I am very confused about the use of the H16 hull template. I'm using a 8 1/2 X 11 piece of paper I downloaded. It has hull bottom templates for the 14, 16, and 18 on it. There's a scale across the top that I assume is to properly size the template after downloading. (I used a copier to enlarge it.)
The text seems to indicate three places to use the template: at the fore and aft pylons and right in the middle. It's not even close on the pylons. Are you only suposed to check the shape in one place between the pylons? Is there some other scale I need to know about to get the template to fit the other cross sections?
Thanks.
