Nacra 5.0 Tuning tip #190591
09/08/09 08:56 PM
09/08/09 08:56 PM
Chelmsford, MA
Barry Offline OP
Barry  Offline OP
Chelmsford, MA
Guys,
Setting up a 5.0 and can't find any base tuning guides online.
Any help with the following would be great:
Diamond wire tension
Mast rake
Thanks
Re: Nacra 5.0 Tuning tip [Re: Barry] #190615
09/09/09 07:47 AM
09/09/09 07:47 AM
Oklahoma City
ghhm43 Offline
ghhm43  Offline
Oklahoma City
Gordon
Macgregor 222
Nacra 5.5sl
E-Scow 1975 Hull #1
Re: Nacra 5.0 Tuning tip [Re: ghhm43] #190618
09/09/09 08:08 AM
09/09/09 08:08 AM
San Diego
H
hokie Offline
hokie  Offline
H
San Diego
This is what I do for tension and mast rake, others may do differently. My sails are old so that probably makes a difference too. I keep my diamond wires fairly tight, make sure the mast looks straight. I think I had read somewhere you should be able to press the wires to the mast 6 inches above the turnbuckle but mine are a little tighter than that. I carry much less rake compared to a hobie 16, I am usually three to four holes down on the front adjuster but this will vary between boats.
Re: Nacra 5.0 Tuning tip [Re: Barry] #190647
09/09/09 02:45 PM
09/09/09 02:45 PM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
Keep in mind that whether you have straight spreaders or raked back spreaders makes a huge difference in you you tune the diamond wire tension.
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: Nacra 5.0 Tuning tip [Re: ejpoulsen] #190693
09/10/09 07:25 AM
09/10/09 07:25 AM
Chelmsford, MA
Barry Offline OP
Barry  Offline OP
Chelmsford, MA
They are not straight but are not adjustable. It a 1987.
1 registered members (vasil), 372 guests, and 39 spiders.
