM |
Posts: 1,152 tampa, fl | Offer still stands for Hiram's. I did get a box of parts in the mail and the boat is going back together this weekend!
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: Idiot's guide to sailplan setup
[Re: scooby_simon]
#145733 06/14/08 04:43 AM 06/14/08 04:43 AM |
Posts: 1,203 uk | Your #2 is a measurement of spreader rake Simon
[Re: waterbug_wpb]
#145734 06/14/08 04:48 AM 06/14/08 04:48 AM |
Posts: 1,203 uk | Luff curve - loosen the battens and lay sail on flat surface
Prebend - eye up the back of the mast or tension the main halyard down the back [on windless day]
Sail draft - tip rigged boat on its side. dropping a ball on the sail is always interesting to see where it goes!
384
guests, and 122
