| more spinaker questions #16191 02/06/03 02:44 AM 02/06/03 02:44 AM |
Posts: 51 australia | hey F16, i am soon going too fit my taipan out to f16 so i have a few questions,any help would be great are carbon fibre spinnaker poles f16 legal ,is there much differense betwen a aluminium pole if you got the cash 4 it has any 1 got a clean strong fitting for the foward pole braces to fixed too the pole how high should i set the pole of the briddle and how much prebend should i put in how many snuffer patches should i use, and is there much of a advantage of haveing the kite made out of siliconised material any help would be good regards kurt taipan 4.9 aus 029 | | | Re: more spinaker questions
[Re: taipan029]
#16192 02/06/03 03:58 AM 02/06/03 03:58 AM |
Posts: 183 | Kurt
Caron poles are legal for F16, and should weigh about 2/3 that of a similr strength aluminium one.
Usually we just attach an eyestrap to each side of the pole for both the forward and mid pole bridle wires, for carbon you will need to bolt these on. Tape every fitting on the mast, diamonds, pole shrouds etc. that the spinnaker could possibly snag on, also make sure your battens are as short as you can get away with otherwise the halyard will get cought round the back of them.It also helps to route the halyard thru the spreaders to stop it flapping about so much.
You will need three patches and use the slippyest material you can get, and even then spray silican on the sail and the shute every time you go sailing.
Keep the pole as low as you can so that you can get the maximium luff length, unless you've already got the sail then you will need to measure from the mast down to where the pole needs to end up, distance from where the head of the sail reaches the mast to the end of the pole needs to be about 96% of the spinnaker luff length. Use about 4 inches of prebend in the pole.
John Pierce
[email]stealthmarine@btinternet.com /email] | | | Re: more spinaker questions
[Re: taipan029]
#16194 02/06/03 08:49 AM 02/06/03 08:49 AM |
I personally don't consider carbon spi poles much of an advantage in relation to alu ones. Weight savings are in the order of 500 grams at max and the cost is considerable higher. I personally use a simple not anodized pole of about 20 AUS$ and that works great. Anodizing makes it look better but isn;t necessary. Carbon looks cool and saves a few grams.
Both carbon and alu are allowed under F16 rules, as John already answered.
My pole wires are made of dyneema (spectra ?) lines and work well. I have not problems with it. Cheap simple and effective. As often seen on tornado's ou can drill little holes in your bows, fill them with resin and filler to make the holes strong, robust and watertight. Run the line through the hole and tie a figure 8 knot in the end. When the holes are not to wide these should hold and they held on my boat (P18) for three years already.
On the pole. I would fit one eyestrap on top near the end and fit a small pully with spring to it. This will be your tack yaryard pully. The pole support wires will just be run through this eyestrap and back down the other side of the pole and be tied of to itself maken a loop running the eyestrap. This puts no extra forces on the eyestrap and gives the lines a good curve radius retaining strenght and preventing wear.
I personally use a loop in the lines and push the entire loop through the eyestrap round the pole and than run the other end of the line through the loop itself. The loose that I'm left with I then run through the hole in the bows and tie a figure 8 knot in it. But then again I can leave the pole rigged during the whole summer as I have beach site boat parking.
I will use a different system for my new boat, something I learned from my kiting days. A quick release and fixing system. Really simple but complex to explain in words.
If you fit support line to the middle of the pole than you can get away with a light alu pole.
Prebend, just a little. enough to make sure that the pole will not buckle downwards when loaded. Lift the boat by the pole and see how the pole behaves that should be a pretty good test.
[Re: Wouter]
#16195 03/02/03 05:12 AM 03/02/03 05:12 AM |
Posts: 51 australia | 1 more question for you taipan f-16 sailors how high sould i set my pole of the standard taipan sloop briddle for the goodall 17.5sqm kite regards..kurt taipan aus 029 (soon to be taipan f-16 this week) | | | Re: more spinaker questions
[Re: taipan029]
#16196 03/02/03 06:27 PM 03/02/03 06:27 PM |
Posts: 58 Canberra, Australia | I usually have mine somewhere in the vicinity of 20cm below the centre of the bridle but it really doesn't have to be that exact. The end of my pole is set up with wire strops with some 2mm spectra on the end to attach to the bows. On the beach I attach the mid pole rope to the bridle then loosely tie on the pole ends. I hoist the kite and then adjust the 2mm spectra ends to the bows so that the kite luff is at the right looseness (now I'm being really technical ) for the prevailing conditions. To be perfectly honest its pretty much the same most of the time anyway. The height of the end of the pole will depend on the luff length of your kite and the hoist height on the mast. Then if there is too much bend in the pole (or not enough) I adjust the bridle strop to suit. Hope this helps!
Taipan 4.9 AUS129 AlphabetSoup
[Re: ABC]
#16197 03/02/03 09:53 PM 03/02/03 09:53 PM |
I pretty much fit the spi gate in the mast which is limited by the F16 rules to 7,50 mtr above the top of the main beam and by the advice giving by Goodall yachts (is the same)
Than on a day with a mild wind. I fit the pole with its end about 0,5 mtr. beve the bows and hoist the spi and see how it sits. Adjust your pole to the cut and luff curve of your spi. Often this means moving the end of your pole up or down a few centimeters (max 15 cm or so)
I'm unfamiliar with the Goodall 17,5 sq mtr. spi so I can't help you there. Of course Goodall Yacht sails themselfs might give you a good starting point / height
[Re: taipan029]
#16199 03/03/03 12:36 PM 03/03/03 12:36 PM |
Posts: 9,582 North-West Europe | >>do any of you taipan f-16`s use the jib barber haul (tweaker) for the spinnaker.
No, just leave it off when you plan to sail with a spi. The jib as well the main itself are sheeted significantely tighter with a spi than without one. This pretty much cancels the need for barber haulers. And besides the lines only get in the way.
If you are using a tramp bag then I advice you to pull the forward trap line towards the sidestay by running the bungee through a ring which is tied to the chainplate with a short piece of string. It will open up the area throught which you will hoist and retrieve your spinnaker.
>>and any one no of any snuffer systems that are made in aus besides the nacra 1.
Like you said Goodall is designing one. You sould also order the midpole fibre ring (other one than the Guck piece) and make up the bag and sorts yourself quite easiliy. The big diameter ring is becoming very popular over here. The Nacra tube was first used on the Tiger but I saw Gerard Loos sail with the ring and bag and leave the tube on the beach at the Dutch nationals.
>and i have talk too goodall yach sails about hoist hight etc; and they are developing a snuffer soon
If you want to measure in a F16 your maximum hoist height (block or gate) is set at 7,50 mtr above the main beam. As the Taipan class is not likely to adopt a spi I advice your limit yourself to that measurement. From memory I believe that Goodalls height was 2 or 3 cm below the F16 hoist height limit.
[Re: ABC]
#16202 03/04/03 01:37 AM 03/04/03 01:37 AM |
Posts: 51 australia | andrew got any tips on making one like how wide the opening should be how should i attach it too the pole,and photoes thanx regards..kurt | | | Re: more spinaker questions
[Re: taipan029]
#16203 03/04/03 03:41 AM 03/04/03 03:41 AM |
Posts: 183 | Kurt
We do 2 types of mid pole snuffer, large diameter ring and one similar to the guck type, e-mail me for specs and prices
regards
john
John Pierce
[Re: taipan029]
#16205 03/06/03 11:56 PM 03/06/03 11:56 PM |
Posts: 58 Canberra, Australia | Hi Kurt, The way I made it was a bit of a trial and error process. The one I have on the boat is actually the fourth ring that I've had on the boat, but it needn't be that way. We made the rings on the spare peice of aluminium tube from the end of the spinnaker pole. From memory it was easier to get 4m sections from the aluminium manufacturer and we had to cut them down to 3.4m or whatever the measurement is so we had about a 600mm offcut. I know I'm mixing unit measurements but I'm sure you'll understand.. The spinnaker poles were 38mm diameter. We created the rings in two different manners. Michael put the pole offcut in the vice and then stuck some packing tape on it so that the fibreglass wouldn't stick and then set about attaching the ring. I decided to cut some sections off the offcut about 8-10cm in length and then bent them out so that they slid over the pole offcut and would slide over the pole as well. The idea being that we could move the ring up and down the pole to find a good place for it before drilling holes and riveting it into place. As it turns out, both systems seemed to work fine. Michael just rivited through the fibreglass into the pole. Anyway, we got some vacuum tube (which is just ribbed plastic pipe about 40mm diameter available from hardware stores) and made a ring which we thought would do the job and then used some fencing wire to tie it to the pole cutoff. In my case I tied it around the stretched out offcut peices around the offcut. Then its just a matter of going crazy with the fibreglass . The first one I made was just simply too small - I have no idea what I was thinking but the hole in the middle was only about 18cm wide. Sure, laugh all you want but I honestly had no idea what I was doing, even if the idea was going to work and be strong enough. The second one I made (which is probably the most robust to be honest) was much bigger (about 30-32cm hole size) and was made with a twist in it to open the bag up a bit which worked reasonably well but was just the tiniest bit too small. The twist worked well but with a new spinnaker it just didn't really want to all bunch up and suck into the hole all that well. So I had to make another one. By this time I was wondering if I shouldn't have just spent a whole chunk of money and bought one of the aluminium ring thingys but fibreglass, vacuum tube and tie wire aren't all that expensive so I made number three. I thought that the Guck snuffer system looked quite good so I made the thrid one bigger (about 35-38cm) and for some reason I made it flat like the Guck one instead of having a twist in it. Unfortunately this ring had the same problem as the second one. The kite would go through the hole fine bit it also had to open up the bag and turn the corner into the bag as it went so it didn't really work any better than the second one. This would be why the Guck systems have the fibreglass turn in the bottom of them. Because the vacuum tube is plastic and smooth, the fibreglass actually doesn't stick to it, it just acts as a backbone. So what I did was to cut the fibreglass with a hacksaw in two places about 45 degrees around the ring and then put a twist in it and glassed it all back up again. This isn't even making sense to me as I'm writing it but I'll take some photos this weekend and post them up next week and you'll have a better idea of what I mean. Hope this helps.
[Re: ABC]
#16206 03/07/03 08:33 AM 03/07/03 08:33 AM |
Posts: 344 Arkansas, USA | Check out this description of how to build a vacuum-bagged fiberglass snuffer ring from Jake- Jake's snuffer ring Kirt
Kirt Simmons
Taipan #159, "A" cat US 48
[Re: ABC]
#16207 03/08/03 05:13 PM 03/08/03 05:13 PM |
Posts: 915 Dublin, Ireland | I hope that 18cm is not laughable. I have just received my snuffer kit for my Spitfire. It is slightly rectangular, but the hole in the middle is about 21 * 19. Thats not a lot more than 18. I have not fitted it yet, but I assume that the spinnaker will fit into it. Does anyone in Europe know who makes the lubricant for spraying on the ring and the sail ?
Dermot Catapult 265
[Re: ABC]
#16208 03/08/03 11:03 PM 03/08/03 11:03 PM |
Posts: 51 australia | hey thanx for all the help (it`s all good)those pics would be great. i tryed my spinnaker out on friday after noon with my brother(only 12 and doesnt now a thing, and im only 14 but i have been sailing my whole life) well, the wind was about 12-15 knots (and just about dark) we poped the kite and we just about got thrown of the boat. we were double trapezing doing 20knots+ boat speed the boat was under control, i hade the helm and spinnaker and my brother the traveler. the only problem`s i found was the bag on the tramp a bit messy (a snuufer would of been handy) and the halyard getting knotes but i still managed to get the kite down safly, then on saterday i went single handed with the kite,the whole system worked well until the wind picked up(15knotes+), then i started to get in a mess,the halyard had knotes and the sheets were over board ,a bit of a spageti factory. and to top that of i almost pitch polted (i only had the main up) while chasing some other cats down i was coming on to them like a train. i had my foot in the feet loops and trapezing but they didn`t help. i ended up face first in the mast ouch.. but i didnt capsize lucky me finaly today (sunday) every thing went well the wind was 25+ i was with my grandad he was on the helm and i was out trapezing with the spinnaker sheats in my hand ,and i thought i was fast on friday i think i did some were near the 25+ knotes of boat speed and loving it i think ill invest in a gps speedo. and the spinnaker work went perfectfor 1s , i was a bit worred about the mast but it held up quit well wat a mouth full,hope u like my story (sorry about the spelling) im gona get some pics next week or so and post them for u regards kurt taipan 4.9 aus 029 | | | Re: more spinaker questions
[Re: ABC]
#16209 03/09/03 06:09 AM 03/09/03 06:09 AM |
Posts: 183 | Kurt
Throw the halyard over the back of the boat after you've hoisted the kite, then you won't get the knots.
john
John Pierce
[Re: john p]
#16210 03/09/03 07:13 AM 03/09/03 07:13 AM |
Posts: 915 Dublin, Ireland | Or tie the end to the mast step, then while you may get loops , you will not get knots.
Dermot Catapult 265
| | | Thankls for the report, make my winter bearable !
[Re: taipan029]
#16211 03/09/03 08:38 AM 03/09/03 08:38 AM |
With respect to the spinnaker, it definately pays to start at 10 knots, rehearse the procedures of setting and retrieving and than work your way up to 20 knots or so. Doing it by hand may feel awkward in the beginning and cumbersome but with a little practise you work out a way of doing things that will work very well. Only problem you will be faced with each time are the jib sheet lines on the Taipan. I've worked with snuffer before and they are handy but please don't think that a snuffer is much easier all of the time.
I tie my halyard to the mastfoot or an eyeled near the mast and through to loop over the back. An alternative I've become to use more often when signlehanding is to drop the halyard on the tramp as I go and never touch it again. Often it lies on the front part where you don't move about anyway when signlehanding. Than when retrieving I uncleat the halyard and it smoothly runs through the cleat without any knots. Trick is the not touch it, tie it up or move it about with your knees or feet between sets and drops.
for my own boat I working on a pully system that will pull away the halyard together with the double block near the spi pole or the tack of the spi itself. I'm confident that that will work.
What kind of bag are you using, with zippers or velcro, hobie style or side load style ? Have you pulled your crew trapeze wire afte to the sidestay ?
Best maybe is to perfect the manual setting and retrieving when you sail the boat without the jib. Let your crew focus completely on the spi.
It is really nice to see you and your brother having so much fun !
[Re: taipan029]
#16214 03/09/03 06:59 PM 03/09/03 06:59 PM |
Joined: Apr 2002 Posts: 170 Australia (Queensland) Berthos
Posts: 170 Australia (Queensland) | Great Story Kurt!! Sailing with a kite on a Taipan with a combined crew weight of (I'm guessing) 90 odd kilos in 15knots is an impressive acheivement. You must have excellent skills and no fear - look out Glen Ashby! I don't sail with a spinnaker myself as yet but suspect that if you and your crew can learn to set and douse your kite off the tramp from a bag and do it efficiently you will have a less windage on your kite and won't suffer as much of an upwind penalty as those boats using snuffers (others may wish to comment on this) This could give you a winning edge. Having the skill of launching from a bag would also help you if ended up sailing one day on a type of boat that always launches from a bag or off the deck eg. 18'skiff, 49er, ocean going yacht etc. To sail single handed without a snuffer would be practically impossible though. Rick White's book, "Catamaran Racing for the Nineties" has an excellent chapter on sailing with a spinaker which would probably be of use to you. In fact the whole book is filled with useful information. I enjoyed your story so much I'm going to upload it to the Taipan website if you don't mind: http://www.taipan.asn.auRob Wilson Taipan 4.9 AUS175 | | | Re: more spinaker questions
[Re: Berthos]
#16215 03/09/03 08:03 PM 03/09/03 08:03 PM |
Posts: 58 Canberra, Australia | Sorry all, camera unavailable on the weekend so will have to wait until next week to take and upload pictures. 18cm might be a little bigger than it was now that I think about it. Can't really measure again because I took out some frustration on it - also found out how strong it was too Also, the size of your ring will depend on how big your kite is (mine's slightly bigger than F16 at just over 18sqm) and how many retrieval holes you have. I have three which makes a fair bunch when its going in. cheers,
[Re: Berthos]
#16217 03/10/03 12:24 AM 03/10/03 12:24 AM |
Posts: 51 australia | rob go ahead and post it on the taipan web site, most of the time i sail single handed 74kg (now with kite) i go out about 4 times a week i try to get out as much as possible id love too bet gleen ashby [color:"blue"] [/color] [color:"blue"] [/color] [color:"blue"] [/color] i tryed get the kite ready be for the f-16 states but no luck or trailor but ill try make it next year it is actualy verry easy to sail with a spinnaker from my point of veiw ,others may not belive so, and i do sail on a few other boats scud f-28R a few keel yachts but cats are the way to go thanx for all the help every one its been a great regards kurt taipan aus 029 | | | Re: Trailing spinn. halyard
[Re: john p]
#16218 03/10/03 05:50 AM 03/10/03 05:50 AM |
Joined: Nov 2002 Posts: 612 Cape Town, South Africa Steve_Kwiksilver
Posts: 612 Cape Town, South Africa | Sounds like a good idea to throw the halyard overboard to straighten it out, but with 20m of rope trailing behind you another problem can occur : Another boat could run over the halyard & get tangled, this happened a few weeks ago at a big regatta with keelboats, dinghies & cats - about 400 boats on the water. A Peterson 33 (about 4 tons) ran over the trailing halyard of an Inter-20 & got it wrapped in the rudder-pin (Guess who won that altercation ?) The Peterson carried on straight, the I-20 slowed down quickly, stopped dead, and then charged off backwards with the spinn. still up ! This presented a new problem, since the I-20 skipper couldn`t drop the spinn with 4 tons of keelboat on the end of the halyard. Luckily he had a hook-knife - cost him a new halyard. Unfortunately he had no rights would there have been a protest - his halyard was not in it`s normal sailing position at the time of the incident. Luckily both parties saw the humor to it & there was no protest, just a friendly exchange of words. I`d love to have seen the I-20 skipper`s face doing 6 knots backward with the chute up, though ! If you fit a snuffer, the halyard is a continous line to the spinn. patches & doubles up as a retrieve line - it will seldom get knotted since there is very little slack in it if you get the length right. | | | Ahh but that is why ...
[Re: Steve_Kwiksilver]
#16219 03/10/03 11:38 AM 03/10/03 11:38 AM |
Posts: 9,582 North-West Europe | Ahh but that is why we here now fix the end of the halyard to the mast base and only have (8 + 4) mtr / 2 - 2,5 mtr = 3,5 mtr of line trailering behind the boat. Much less than the 8 + 4 - 2,5 = 9,5 mtr of the older methode.
8 mtr. is the distance from bag to spi gate 4 mtr. is the excess of line after the tack is pulled out. 2,5 mtr. is the length of the trampoline and hulls which are behind the mast foot.
741
guests, and 84
