jib tuning #19021
04/28/03 09:34 AM
04/28/03 09:34 AM
Crozet (near Charlottesville),...
Marooned_In_Crozet Offline OP
Just wanted to know how everybody sets their jib halyards and clew holes for prevailing conditions.
Brian
Re: jib tuning [Re: Marooned_In_Crozet] #19022
04/29/03 01:59 PM
04/29/03 01:59 PM
Branford, CT
rhodysail Offline
rhodysail  Offline
Branford, CT
The way I understand it
The rake (determined by jib halyard) should be set so that the mainsheet blocks are touching when there is proper leach tension in the main. (Maybe a little more than proper leach tension so you have some range)
The jib lead should be attached so that you also get proper tension in the jib leach.
Re: jib tuning [Re: rhodysail] #19023
04/29/03 08:20 PM
04/29/03 08:20 PM
H
hydroluge Offline
hydroluge  Offline
H
in my square sailing experience, we call blocks touching "chock-a-block" or "to-block" just reminiscing of the 5 years i spent onboard the nyckel, ahhhh nothing like doing 10 knots up the coast of cape cod heeling so hard you can walk on the sides of vertical objects without much effort.....
ok ok , snapping out of it.
peace
jason
0 registered members (), 321 guests, and 55 spiders.
