| What am I doing wrong? #17369 03/14/03 09:23 PM 03/14/03 09:23 PM |
Joined: Jul 2001 Posts: 1,253 Columbia South Carolina, USA dave mosley OP
Posts: 1,253 Columbia South Carolina, USA | I bought the parts to upgrade my downhaul to the theoretical 16:1, but found after installation that I am limited to the length of the blue rope in the picture from the Murrays Catalog. The longer the rope, the less downhaul I get. I need the rope to be a certain distance to be able to hook it to the clew. I still have plenty of room between the clew and the blocks, but the limitation of the lenght of the blue rope runs me bullet block to pivoting exit block(block to block) Any solutions? Murrays Downhaul Page
| | | Re: What am I doing wrong?
[Re: bsquared]
#17373 03/17/03 09:00 PM 03/17/03 09:00 PM |
Posts: 12,310 South Carolina | I agree - that's a cascading 8:1 not 16:1.
Ooooo wait...no - they're right - it's 16:1 but in a weird way. Draw it out.
Jake Kohl | | | Re: What am I doing wrong?
[Re: Mike Fahle]
#17375 03/18/03 06:54 AM 03/18/03 06:54 AM |
Posts: 12,310 South Carolina | Dave,
My Nacra 6.0na has the downhaul Mike describes. I'll be at Pee Dee Friday night so you can see it there if you like. It's 16:1 and can bend that hearty 6.0 mast like it were a wet noodle.
#17376 03/18/03 09:30 AM 03/18/03 09:30 AM |
Posts: 1,253 Columbia South Carolina, USA | Are they having an open class at Pee Dee? I thought it was straight Hobie.
Thanks for all the input. I revised my downhaul and used the small bullet blocks elsewhere, so no loss. I'll send pix when it stops raining long ebough for me to get to my boat!
David
[Re: dave mosley]
#17377 03/18/03 11:04 AM 03/18/03 11:04 AM |
Posts: 12,310 South Carolina | The NOR doesn't say anything about whether or not there's an open class but I assumed there would be. I've got an email out to ask that question now.
[Re: bsquared]
#17379 03/18/03 11:48 PM 03/18/03 11:48 PM |
Posts: 58 Canberra, Australia | I think, with the way that you are explaining it, you're pulling both the red strings at the same time - not thinking of it as two sided. If you look at the red system by itself its a simple 4:1 system just that you can pull either end of it right? Just like having a system with a double block at the top and a single block with becket at the bottom right. The bit that you tie on to the becket is essentially the end that goes through the other cleat. Now if you look at the blue system then its exactly the same - just that the ends of the rope are blocked out up at the top block. So the blue system is a 4:1 system as well. Now because you're only pulling one end of the red system at a time its essentially tacked on to the end of the blue 4:1 system making 16:1. simple.... ish..... I think....  cheers,
Taipan 4.9 AUS129 AlphabetSoup
| | | Re: force diagram
[Re: bsquared]
#17382 03/19/03 01:30 PM 03/19/03 01:30 PM |
Posts: 12,310 South Carolina | I perfomed a quick calculation on pull distances and it agrees with you - 3" of pull draws the sail down .125"...that's 8:1. I've tried every conceivable way to politely disprove what you've stated but keep coming up with your answer. Where I keep getting confused is that if you consider one of the blocks that terminates the blue line is free and not stationary - you might think that it adds to the tension on the blue line. I was considering that this effect was putting tension on the blue line equal to 4x (2x + 2x = 4x) because it was being pulled on either side by 2x but, as you stated, that isn't possible - if you split the system in the middle, the sum of the forces doesn't equal zero if you look at it that way. I'll drop a line to Murrays to let them know that they should probably re-examine that 16:1 description (althought they leave it a bit cloudy with the word "theoretical" thrown in there) If you break the following diagram anywhere, your forces are not 20lbs in the middle but always 10lbs. i.e. the sumation of forces in a stationary system must equal zero no matter how you break it down. 10lbs <--------------->10lbs 10lbs <-----/10lbs (not 20 here).
Jake Kohl | | | Damn I suck at math!
#17383 03/19/03 02:14 PM 03/19/03 02:14 PM |
Posts: 1,253 Columbia South Carolina, USA | I re-rigged and am pretty happy with what I've got now. Even though this old G-Cat weighs in @400 #s it quickly gets overpowered upwind single handed. Maybe now I can get the sq top a little flatter.
Thanks for all the information
David Mosley
| | | Re: force diagram
#17385 03/19/03 07:01 PM 03/19/03 07:01 PM |
Joined: Jun 2001 Posts: 90 Québec, Canada CharlesLeblanc
Posts: 90 Québec, Canada | Jake, I worked on the system and I am pretty sure that I have figurated it out The diagram showed in the Murray's does wourk out at 8:1. However, it is possible to re-arrange it to 16:1 but you will not be able to ajust it from both sides. Another point, on my 8:1 system, you might argue that if two peoples pull with a 10lbs force, the total pull would be 20lbs. However, the rope tension is 10lbs and if one of the two person would pull with less than 10lbs, let's say 9lbs for example, he would not be able to hold the rope. If the other sides is anchored by a cleat and something else, the anchor is actually pulling on the rope with an equal force
Charles Leblanc
Nacra 5.2 #26
499
guests, and 29
