Shroud load #169226
02/23/09 05:39 PM
02/23/09 05:39 PM
Clear Lake,Texas
TreyG Offline OP
TreyG  Offline OP
Clear Lake,Texas
What is the normal/max amount of load tension on the shroud and bridles of a typical F18 or Inter 17?
Trey
Nacra 5.2 "Silver Bullet" #333
TCDYC
Re: Shroud load [Re: TreyG] #169228
02/23/09 05:59 PM
02/23/09 05:59 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
Given that 3mm shrouds are rated to ~1200 lbs...that's gonna be about your max tension ;-)
If you're talking about how much tension you should set your boat up with...The tornado is setup with a 24-30 range using the newer Loos gauge. Not sure what that works out to in pounds.
The main idea is to create enough tension in the forestay to prevent the jib luff from bowing excessively when there's not much mainsheet load...such as in light air.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: Shroud load [Re: Tornado] #169236
02/23/09 06:53 PM
02/23/09 06:53 PM
TeamChums Offline
TeamChums  Offline
I run mine at about 250lbs.
Lee
0 registered members (), 276 guests, and 66 spiders.
