| Re: Diamond wire tension on an a-cat
[Re: carlbohannon]
#155873 09/25/08 11:44 AM 09/25/08 11:44 AM | Anonymous
| Anonymous
Unregistered | i run 420lbs on my mystere 5.5 | | | Re: Diamond wire tension on an a-cat
[Re: ]
#155874 09/25/08 02:43 PM 09/25/08 02:43 PM |
Posts: 5,590 Naples, FL | how do you calibrate a Loose gauge? I've got the old style (you hook up and pull outward)
[Re: waterbug_wpb]
#155875 09/25/08 07:57 PM 09/25/08 07:57 PM |
Joined: Jun 2001 Posts: 12,310 South Carolina Jake OP
Posts: 12,310 South Carolina | how do you calibrate a Loose gauge? I've got the old style (you hook up and pull outward) Hang known weight from a cable and measure the tension.
Jake Kohl | | | Re: Diamond wire tension on an a-cat
#155876 09/25/08 09:41 PM 09/25/08 09:41 PM |
Posts: 805 Gainesville, FL 32607 USA | LOOS. Not Loose- what are you an American voter?
Loos guages in the box come with a calibration page for each wire diameter. Conversion of Loos numbers to pounds of Kg change with the wire thickness and type. This Wire thickness can be measured by numerous means: V-groove guage, micrometer, slide guage, calibrated eyeball. You can probably get someone to xerox this page for you.
[Re: dacarls]
#155877 09/25/08 10:27 PM 09/25/08 10:27 PM |
Posts: 12,310 South Carolina | LOOS. Not Loose- what are you an American voter?
Loos guages in the box come with a calibration page for each wire diameter. Conversion of Loos numbers to pounds of Kg change with the wire thickness and type. This Wire thickness can be measured by numerous means: V-groove guage, micrometer, slide guage, calibrated eyeball. You can probably get someone to xerox this page for you. Whew...that was rough. Loos gauges, the one's we typically purchase, are not terribly accurate devices. To calibrate one you need to actually test it with a known condition.
Jake Kohl | | |
318
guests, and 55
