Spinlock pictured on homepage.... #16465
02/18/03 11:12 AM
02/18/03 11:12 AM
42.904444 N; 88.008586 W
Todd_Sails Offline OP
I think it's a ronstan, anyway, when I retorfitted my N6.0 with a snuffer rig, I used one like this for the spin halyard. The second time I used it, it wouldn't hold the sheet in heavy air!
Now, I do use some kind of high tech, no stretch line, expensive line ( can't 'member the name)
I took it back to West Marine, and got one, that looked the same size, by the same manufacturer, but, on the top of the cleat,
it has the word 'ALLOY' stamped on it in plain sight.
I'm not slamming anything here, just relating personal experience.
The current one, by the same manufacturer, works GREAT!
F-18 Infusion
#626- SOLD it!
Re: Spinlock pictured on homepage.... [Re: Todd_Sails] #16466
02/18/03 12:08 PM
02/18/03 12:08 PM
Wilmington,NC
Dlennard Offline
Dlennard  Offline
Wilmington,NC
Todd
The spinlock is made by spinlock and the first ones that came out did not have the alloy cam (the alloy cams have white letters on them). If you contact spinlock they will send you a free replacement cam. West Marine must not move some of there stock very fast and there is a lot of old design products on there shelves. Just look at there Harken stock there are very few new cabro blocks on there shelves.
Re: Spinlock pictured on homepage.... [Re: Todd_Sails] #16467
02/18/03 12:35 PM
02/18/03 12:35 PM
Pensacola, Florida / Katy, Tex...
Cookie Monster Offline
Todd,
The Spinlocks are great, but be careful with heavy loads and small line. You may want to think about sewing on a sleeve of bigger diameter line (about a foot long), just where the cam bites the line. This gives a much better bite and will help keep it from slipping under heavier loads. You don't need a spinnaker to get away from you too many times, before you figure this one out.
Don
Don Cook ARC22 #2226 ADRENALIN
Re: Spinlock pictured on homepage.... [Re: Cookie Monster] #16468
02/18/03 12:45 PM
02/18/03 12:45 PM
Thanks David, and Don,
As I said, they replaced the spin lock free, and now it works just fine with the alloy cleat. I thought maybe they were making both, and wanted to point out the better product.
Todd
F-18 Infusion
#626- SOLD it!
Now have all Spinlocks available [Re: Todd_Sails] #16469
02/18/03 05:02 PM
02/18/03 05:02 PM
RickWhite Offline
RickWhite  Offline
The new store is slowly getting filled and we now have most of the Spinlock Products ready to ship.
Ad Police: This is my site.
Rick
Rick White
www.onlinemarinestore.com
I used it for a Jib halyard and it did not work... [Re: Todd_Sails] #16470
02/18/03 05:30 PM
02/18/03 05:30 PM
Columbia South Carolina, USA
dave mosley Offline
dave mosley  Offline
It was not the line slipping, it was uncleating itself, I assume under load , but not sure since it was on the mast and got alot of slamming around with gybes and tacks and such. I will have to look at it and see if it is alloy. What is the replacement made of? It was bought at West Marine.
David Mosley
www.seacats.org
Re: Spinlock pictured on homepage.... [Re: Todd_Sails] #16471
02/19/03 02:01 PM
02/19/03 02:01 PM
Mark Meis Offline
Mark Meis  Offline
The spinlock's work well but sometimes believe it or not when you first go out on the water and pull the shute up you need to put some water on the cleat and line. Then she will hold. My memory is that the cleat wears out after a season or so on a cat. 1/4 inch spinnaker halyard would probably be best and actually easiest to handle. This cleat gets a lot of abuse.
Mark C28R no. 140 Houston, TX
0 registered members (), 214 guests, and 40 spiders.
