Karl,
Where are you standing on the boat during the jibe?
If you are on the back of the boat, out on the wire, and running downwind; wouldn't you pull the tiller and thereby drive the sterns toward your feet?
Regardless, I'd recommend some foot straps where ever you happen to be standing...
Agreed. When I was sailing a LOT;; i could gybe from the wire in a similar way to the MPS guys do.
Start to bear off, hull comes towards you; pick yourself up; step on hull; keep bearing off; under boom; change hands with tiller, re-sheet kite, mis trapeze handle on the way out and fall off the other side!!!!!!
