| Reefing a main #163535 12/26/08 09:29 AM 12/26/08 09:29 AM |
Joined: Jun 2001 Posts: 1,911 South Florida & the Keys arbo06 OP
Posts: 1,911 South Florida & the Keys | Good Morning, we survived Christmas....
I am considering adding reef points to the main of the ARC21. What other mods are needed to the halyard etc?
I forgot to mention that it is boomless.
Thank you,
Eric Arbogast ARC 2101 Miami Yacht Club | | | Re: Reefing a main
[Re: arbo06]
#163561 12/26/08 11:14 PM 12/26/08 11:14 PM |
Posts: 493 Minnesota | Not related to your question, but...
Why do they call it "reefing" the main? I assume the reef knot got its name from tying up a reefed sail with this knot. But why the name "reef"? Does it originate from sailing through a reef, with better control and less power?
| | | Re: Reefing a main
[Re: Jeff Peterson]
#163575 12/27/08 10:10 AM 12/27/08 10:10 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Why do they call it "reefing" the main? I assume the reef knot got its name from tying up a reefed sail with this knot. But why the name "reef"? Does it originate from sailing through a reef, with better control and less power? Here is what I think: "Reef" apparently is a word that originated in Old Norse, "rif," meaning "ridge." Originally, sails had strips sewn across them, which probably were ridged above the surface of the sail, and these reinforced "ridges," (which they called "rifs", probably pronounced "reefs") were used as the places at which to reduce sail. Whaddaya think? Maybe Rolf would know, or Wouter, because "rif" also is an obsolete Dutch word. Apparently, it also appeared in Mid English as "riff."
| | | Re: Reefing a main
[Re: JJ_]
#163587 12/27/08 07:33 PM 12/27/08 07:33 PM |
Posts: 1,911 South Florida & the Keys | Yeah, but how do I take an old main and add a reef system to it? Should I just shorten it and use it in special situations?
[Re: davefarmer]
#163630 12/29/08 10:33 AM 12/29/08 10:33 AM | andrewscott
| andrewscott
Unregistered | I am no expert, but if you have no boom... and shorten the sail by removing bottom panels... your mainblocks... traveler will have different angles and you will need to have allot more main sheet to handle the extra space. If it is a foot higher and you have an 8-1 block.. you will need 8 feet more sheet.
another consideration is the hook on top. If you have a hook and ring system (and you wish to lower the top of the sail down) you will have to either flip the boat to take the ring off... or come up with some way of twisting the ring for lowering the sail. Perhaps a small line tied to the bottom of the ring.... | | | Re: Reefing a main
[Re: arbo06]
#163631 12/29/08 11:12 AM 12/29/08 11:12 AM |
Posts: 1,152 tampa, fl | Instead of going through putting reef points in your main, wouldn't you be better served to find a main from a N6.0 or 5.8 that is smaller than your sail and already set to accept a boomless set-up? Maybe a little more costly up front, but I think you'll end up with a better set-up.
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: Reefing a main
[Re: whr241]
#163694 12/30/08 09:21 AM 12/30/08 09:21 AM | andrewscott
| andrewscott
Unregistered | I would love to learn more about your rigid extension (and see a pic or 2)
thanks | | | Re: Reefing a main
[Re: arbo06]
#164313 01/07/09 01:59 PM 01/07/09 01:59 PM |
Posts: 1,200 Vancouver, BC | Yeah, but how do I take an old main and add a reef system to it? Should I just shorten it and use it in special situations? Track down HobieGary (aka Gary Freisen; sometimes on this forum...always on So_CA_Beachcat_Sailors yahoo forum) as he has worked out reefing on his Mystere.
| | | Re: Reefing a main
[Re: Tornado]
#164315 01/07/09 02:16 PM 01/07/09 02:16 PM | andrewscott
| andrewscott
Unregistered | i saw pics of HobieGary's set up and even talked to him a little about it.. i would still like to see whr241's rigid extension | | |
3,236
guests, and 277
