Re: mast pre bend [Re: ] #162451
12/11/08 10:14 AM
12/11/08 10:14 AM
Netherlands
L
Leo Ambtman Offline
Leo Ambtman  Offline
L
Netherlands
In my opinion more diamond tension takes out camber of the sail but not necessarily opens the leech (better for pointing) and that cunnigham open the leech and pull the depth forward (better for reaching). There must be a difference.
Re: mast pre bend [Re: ] #162468
12/11/08 12:22 PM
12/11/08 12:22 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Originally Posted by andrewscott
Question:
If you "overset" your pre-bend so when you max downhauled... you went past "fully flat" ... would that put more draft in your sail and power you up?
It would bend the mast more and give you a realy flappy leech on the back of a really flat front third of the sail - 'orrible
Re: mast pre bend [Re: TEAMVMG] #162655
12/15/08 06:54 AM
12/15/08 06:54 AM
Kiel, Germany
Baltic Offline
Baltic  Offline
Kiel, Germany
I agree with TeamVMG's remark. Wouldn't it make more sense to rig the boat correctly (= sail in the masttrack), lay her on one side and pull downhaul, outhaul, and mainsheet to a maximum as you would go upwind in extreme conditions and adjust the diamonds that they are just tight? Then you have enough mastband to get there if you need it but avoid over-tension.
F18: C2 / A-Cat: Minelli
Re: mast pre bend [Re: Baltic] #162901
12/18/08 04:43 AM
12/18/08 04:43 AM
ready Offline OP
ready  Offline OP
emailed glenn ashby on setting mast up ; swing the trap wire forward tie extra sheet onto the trap wire place next to forstay in middle of hull mark the sheet.place a mark 100ml in front of rear beam . swing trap wire to the stern .mast is in correct place when the trap wire touches these two marks this is for light wind /heavy wind 20knts + mark 100ml behind rear beam.mast stay wire tension 35 on loos guage .
Jerry
A class sail no. 763
mk.4
Re: mast pre bend [Re: ready] #162916
12/18/08 09:19 AM
12/18/08 09:19 AM
mark 100mm in front of the rear beam? That sounds way too far forward. I don't think I understand your measured positions - can you clarify?
Re: mast pre bend [Re: Jake] #162918
12/18/08 09:34 AM
12/18/08 09:34 AM
Kiel, Germany
Baltic Offline
Baltic  Offline
Kiel, Germany
... the value of 35 on the loose gauge remains the same on all wind conditions? I thought that mast rake remains fixed but the tension of the side stays gets adjusted according to the wind.
May I ask which adress you used to mail Glenn? I mailed him too, but received no reply - possibly I used a wrong address?
Kai
Re: mast pre bend [Re: Baltic] #162938
12/18/08 11:26 AM
12/18/08 11:26 AM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
Originally Posted by Baltic
Jack, you tuned your mast according to Mike Kratz's technique and want to make a try upcoming weekend? Please let me know how it has worked!
As some of you (and I) expected, we were way too flat at the extreme prebend settings. Even though the wind was 20+, we could not power up in the lulls (20-).
That was with rake at 4", tension at 800#.
The second day, with 18-20, we backed off to 3" rake and 600#...we were still underpowered except in the puffs.
Sooo....I guess the conventional wisdom is still about 2 to 2 1/2" rake and 400-700 tension.
That is some prebend with the ability to downhaul to as much as it takes. This is with an alloy stick of course.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Alachua FL/Put-In-Bay
Re: mast pre bend [Re: Mugrace72] #163022
12/19/08 03:43 AM
12/19/08 03:43 AM
C
cattail
cattail
C
There are a few different boats on this thread and different rigs and adjustment options with each. On my cat the side stays have only 5 holes to set the stays in before the forestays are tightened with some 1/8th braided line. Jerry I am going to try looking at the trap wire measurement next time I set up. Too bad we don't have any rake adjustment underway. As the wind comes up or dies that would be useful.
Re: mast pre bend [Re: ] #163030
12/19/08 06:45 AM
12/19/08 06:45 AM
ready Offline OP
ready  Offline OP
sorry for the confusion it should of read diamond wire tension is 35 on the guage. and the rear mark should be 100ml in front of the rear beam in the centre of the same hull thanks jerry
Jerry
mk.4
Re: mast pre bend [Re: ready] #163032
12/19/08 07:39 AM
12/19/08 07:39 AM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
You actually made more sense after the Christmas party than before. That must have been special punch you were drinking.
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: mast pre bend [Re: ready] #163038
12/19/08 09:23 AM
12/19/08 09:23 AM
So you're measuring like this? That's completely different than where I am on my Boyer MKIV. My experience is to have the trap line measurement fall even with the rear port for light air and halfway between the rear port and the stern for heavy. I'm MUCH more raked back than this measurement and could really feel that having it measured at the port for 15knots was way over powered. The second I raked it back more, the groove was steady and I had great speed:
Re: mast pre bend [Re: Jake] #163040
12/19/08 09:29 AM
12/19/08 09:29 AM
Jake,
what did raking the rig back do for helm balance? I am subscribing more to the thought of finding a good setting and depowering with downhaul. What is your opinion?
Re: mast pre bend [Re: Rolf_Nilsen] #163284
12/22/08 06:44 AM
12/22/08 06:44 AM
Apherel Offline
Apherel  Offline
Hi all, first post here.
I've dug around in my computer and found these comments from a tuning guide written by greg goodall, not sure when it was written, but probably around the beginning of mark 5s. Principles should still apply to the mark 4 and is consistent with Jakes comments. You also need a bit more rake for downwind in the Mark 4s and 5s. Exact tuning would depend on your mast, but its a good start. Jerry, PM me if you want a copy of the guide as it is no longer on the AHPC web site. There is also this quide on the Landenberger site, but I find it a bit hard to follow.
http://www.landenberger-onedesign.com/spip.php?article21
Hope this helps
Extract from Greg Goodall A class tuning quide. Date ??
Mast Rake
On our Auscat boats we set up the mast with about 5 deg. of aft rake for all conditions. We have found that it doesn't seem to make any significant difference if we change it for different wind conditions. Although we do increase the mast rake for rough water, i.e.. 1 meter+ waves.
On our boats we set the mast rake by using the trapeze wire. Measure the height of the trap ring off the deck at the front chainplate and then take the trap towards the stern. With normal mast rake the trap ring is the same height off the deck about 250mm behind the rear beam.
Rig Tension
Rig tension on an A-Class doesn’t need to be tight when compared to other classes. The tension is about 50 –60 Kg.
MAST SETUP
Spreader Rake, Diamond Tension and Mast Prebend.
Spreader rake.
Spreader rake is the method of tuning the fore aft stiffness of the mast below the hounds. The ideal amount of spreader rake is dependent on the fore-aft stiffness of the mast and to a lesser extent, the amount of luff curve cut into the sail. Stiff masts require more rake to make the mast bend sufficiently, soft masts require less rake.
The spreader rake is measured by placing a straight edge or string-line between the diamond wires at the spreaders and measure the distance to the back of the mast. On the Saarberg and Australian masts we are currently using 50 – 60mm of spreader rake.
To answer how much is sufficient rake can only be determined by sailing the boat and knowing what to look for.
If you have excellent height, but lack boat speed up wind and the boat does not want to accelerate in the wind gusts, then you need more rake. This helps the mast bend fore and aft which allows the sail to flatten and the leech to open in the wind gusts.
If you are lacking height and "grunt" in light weather, then you have too much spreader rake.
Diamond Tension
This primarily controls the side bends of your mast. Loose diamonds allow the middle of the mast to bend to leeward and the top of the mast to hook to windward. This tends to cause the boat to heel very easily in wind gusts. Very tight diamonds do the opposite.
Downwind, tight diamonds keep the mast bent reducing camber and power. On our boats the diamond tension is set at 30 - 34 on the loose gauge.
Re: mast pre bend [Re: Rolf_Nilsen] #163285
12/22/08 07:34 AM
12/22/08 07:34 AM
Originally Posted by Rolf_Nilsen
Jake,
Funny you should ask - it actually balanced out my helm a little more when I raked back more. I suspect my rudders are raked a little forward of the center of pivot. With the rake measurement taken from the forestay to directly over the rear access port I had a lot of weather helm making it a real beast sailing downwind in any kind of air. I would really struggle to keep it under control while making an adjustment or two because it wanted to round up so quickly. Upwind in 12 to 18 knots, the groove was very difficult to find and the boat felt like it couldn't get out of it's own way in puffs. No matter what I would do, I couldn't get the bow down under pressure. In light air, however, the boat as setup was a rocket.
I then raked it back to the position between the port cover and the handling in big air became dramatically better. I was shocked, actually, at how much better it had become. The constant struggle to keep the bow down and the boat charging when puffs hit was gone and it was a matter of making the minor trim adjustment to handle the extra pressure. What also surprised me was that the weather helm also became less dramatic...leading me to believe that the rudders are raked a little too far forward. I've got a new Ashby sail coming so I'm not planning to do any more tuning until then.
Re: mast pre bend [Re: Jake] #163292
12/22/08 08:26 AM
12/22/08 08:26 AM
Thanks Jake. That reflects my thoughts on the subject. Rake should be adjusted to the boat setup and the sailors, if the sailor is skilled enought to take advantage of it.
The "best practice" trimsheet did not suit us at all on the T with the sails we had. If we had sailed with stock sails, I guess "best practice" would have suited us well.
Re: mast pre bend [Re: Jake] #163606
12/28/08 02:49 PM
12/28/08 02:49 PM
Kiel, Germany
Baltic Offline
Baltic  Offline
Kiel, Germany
Jake,
do you expect recommendations for spreader rake / diamond tension / mast rake to come with your new Ashby-sail? I own a 2004 Ashby sail but I'm unable to get in contact with Ashby Sails to obtain the correct settings. If you could post the settings fpr your sail here or send me a PM, I could start with these on my boat - this would be very kind of you!
Kai
Re: mast pre bend [Re: Baltic] #163625
12/29/08 06:34 AM
12/29/08 06:34 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
" I'm unable to get in contact with Ashby Sails to obtain the correct settings"
GONE SAILING - BACK SOON!
Re: mast pre bend [Re: TEAMVMG] #163628
12/29/08 08:15 AM
12/29/08 08:15 AM
Southern Ontario
fredsmith Offline
fredsmith  Offline
Southern Ontario
I think Glen will be out of the office for a few days defending his A Cat world championship.
Fred
0 registered members (), 510 guests, and 82 spiders.
Posts267,056
