| Re: Help buying my first Cat
[Re: TurboCat]
#146605 06/24/08 03:04 PM 06/24/08 03:04 PM | Anonymous
| Anonymous
Unregistered | just buy the one in the best shape and get on the water. as long as you dont blow it up... you can sell it and buy another anytime... | | | Re: Help buying my first Cat
[Re: mike4xin]
#146608 06/24/08 04:27 PM 06/24/08 04:27 PM |
Posts: 168 San Diego | make sure the trailer is titled for whatever boat you buy, and if not then tell the current owner to do it because it is a huge pain and will cost you close to the cost of the trailer. | | | Re: Help buying my first Cat
[Re: mike4xin]
#146610 06/26/08 12:40 AM 06/26/08 12:40 AM | Anonymous
| Anonymous
Unregistered | I have sailed all the boats you list and they are all very good. Just be sure to read that link and check for all the serious defects listed in it. Most everything else can be repaired, but if something such as soft decks (hulls) are present you wont be able to repair it. I like prindles myself.
If you are new you probably want to read a book to get all the safety info. also post here we will be happy to help.
Formula 18 is probably too aggressive for a first boat unless you are already an experienced racer.
[Re: ]
#146611 06/26/08 02:27 AM 06/26/08 02:27 AM |
Posts: 431 Netherlands | I bought a 5.2 after due deliberation, much like yourself I assume. Got a lot of help from the people on this forum, they are an excellent bunch. First you need to be brutally realistic about what you are going to do with this boat. Its not what you INTEND to do with it, but what you are actually going to DO with it that counts! Get that cleared up first off. IE will you race, get a boat with a good local fleet.
I think my 5.2 is excellent, but coming from a (racing) keelboat I am used to having underwater appendages (like daggerboards on a 5.2) that can badly damage the boat when grounding at speed. If sailing in an area with shallow water and lots of nasties under water, you might want to consider a boardless design.
The Nacra 5.2 itself is about as gentle as it gets. Not too quick to fly a hull, which is either frustrating (to a pro) or reassuring to a catamaran beginner like me. Precision steering due to the daggerboards is truly excellent! The boat is quite straightforward to rig (IMHO). Very easy to de-power, mainly because it isn't really overpowered in the first place. You can go with just the main for really relaxing sailing. Does not tend to nose dive (in fact I need my weight quite far forward when sailing solo to keep the transoms from dragging). Mine has the center bar in the tramp, I like this because it gives me some support when the boat starts to heel, so I don't go sliding off the tramp. The 5.2 is quite heavy for on the beach solo handling. On a nice sloping beach you may be able to get it back up high and dry solo, but can you still drag it yup the beach after a couple of hours sailing? I know I can't at our local beach, which has this huge sandbar you need to negotiate first. Luckily there's always help nearby. (Maybe I should get a Newfoundlander and rig the dog up with a harness...) Righting solo is a hit and miss affair though. I really can't tell you if you can pull it off solo in light winds. My web research reveals that some can do it (heavier sailors like 200 lbs+) and some can't (those with a more average posture). You may want to consider this and carry a righting bag or install some other righting help. Or get your own Newfoundlander you can dangle off your shoulders....
Regards, Dennis | | | Re: Help buying my first Cat
[Re: DennisMe]
#146612 06/26/08 08:29 AM 06/26/08 08:29 AM | Anonymous
| Anonymous
Unregistered | You may want to consider this and carry a righting bag or install some other righting help. Or get your own Newfoundlander you can dangle off your shoulders.... If you don't sail with crew or friends ... you SHOULD invest and carry a righting bag. | | | Re: Help buying my first Cat
[Re: mike4xin]
#146614 06/26/08 02:34 PM 06/26/08 02:34 PM | Anonymous
| Anonymous
Unregistered | Bewlow is a rough guide to boat weights. I do not think it is correct is stating the P16 is 150 lbs. I think it is 300. The prindle 16 is a lighter mast... and pretty easy to self step. There are tricks to doing it safely (have the boat slanted downhill. run a saftey line through the jib turnbuckle, get a mast stepper).... http://www.multihullsmag.com/boats/boatlists/cats_up_to_20_feet.htmAs per self righting.. i stand by my statment above... bite the bullet and purchase a righting bag if you plan to sail solo ... Prindle guides - http://www.nacra.us/Prindles/
[Re: ]
#146615 06/26/08 03:50 PM 06/26/08 03:50 PM |
Posts: 757 japan | think you'll find the 16 is slightly lighter with a shorter mast and so easier to right solo, but
the 5.2's longer hulls and taller mast mean it will carry the extra weight better
[Re: mike4xin]
#146617 06/26/08 07:41 PM 06/26/08 07:41 PM |
Joined: May 2008 Posts: 22 North of Los Angeles, Californ... marshall
Posts: 22 North of Los Angeles, Californ... | I'm in So Calif and recently bought a Prindle 16 on a trailer. The seller did not put either of them in his name, leaving both in the original owner's name. Yeah, bad situation, but I checked with the DMV. Costs and penalties would not amount to a lot, so I made a good deal on both. Since the total amount paid was low, which is what the fees and penalties are based on, I got out of the DMV, for both the P16 and trailer for just over $100. Includes everything up to date, new Calif Permanent Trailer plate, etc. It did help that the seller had the expired reg and title papers from the original owner. | | |
1 registered members (Seanziepop),
581
guests, and 110
