main sail deep or flat #187757
08/12/09 05:37 PM
08/12/09 05:37 PM
C
cooper engineer Offline OP
C
it's possible to indicate an approximate value of camber for the two cases?
Thanks
Re: main sail deep or flat [Re: cooper engineer] #187766
08/12/09 07:16 PM
08/12/09 07:16 PM
Flat - 11 to 12%
Full - 13 to 15%
(% of chord length)
Re: main sail deep or flat [Re: mbounds] #187805
08/13/09 04:42 AM
08/13/09 04:42 AM
C
C
I expected lower numbers ......
Re: main sail deep or flat [Re: cooper engineer] #187822
08/13/09 08:22 AM
08/13/09 08:22 AM
Agreed
Full:
Flat
Re: main sail deep or flat [Re: scooby_simon] #187827
08/13/09 08:54 AM
08/13/09 08:54 AM
andrewscott
andrewscott
Hey Scoobie, what is that line on your sidestay (or trapwire) for?
Re: main sail deep or flat [Re: ] #187836
08/13/09 09:16 AM
08/13/09 09:16 AM
Dont forget to include the mast when looking at the draft. A sail designed for 10% draft will probably be 12% when put on a rotating mast.
10-12% is in the ballpark in my experience.
Re: main sail deep or flat [Re: scooby_simon] #187842
08/13/09 09:37 AM
08/13/09 09:37 AM
The wonders of PhotoShop:
The sail looks seriously screwed up in the second photo. The leech is very loose up top. Draft is too far forward.
Re: main sail deep or flat [Re: mbounds] #187933
08/13/09 02:09 PM
08/13/09 02:09 PM
Top of the sail is too twisted away, I have fixed that with some work on the sail battens.
Sail now stands up better when loads of DH is applied. Did some work on it with different top battens.
I'm light so I am quite happy with the draft well forward and little of it!
Re: main sail deep or flat [Re: ] #187934
08/13/09 02:17 PM
08/13/09 02:17 PM
waynemarlow Offline
waynemarlow  Offline
Stops the Spinnaker being pulled up between the forestay and sidestay wires and getting jammed in light wind ( you can virtually use the flat spinnakers we use on the F16's as reaching sails )
Re: main sail deep or flat [Re: waynemarlow] #187935
08/13/09 02:26 PM
08/13/09 02:26 PM
Yep. It also helps me sailing very high in very light winds to tack the kite with less risk of snags.
Re: main sail deep or flat [Re: scooby_simon] #187947
08/13/09 03:23 PM
08/13/09 03:23 PM
andrewscott
andrewscott
gotcha.. thanks... i never have a problem like that.. my problems are at the waterlevel.
0 registered members (), 485 guests, and 39 spiders.
