A-Cat Mast Repair part2 #188464
08/19/09 11:37 PM
08/19/09 11:37 PM
Palm Beach County
TheManShed Offline OP
Palm Beach County
Back to work on the A-Cat mast. In the first part I built the air pump system, and then tested it on the hull lay-up for the TMS-20, I did not want to just jump into the mast repair. In this post I am building the sleeves and showing how I bagged out the sleeves. I figure somebody may like to see a post on how to vacuum bag. On this project I had time to take some pics. One the TMS-20 lay-up we were too busy to grab the camera.
3M masking film.JPG (200 downloads)
3M masking film great stuff make sure you have the writing on the outside.
Taped into sail grove.JPG (199 downloads)
Taped in the sail slot
Masking film fitted to mast.JPG (199 downloads)
Masking film rolled around the mast a few times - works better then wax paper.
Mike Shappell
www.themanshed.com
TMS-20 Builder
G-Cat 5.7 - Current Boat
NACRA 5.2 - early 70's
Re: A-Cat Mast Repair part2 [Re: TheManShed] #188465
08/19/09 11:41 PM
08/19/09 11:41 PM
Palm Beach County
Palm Beach County
next
Dumb-dumb ready for bagging plastic.JPG (196 downloads)
Dumb-dumb on the outside area for bag
Taped to protect dumb-dumb from resin.JPG (197 downloads)
Protect the dumb-dumb from resin
Getting bag ready.JPG (198 downloads)
Getting the bag ready. All of this before glassing.
Mike Shappell
www.themanshed.com
TMS-20 Builder
Re: A-Cat Mast Repair part2 [Re: TheManShed] #188466
08/19/09 11:44 PM
08/19/09 11:44 PM
Palm Beach County
Palm Beach County
next...
Building frog.JPG (195 downloads)
Building the frog - suction device
Frog
Layer 1 of carbon.JPG (195 downloads)
First layer of carbon
Mike Shappell
www.themanshed.com
TMS-20 Builder
Re: A-Cat Mast Repair part2 [Re: TheManShed] #188467
08/19/09 11:47 PM
08/19/09 11:47 PM
Palm Beach County
Palm Beach County
Next...
3 layers of carbon wetted out.JPG (189 downloads)
Wetted out all 3 layers
Peel Ply.JPG (190 downloads)
Peel Ply
Bagging felt.JPG (190 downloads)
Bleeder cloth
Mike Shappell
www.themanshed.com
TMS-20 Builder
Re: A-Cat Mast Repair part2 [Re: TheManShed] #188468
08/19/09 11:51 PM
08/19/09 11:51 PM
Palm Beach County
Palm Beach County
next
View inside.JPG (187 downloads)
View inside still green - rubber feel.
Put back on Mast to cure out.JPG (188 downloads)
Put it back on the mast to make sure it cures over night
Mike Shappell
www.themanshed.com
TMS-20 Builder
Re: A-Cat Mast Repair part2 [Re: TheManShed] #188469
08/19/09 11:53 PM
08/19/09 11:53 PM
Palm Beach County
Palm Beach County
I'll pull the peel ply tomorrow. Then I'll be ready to cut the slot area and fit the sleeves inside the mast.
More Later...............
Vacuum on.JPG (180 downloads)
Pulling a 3 micron vacuum
Mike Shappell
www.themanshed.com
TMS-20 Builder
Re: A-Cat Mast Repair part2 [Re: TheManShed] #188471
08/20/09 01:46 AM
08/20/09 01:46 AM
taipanfc Offline
taipanfc  Offline
Sorry for the hijack, but I am looking for a 5.4m long A-Cat section. So if anyone has broken an A-Cat mast section and doesn't want to go through the above or claimed a new one on insurance, let me know. Thanks.
Re: A-Cat Mast Repair part2 [Re: taipanfc] #188754
08/23/09 01:03 AM
08/23/09 01:03 AM
Palm Beach County
Palm Beach County
I fitted the sleeves to each mast section 5mm and 2.5 mm. I made the 2.5mm sleeve a bit stiffer and leveled the diameter of the inside of the spar section with the sleeves. No more 2.5mm hard spot - drop in wall thickness, so the manufacturing defect has been corrected. I have a little work left on the sleeves now that I’ve fitted everything. Tomorrow, err later today after some sleep I will add reinforcement inside the inner sleeve where the mast sections join and a lay-up to the sleeve in the sail groove area.
I have it level on the sail groove area to make and eyeball straight. I will then throw the laser beam on the mast to make sure it is straight from foot to head. Then drill some alignment holes for screws and glue it together. Following are some pics of the work today.
Sleeve ready to trim.JPG (122 downloads)
Cutting to size
Building Sleeve.JPG (122 downloads)
Layup of the bottom area after cutting
View of mest sections with sleeves.JPG (121 downloads)
Sleeves
Mike Shappell
www.themanshed.com
TMS-20 Builder
Re: A-Cat Mast Repair part2 [Re: TheManShed] #188755
08/23/09 01:04 AM
08/23/09 01:04 AM
Palm Beach County
Palm Beach County
More..
Double sleeves.JPG (118 downloads)
Double Sleeve 2.JPG (116 downloads)
Outer sleeve slide over inner sleeve.JPG (117 downloads)
Outer sleeve pushed over inner sleeve
Mike Shappell
www.themanshed.com
TMS-20 Builder
Re: A-Cat Mast Repair part2 [Re: TheManShed] #188756
08/23/09 01:10 AM
08/23/09 01:10 AM
Palm Beach County
Palm Beach County
More.....
Level and small mast section supported
Dry Run level and fitted.JPG (114 downloads)
Dry run
Dry Run level and fitted 2.JPG (118 downloads)
Dry Run 2
Mike Shappell
www.themanshed.com
TMS-20 Builder
Re: A-Cat Mast Repair part2 [Re: TheManShed] #188757
08/23/09 01:12 AM
08/23/09 01:12 AM
Palm Beach County
Palm Beach County
One last picture. One other thing I will do is to taper the sleeves at the ends as to not leeve a new hard spot.
Tomorrow I will make it one mast section again ready for everybody's favorite thing....grinding.
If time, weather, and the morning work sets-up in time start the glass work on the outside.
Later.....Mike
Mike Shappell
www.themanshed.com
TMS-20 Builder
Re: A-Cat Mast Repair part2 [Re: TheManShed] #188765
08/23/09 11:05 AM
08/23/09 11:05 AM
cyberspeed Offline
cyberspeed  Offline
Nice shot of the moon in the last pic in the first page.
craig van eaton
Supercat 20
TEAM CYBERSPEED
www.TeamCyberspeed.com
Endurance Series
www.SailSeries.com
Re: A-Cat Mast Repair part2 [Re: cyberspeed] #188768
08/23/09 11:32 AM
08/23/09 11:32 AM
Palm Beach County
Palm Beach County
When I saw that I thought the same but knew it was not the moon. The picture was taken at Midnight or there about the object is 25 degrees from the horizon looking NNE out of the shop. The moon would be at least 90 degrees overhead.
Fox Mulder and Dana Scully are you out there ………..
..--------- That is all I need now broke-butt spaceships in the shop I'll never get the TMS-20 done.
Mike Shappell
www.themanshed.com
TMS-20 Builder
Re: A-Cat Mast Repair part2 [Re: TheManShed] #189016
08/25/09 09:25 PM
08/25/09 09:25 PM
Iowa
Rum Bum Offline
Rum Bum  Offline
Iowa
Hilarious. Nuf said...
Josh
Nacra 5.5SL
Sail #915
0 registered members (), 657 guests, and 123 spiders.
Posts267,056
