Re: what type of fid do you use? [Re: Team_Cat_Fever] #173602
04/02/09 09:08 AM
04/02/09 09:08 AM
I've got a set of the Samson fids and I hardly ever use them. Granted, I'm not splicing covered line very often - mostly 12 strand Dyneema / Amsteel and the like. I use a simple splicing needle and it does everything I need to do.
For the model sailboats, I took a moderately sized sewing needle and blunted and polished the end. It works great for splicing 1/32" spectra line for the r/c boat. There's not one single knot on my whole US1M!
Re: what type of fid do you use? [Re: Jake] #173606
04/02/09 09:15 AM
04/02/09 09:15 AM
andrewscott
andrewscott
Thanks Jake...
needles like this style?
Re: what type of fid do you use? [Re: tami] #173608
04/02/09 09:18 AM
04/02/09 09:18 AM
andrewscott
andrewscott
Originally Posted by tami
I oughta be getting a commish from Toss, Hampidjan and Précourt, huh? I'm just real pleased with their stuff, so I tell everyone. Sorry if it's a belaboured point.
Yes,.. you should at the least.. get a free t-shirt!. Not a "belaboured point", your input has been very valuable... thanks
Re: what type of fid do you use? [Re: ] #173615
04/02/09 10:21 AM
04/02/09 10:21 AM
Originally Posted by andrewscott
Thanks Jake...
Not quite - even more simple than that.
Though I've become a big fan of the brummel style eye-splice as of late...that shows a simple eye splice in process which will hold but should receive a proper lock stitch for security.
Re: what type of fid do you use? [Re: Jake] #173616
04/02/09 10:29 AM
04/02/09 10:29 AM
andrewscott
andrewscott
[quote=Jake]Not quite - even more simple than that.
Cool. and when you are done with your splice... you can make shish kabobs!
Re: what type of fid do you use? [Re: ] #173623
04/02/09 11:00 AM
04/02/09 11:00 AM
andrewscott
andrewscott
Does the Brummell not need to be locked stitched to secure?
http://www.neropes.com/SPL_12Strand_EyeSpliceBrummel.aspx
Re: what type of fid do you use? [Re: ] #173639
04/02/09 12:14 PM
04/02/09 12:14 PM
Gulf Coast
tami Offline
tami  Offline
Gulf Coast
The problem I see with the needle that Jake has pictured is that the little hook bit would tend to snag fibres inside the core. It would just take a bit more care when drawing the tail through, is all.
(That 'needle' is available at fabric stores - it's used for drawing elastic through casing.)
No, you don't need to lockstitch a correctly done Brummel splice. It locks itself. (That said, I do lockstitch them anyway.) Brummel splices are also known as Möbius Brummel splices. The caveat is CORRECTLY DONE.
A simple tail bury, as Jake has pictured, in hightech low friction lines, will be just fine as long as the line is loaded (the 'chinese finger puzzle' effect).
What happens (disclaimer) IF YOU DON'T LOCKSTITCH A SIMPLE BURY IN HIGH MODULUS LINE is that when the line is NOT loaded, the low friction of the slick high modulus line enables the buried tail to slip right out.
Re: what type of fid do you use? [Re: tami] #173649
04/02/09 01:01 PM
04/02/09 01:01 PM
League City, TX
flumpmaster Offline
flumpmaster  Offline
League City, TX
Chris, are you using those tools to splice covered line? I gota know your technique 'cause I'd be tearin' my hair out.
Only for core to cover splices - not for eye splices on double braid line. Most of my splicing is high tech single braid. I don't use brummel splices - I interlock the tail three times then bury a few inches with a taper. I then lock stich - as high tech splices can certainly open up if loaded and unloaded (e.g. trap lines). Perhaps I should stop being cheap and throw down for the Toss wand.
I use haemostats (see picture below) as an extra pair of hands when splicing, as well as blue painters tape to secure line to the fid and a sharpy marker to lay out the splice and identify where to cut lines for the taper.
I learnt my stuff from Jesse Fulmer who is a full time rigger.
Chris.
Re: what type of fid do you use? [Re: tami] #173658
04/02/09 01:30 PM
04/02/09 01:30 PM
No hook - it's just a hole (closed) in the end of the needle that you thread the line through. It's really easy to use.
Re: what type of fid do you use? [Re: ] #173659
04/02/09 01:31 PM
04/02/09 01:31 PM
No, it's a tricky splice to carry out - especially around something like a thimble...but it's interwoven through itself and cannot come apart. You have to see it to appreciate it.
Re: what type of fid do you use? [Re: Jake] #173678
04/02/09 03:45 PM
04/02/09 03:45 PM
andrewscott
andrewscott
Is this a good method to try this knot?
http://www.precourt.ca/brummel_splice.pdf
Re: what type of fid do you use? [Re: ] #173714
04/02/09 07:59 PM
04/02/09 07:59 PM
I haven't seen that tutorial before - but yes, that is a good one to go by. The Samson Rope tutorials have some additional detail regarding tapering and a way to do it without unstranding the line...personally, I put the line on a table and cut it with a razor blade at a high angle to get a taper on the tail. It's not as perfect or as long a taper as picking and cutting out pairs of strands but for what we use this kind of line for (small control lines), it's fine.
Re: what type of fid do you use? [Re: Jake] #173716
04/02/09 08:08 PM
04/02/09 08:08 PM
andrewscott
andrewscott
cool,
thanks..
0 registered members (), 543 guests, and 27 spiders.
