I hate harnesses! #173741
04/03/09 07:55 AM
04/03/09 07:55 AM
pgp Offline OP
pgp  Offline OP
Anyone ever tried sliding seats or planks on a cat? Would it be legal on my F16? wink
http://www.youtube.com/watch?gl=AU&hl=en-GB&v=zgdo4p90jHo
Pete Pollard
Blade 702
Re: I hate harnesses! [Re: pgp] #173742
04/03/09 08:11 AM
04/03/09 08:11 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
I hate harnesses!
Volunteer for R/C duty?
Re: I hate harnesses! [Re: ThunderMuffin] #173743
04/03/09 08:14 AM
04/03/09 08:14 AM
pgp Offline OP
pgp  Offline OP
Yep. Among other things. You?
Pete Pollard
Blade 702
Re: I hate harnesses! [Re: pgp] #173745
04/03/09 08:23 AM
04/03/09 08:23 AM
Portland, Maine
Portland, Maine
I certainly do my fair share of R/C duties. Three regattas last year.
I was simply mentioning it as an alternative to wearing harnesses smile
Re: I hate harnesses! [Re: ThunderMuffin] #173747
04/03/09 08:28 AM
04/03/09 08:28 AM
pgp Offline OP
pgp  Offline OP
I was hoping to get some input from the Tybee types about the IC sliding seat. It seems to have worked well for a long time.
Pete Pollard
Blade 702
Re: I hate harnesses! [Re: ThunderMuffin] #173748
04/03/09 08:29 AM
04/03/09 08:29 AM
andrewscott
andrewscott
you can super glue a park bench to your hulls smile
ps those canoes are amazing
Re: I hate harnesses! [Re: ] #173751
04/03/09 09:11 AM
04/03/09 09:11 AM
Portland, Maine
Portland, Maine
AFAIK, in the Tybee We've always used harnesses.
The old Worrell guys in the development days did some crazy stuff with racks that went up and down depending on the tack you were on.
Maybe you should just get some wings.
Re: I hate harnesses! [Re: ThunderMuffin] #173752
04/03/09 09:20 AM
04/03/09 09:20 AM
Eastern NC, USA
tshan Offline
tshan  Offline
Eastern NC, USA
Fun in the Sun had some Goodall harnesses that looked like they would be comfortable. Anyone seen/used those?
Re: I hate harnesses! [Re: ThunderMuffin] #173753
04/03/09 09:26 AM
04/03/09 09:26 AM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
Tah dah! Do magnum sailors even where harnesses anymore?
F18 USA 242
http://www.solarwind.solar
Re: I hate harnesses! [Re: David Ingram] #173761
04/03/09 09:47 AM
04/03/09 09:47 AM
I dunno - but they do try to fly (and fail miserably).
Re: I hate harnesses! [Re: tshan] #173762
04/03/09 10:01 AM
04/03/09 10:01 AM
M
mini Offline
mini  Offline
M
I do not know about you but lacing a strap across my nuts is the definition of UNcomfortable. My first Hobie harness was that way and was about enough to send me to mono-hulls.
Try a real full harness (one with leg straps) if you get fatigued. The fatigue issue I always had was no so much from the trap position in long distance stuff, but getting uncomfortable looking constantly in the same direction. It is worse in light air when not on the tramp as you typically are sitting awkwardly, looking up at extreme angles and tense from willing your boat to move that little bit faster so you can get out on the trap to relax.
If you have wings and a trap system, you gain no advantage in ease. If you do not have a trap, then you will end up hiking, and if you have spent any amount of time trying to hike with your current straps, you will agree trapping is way the better way to go.
Re: I hate harnesses! [Re: Jake] #173785
04/03/09 12:38 PM
04/03/09 12:38 PM
LULz DELIVERED! specially the comentary "WOU WOU OOOOOH! I got that to".
Re: I hate harnesses! [Re: Robi] #173793
04/03/09 03:40 PM
04/03/09 03:40 PM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
Todays crotchless harnesses, with lumbar supports, etc., are very comfortable. Is this another what kind of harness thread?
And you can't wear that?
It is pretty cool when they fly the chute.
I'd rather have this:
http://www.syzfoiler.com/
F-18 Infusion
#626- SOLD it!
Re: I hate harnesses! [Re: Todd_Sails] #173796
04/03/09 05:01 PM
04/03/09 05:01 PM
RickWhite Offline
RickWhite  Offline
Some of the original A-Cats back in the late 60s had sliding boards. They were pretty narrow boats. Problem was you didn't dare forget to slide it to the windward side.
Rick
Rick White
www.onlinemarinestore.com
Re: I hate harnesses! [Re: pgp] #173818
04/03/09 11:28 PM
04/03/09 11:28 PM
Eastern NC, USA
tshan Offline
tshan  Offline
Eastern NC, USA
To answer the legal question - they are legal but they cannot extend out past the 2.5m width - making them very inefficient. Correct?
"1.2.3 Wings may be carried as long as the equivalent overall beam, when measured over the platform, and one fully extended wing is 2.5 m or less"
Re: I hate harnesses! [Re: tshan] #173843
04/04/09 12:49 PM
04/04/09 12:49 PM
Netherlands
Genealex Offline
Genealex  Offline
Netherlands
Perhaps something along the lines of the asterwind?
The whole rig slide from side to side, they still use trapezes on it, though.
http://www.asterwind.com/
Re: I hate harnesses! [Re: Genealex] #173867
04/04/09 09:34 PM
04/04/09 09:34 PM
SE Pa. or Chesapeak Bay
HMurphey Offline
HMurphey  Offline
Have you ever tried to sail a International Canoe w/ a slider???? or a Chesapeake Log Canoe w/ planks???? or a TheMightyHobie18 MAGNUM??? I've done all three ... well I've attempted the first two with various degrees of success and the H18Mag I do all the time sometimes just on the wing and sometimes trapped off of the wing.
With the IC I spent most of my time swimming ... tippy boat, and I could never get the hang of it.
The Chesapeake Log Canoe ... ALOT of work moving those planks through from side to side. Then out on the plank ... in on the plank ...out ... in ...out/in ... then you have a hole in your sailing shorts !!!! Or if someone's timing is just a little off ... it's swimming time!!!
Trappin out from a H21SE or a H18Mag is a HOOT ... you are high above the water .... and when you stuff it you go flying so farrrrrrr....... Onetime while double trapped off the wings a micro burst hit us, immediately driving the bows under and off we went ... Tarzan and his apprentice ... we snapped both bungies ... and swung out and up until I was looking back at the boat, standing on it's bows as we dragged it forward through the water at the end of the trap wires with our weight/momentem. I never have fallen so far before I hit the water ... we must have been +25' in the air at the top of the arc.
Then of course there is also "The Thomas Crown Affair" w/ the "Ladder Rack" salvaged from one of the Worrell N6.0's. Rick Bliss?? took that leap I believe ....
So having done three of the four ... I recommend a "GOOD" Crotchless Harness ..... I got a Murrays Crotchless when they first came out(1988-89)... used them up eventually (I had two that I had new "seats" sewn in by a sailmaker to extend their lives), good harness .... got a "Musto 6-8 years ago, EXCELLENT ... tried my friend's "Black Magic" recently, even BETTER .... So there are some excellent harnesses out there, the secret is just make sure you have a good spreader bar.
On that Video ... do you think that masthead US flag had something to do w/ the flip???? Once you fly a hull too high the wing drags in the water ... the boat stops ... and gravity takes over .... SPLASH. Thats why you never see TheMightyHobie18 Magnums in hull flying contests ... before you get to the neutral balance point you drag the leeward wing .... and you're done ....
Harry
0 registered members (), 498 guests, and 87 spiders.
Posts267,056
