Storing a Hobie 16 outdoors? #154646
09/09/08 01:15 PM
09/09/08 01:15 PM
Southern Illinois
rfarson Offline OP
rfarson  Offline OP
Southern Illinois
I have to store a Hobie 16 outdoors - I'm in the midwest so a lot of temp changes. Are covers recommended? If so, is there a place they can be purchased? Any other tips? thanks...
~~~Ron
Re: Storing a Hobie 16 outdoors? [Re: rfarson] #154647
09/09/08 01:43 PM
09/09/08 01:43 PM
covers can't hurt and CatSailor has an OnLine store
Where in the MidWest do you sail?
Re: Storing a Hobie 16 outdoors? [Re: _flatlander_] #154648
09/10/08 08:12 AM
09/10/08 08:12 AM
Southern Illinois
rfarson Offline OP
rfarson  Offline OP
Southern Illinois
in Illinois near St. Louis at Lake Carlyle
~~~Ron
Re: Storing a Hobie 16 outdoors? [Re: rfarson] #154649
09/10/08 11:05 AM
09/10/08 11:05 AM
NC
drbinkle Offline
drbinkle  Offline
NC
How old is the boat? Custom fitted covers can be expensive and are usually used by owners of newer boats. I've used tarps for the past ten years without any issues.
Re: Storing a Hobie 16 outdoors? [Re: drbinkle] #154650
09/10/08 12:50 PM
09/10/08 12:50 PM
Southern Illinois
rfarson Offline OP
rfarson  Offline OP
Southern Illinois
Built in 1986. I am in the process of purchasing. Tarps sound good. How do you keep them on the boat?
~~~Ron
Re: Storing a Hobie 16 outdoors? [Re: rfarson] #154651
09/10/08 09:08 PM
09/10/08 09:08 PM
Lindale, Texas Inland freshwa...
Wallybear Offline
Wallybear  Offline
I use a 12 x 16 tarp which cover almost the entire H16. A very small bit of the hulls stick out the ends of the tarp. The 12 foot side is across the boat and the 16 foot side is lengthwise. I stretch it over the mast and then run a line from one front corner through the lower trailer mast support brace to the opposite front corner. This pulls the tarp tight, forward and down. At the rear I do sorta the same thing. The tarp is stretched tight and sheds water. I buy a silver tarp at Lowes and replace it every season. It cost about 22 bucks. Seems pretty effective. Of course a nice covered and dry storage would be great, but I don't have that option.
Re: Storing a Hobie 16 outdoors? [Re: rfarson] #154652
09/15/08 11:59 PM
09/15/08 11:59 PM
Minnesota
Jeff Peterson Offline
Minnesota
Just be sure you completely drain any water out of the hulls, before the freezing weather. You don't want ice expanding your hulls.
Jeff Peterson
H-16 Sail #23721
Big Marine Lake, MN
Re: Storing a Hobie 16 outdoors? [Re: Jeff Peterson] #154653
09/26/08 04:19 PM
09/26/08 04:19 PM
West Point, Utah
M
MikeG Offline
MikeG  Offline
M
West Point, Utah
I store my H16 outdoors in Utah using the same tarp option. I take my mast off the boat and hang it on the outside of the garage up near the eves and it stays dry and snow free most of the time. The boat gets the 10X16 tarp wrap and I use bungi cords that go from side to side under the boat. Last year I put a 2X4 accross the middle of the tramp from the front cross beam to the back and it shed the snow and water a little bit better. When we had snows of a foot or more I pushed the snow off with a push broom just so the weight wouldn't get to great. This is the 4th season and it has worked great so far. Don't expect the tarp to last much more than one season though. It takes the brunt of the sun damage so your boat doesn't.
Re: Storing a Hobie 16 outdoors? [Re: MikeG] #158212
10/25/08 12:38 AM
10/25/08 12:38 AM
Phoenix, AZ
Cousin_Eddy Offline
Cousin_Eddy  Offline
Phoenix, AZ
I store mine outside with a tarp and bungees. Bad idea. Just had a few windy days. The tarp and bungees did some damage to the hulls. I don't think it will buff out.
Re: Storing a Hobie 16 outdoors? [Re: Cousin_Eddy] #158349
10/27/08 07:05 AM
10/27/08 07:05 AM
C
Chet
Chet
C
It's also smart to store with the bow as high as possible and the drain plugs removed. This ensures a dry interior.
Regards
Chet
Re: Storing a Hobie 16 outdoors? [Re: ] #160680
11/18/08 04:33 AM
11/18/08 04:33 AM
japan
erice Offline
erice  Offline
japan
we store in 5-8 foot snow depths without any problems
masts are tied to trees with weight supported on an old tyre. due to snow loads rest of boat is disassembled with hull bases pointing upwards, to split the snow load, plugs out of course
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
0 registered members (), 220 guests, and 29 spiders.
