Replacement luff track installation on comp tip #168857
02/19/09 05:14 PM
02/19/09 05:14 PM
tedb Offline OP
tedb  Offline OP
I have to replace the luff track on my h20. Any does and donts? I am actually most concerned with removing the old track without damaging th comp tip.
BTW There seems to be a problem with the search engine. When I click on the thread I want to search, I am redirected to the current main index
Re: Replacement luff track installation on comp tip [Re: tedb] #168859
02/19/09 05:47 PM
02/19/09 05:47 PM
Santa Cruz, CA
SurfCityRacing Offline
Santa Cruz, CA
Hey tedb,
I always start with a screwdriver at the junction between the extrusion and tip. Go real easy with the screwdriver against the comptip itself, it will chip. Once you get it started, just grab it and peel it to the head.
Use a fine toothed hacksaw to trim it to length. Yeah, they're all different. I mark them with masking tape to make sure I get a square cut on the track. A chop saw with an abrasive blade works well if you have one. I use a radial arm saw with a small-toothed blade.
Use a file to bevel the sail track so the sail won't get snagged. The Leatherman file size is perfect. Do it before you install it. After you get it trimmed and beveled snap the new track into place. Pin one edge under the lip on the comptip and work your way down. I always exagerate the track down toward the alu/tip junction and fine tune the height with a soft blow hammer to get it perfect. Also, if it looks too long, don't snap the track all the way down, just bite the bullet and take it off while it's easy.
One more thing. Make sure that the lips that hold the track onto the comptip are clear of any debris that could keep the track from snapping into place. A quick hit with a knife will clean out any left over fiberglass/ fairing putty.
Hope that helps!
Re: Replacement luff track installation on comp tip [Re: tedb] #168947
02/20/09 01:45 PM
02/20/09 01:45 PM
Clinton, Mississippi
rattlenhum Offline
rattlenhum  Offline
I did my H-16 last fall and it was easier than I had anticipated. Never had to use too much force during either the removal or installation. In fact, once I pried a little to get it started off, I did the rest by hand except for having to trim 1/8 inch or so with a fine tooth hack saw. I did take the time to clean it well before installation, and IIRC I used a little liquid dishwashing soap for lubrication prior to installing.
Jerome Vaughan
Hobie 16
0 registered members (), 188 guests, and 47 spiders.
