Center Board Slop #181438
06/08/09 07:40 PM
06/08/09 07:40 PM
V
Ventucky Red Offline OP
V
Boat - Prindle 18-2
Symptom - Centerboard slap form side to side (sometimes) while beam or broad reach making thunk think thunk thunk sound.
Solution -What I am thinking of doing is putting some APS daggerbaord carpet on one side of the bunk to lessen the slop.
My question is, do I want any sideways play in the center boards, or shim this a tight as possible without distorting the centerboard trunk?
Thanks
Re: Center Board Slop [Re: Ventucky Red] #181512
06/09/09 10:14 AM
06/09/09 10:14 AM
Memphis, TN
Andy Humphries Offline
Memphis, TN
You might try the soft side of some industrial duty Velcro, available at Lowes or Home Depot. Put it on both sides if there is room.
Re: Center Board Slop [Re: Ventucky Red] #181515
06/09/09 10:34 AM
06/09/09 10:34 AM
andrewscott
andrewscott
no sideways play.. but you want to make sure its straight. the optimal way is to put your cat on workhorse (or similar), drop the boards and with level make sure you are good.
PS i use thick (foam) double sided tape and leave 1 side of the tape cover on.
Re: Center Board Slop [Re: ] #181528
06/09/09 11:28 AM
06/09/09 11:28 AM
Tn
JACKJACK Offline
JACKJACK  Offline
Tn
Another option. On my P-19, when I refinished my boards I sprayed gelcoat up into the pivot tube hole. This hole was worn and the CB/tube fit had alot of slop. This made for a very snug fit for the pvc pivot tube into board. I also replaced the lockdown button and this completely eliminated any movement of the assembly.
Jack
Re: Center Board Slop [Re: Ventucky Red] #181529
06/09/09 11:31 AM
06/09/09 11:31 AM
srm Offline
srm  Offline
Centerboards only tend to clunk around when they're not loaded- like you said, when broad reaching. In that case, just pull them up, they're only causing drag anyway.
sm
Re: Center Board Slop [Re: srm] #181532
06/09/09 11:37 AM
06/09/09 11:37 AM
andrewscott
andrewscott
sm
You are probably correct... when i said i use tape .. i actually only do it on the forward and aft well walls (to avoid damage from pushing the boards up or down)... i dont get much jigglin/rattlin when under load.
0 registered members (), 267 guests, and 27 spiders.
