Page 3 of 3 1 2 3
Re: Recommendations for single handed beach cat? [Re: DennisMe] #187029
08/05/09 02:23 AM
08/05/09 02:23 AM
Y
yurd Offline
yurd  Offline
Y
Originally Posted by DennisMe
I sail solo on a nacra 5.2 myself (my first own cat) and love having two sails. In fact, I'm planning to install a spin next year! The 5.2 without the jib bores me to death and has too much weather helm for my comfort, doesn't tack in waves as well by a long shot. Trim the mast forward and it gets a bit "jittery". I have a righting pole installed for very easy solo-righting. I'm almost 200 lbs though... Putting up the mast solo takes some planning but can be done. Usually someone else spots me and comes to help, so I have only raised the mast solo about two times! Most times I just pull the boat over on its side to work on the mast and fittings. The boat sails very well, but it is way too heavy to pull up our beach solo (and I am quite a strong guy If I do say so myself). As a consequence I now sail at a lake! You may want to bear that in mind.
How well does that righting pole work for you on the 5.2? I'm 195 give or take and looking for something quick and easy to right my 5.2 solo as I flip quite often.
Re: Recommendations for single handed beach cat? [Re: yurd] #187030
08/05/09 02:43 AM
08/05/09 02:43 AM
Netherlands
DennisMe Offline
DennisMe  Offline
Netherlands
Works well enough for me. It is the lower half of an old carbon windsurfer mast. I made a mounting plate out of thick (approx. 3/16") aluminum strip from the local scrap yard and mounted the mast using the original windsurfer mast base (I ground off the downhaul pulleys) to the main beam. If I were to do it again I would probably just mount it to the dolphin striker where it goes through the beam. As it is now I have a limiter line so the pole will not get pinched by the Dolphin striker. The whole thing is set up to auto retract, even if still deployed. (it just misses the dagger boards) This helps if I flip in shallow water. It gives me so much leverage I can even pull the boat over using just my weight on land. (I can do that with the trapeze handle but I need enough grip in the soil to be able to pull outward as well as down.) I have been planning to do a demo video, but I need another volunteer for the camera and someone to discourage potential helpers!
One thing I can tell you, it sure is quick and easy, but I don't use it often. You may need to go for a mechanical type of mast base fitting. i have a diabolo rubber type and it is wearing out quickly. Mine was second hand and also very old, so that could be it. But it is a single point of failure.
Re: Recommendations for single handed beach cat? [Re: DennisMe] #187053
08/05/09 10:39 AM
08/05/09 10:39 AM
TurboCat Offline
TurboCat  Offline
Yurd,
Do you have problems righting your 5.2? I can right mine solo and i weigh in at 180lbs.
Re: Recommendations for single handed beach cat? [Re: TurboCat] #187067
08/05/09 01:24 PM
08/05/09 01:24 PM
Palm Beach County
TheManShed Offline
TheManShed  Offline
Palm Beach County
This is a picture back when I had hair and the 5.2 was a new boat. I use to right the boat by leaving the main tight but had a hold of the sheet. I'd stand at the end of the dagger boards holding the top one and point her into the wind.
Flying A Hull just about the best thing thrill I know!
Mike Shappell
www.themanshed.com
TMS-20 Builder
G-Cat 5.7 - Current Boat
NACRA 5.2 - early 70's
Re: Recommendations for single handed beach cat? [Re: TurboCat] #187150
08/05/09 11:35 PM
08/05/09 11:35 PM
Y
yurd Offline
yurd  Offline
Y
Originally Posted by TurboCat
Yurd,
I haven't actually flipped the 5.2 that many times (yet). I flipped my P18 very often, but I haven't had the 5.2 very long. I flipped once and found out that nothing towards the top of the mast was sealed...took 3 of us to right it.
I've never tried standing on the daggers, though. I guess I'll try to right it alone before the end of the summer and see if I can do it, and go from there.
Re: Recommendations for single handed beach cat? [Re: yurd] #187153
08/06/09 01:04 AM
08/06/09 01:04 AM
Palm Beach County
TheManShed Offline
TheManShed  Offline
Palm Beach County
Yued,
Give it a shot on the dagger boards just make sure you don't drop the main sheet.
Mike Shappell
www.themanshed.com
TMS-20 Builder
Page 3 of 3 1 2 3
0 registered members (), 245 guests, and 45 spiders.
