Mast spreader #183457
06/29/09 11:21 AM
06/29/09 11:21 AM
Near SLC, Utah
tomthouse Offline OP
Near SLC, Utah
I've got an old Solcat 19. Its factory mast is designed without a diamond wire.
When it tumbled over on the beach it bent the mast.
I believe I can resolve the bend by installing diamond wires.
My question is where can I come up with a used spreader assembly???
A swept back assembly would probably be better.
Any thoughts???
Re: Mast spreader [Re: tomthouse] #191155
09/16/09 08:26 PM
09/16/09 08:26 PM
Lincoln, AL
CaptainScurvey Offline
Lincoln, AL
Solcat 19?
Maybe a SuperCat 19?
I have un-bent mine buy using two heafty trees and a come-a-long.
Re: Mast spreader [Re: CaptainScurvey] #191174
09/17/09 07:45 AM
09/17/09 07:45 AM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
Originally Posted by CaptainScurvey
Solcat 19?
Check the Hobie 16 forum both here and at the Hobie Forum.
There are a number of ways to UNBEND a BENT spreaderless mast.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Alachua FL/Put-In-Bay
Re: Mast spreader [Re: Mugrace72] #191181
09/17/09 09:11 AM
09/17/09 09:11 AM
central oregon, u.s.a.
dand Offline
dand  Offline
My Prindle 15 went over on the beach at a local lake during a short lived, but violent wind and rain storm. No sail damage, but it bent the mast.
I spoke with the Prindle factor and based on their recommendations I straightened my bent P-15 mast by placing it on two solid objects, placed a piece of carpet on the area of the bend, and slowly and increasingly pressed down on the bend with my small tractor loader bucket. It eventually straightened out.
The factory suggested I consider installing Prindle 18 spreaders. They of course offered to sell me a new set, and also suggested I search for a used P-18 set. You might also consider spreaders from a P-18.
dan
Re: Mast spreader [Re: tomthouse] #191226
09/18/09 12:29 AM
09/18/09 12:29 AM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
Tom,
Try calling Proctor rigging.
And thanks again for the waffles.
Eric
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: Mast spreader [Re: ejpoulsen] #191339
09/19/09 08:55 AM
09/19/09 08:55 AM
Tampa, Fl
deepsees Offline
deepsees  Offline
Tampa, Fl
We bend all manner of metals to test them. One aspect of aluminum is it takes the largest mandrel (round surface) to bend it without over stressing the point of contact. Aluminum suddenly breaks if the stress point is too focused. Heating helps... some... but bear in mind that aluminum does not let you know it is about to turn into a liquid state by glowing.
Deepsees
Re: Mast spreader [Re: deepsees] #191340
09/19/09 09:06 AM
09/19/09 09:06 AM
Palm Beach County
TheManShed Offline
TheManShed  Offline
Palm Beach County
I made a knock off of the SuperCat spreaders for my G-Cat if you want I'll post a picture it is a pretty good setup.
Mike Shappell
www.themanshed.com
TMS-20 Builder
G-Cat 5.7 - Current Boat
NACRA 5.2 - early 70's
Re: Mast spreader [Re: CaptainScurvey] #191346
09/19/09 10:19 AM
09/19/09 10:19 AM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Beware of the ping of death. shocked
US Sail Level 2 Instructor
US Sail Level 3 Coach
0 registered members (), 361 guests, and 45 spiders.
